6DOF build question.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by T R Para, Dec 7, 2018.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,440Coins
    AC motor, 6DOF
    I have been reading the 6dof builds. It seems that some start out with motor/gearbox and then switch to DIY actuators.
    I got a lead on 6 matched wheelchair motors 350watt cont /1000watt intermittent.
    Is it even worth the experimenting with motors?
    I was thinking I could maybe repurpose the 24vdc motors and upgrade to diy actuators..
    And since I got you here. what is the deal with using carbon fiber output tubes vs say chromoly or aluminum tubes??
  2. MarkusB
    4,213Coins
    Maybe @Grigory can help you with the decision between actuators and gear motors, because he made a full circle from gear motors to actuators and back to gear motors.
  3. T R Para
    Cincinnati, Oh
    2,440Coins
    AC motor, 6DOF
    Thanks Marcus.
    That pretty much spelled it all out.
    And only 3 pages of posts!
    If I were to build the ultimate 6dof thats the way to go.
