30" Linear Actuator ($100) - Will this work for a 6DOF rig?
Discussion in 'Motor actuators and drivers' started by insomagent, Oct 10, 2017.
  1. insomagent
    insomagent New Member
    124Coins
    I was blown away by the 6DOF rigs I saw on this site.
    I searched around for linear actuators on ebay, and came across this.
    (ebay , com) /itm/Heavy-Duty-330lb-Stroke-Electric-Linear-Actuator-Motor-DC12V-150KG-Max-Lift/112415134937?hash=item1a2c76d4d9%3Ag%3ADy4AAOSw9OFZIkFL&var=
    Would something like this be sufficient? What are the things to keep in mind when planning out these rigs? Where should one start? I've been scouring the forums and it seems like there isn't one single "starting point" or a single one size fits all rig.
    I've also thought of getting wiper motors from a scrapyard, which would run about $25 each. I don't know about that though.
    I want to build a smaller prototype (with RC servos) of a 6dof device, but I want to think about the real world specs before I start prototyping.
    (ps. apologies for the bad link, once my account is upgraded I will update it)
  2. RandomCoder
    Control Engineer
    1,674Coins
    Sorry to break the bad news but these are far too slow for use on motion simulators. Typically you need a minimum of 150mm/s. Other factors to consider when purchasing linear actuators of the shelf is the rated duty cycle. This is why a lot of people here are building DIY linear actuators as commercial grade ones are very expensive.
    Here's a useful link to read up further....
    https://www.xsimulator.net/community/faq/speed-needed-for-good-motion.218/
    Search the forum, the several users that already use linear actuators and several others that are currently building new rigs.
    Welcome to the community ;)
  3. insomagent
    124Coins
    Thanks @RandomCoder ! I was hesitant but I'm glad I asked before buying.
  4. RandomCoder
    Control Engineer
    1,674Coins
    To build a 6DOF Stewart Platform is a costly project and not for the faint hearted. Not only do you require six actuators, they also have to be fast and powerful enough to share the load of the platform, driver and all equipment. Then there is multiples of everything else, drivers, power supplies, cabling etc. It also takes considerable time to build and a reasonable amount of space to use.
    I think lots of people here start off small and gradually build up to bigger and better simulators. I'm yet to get started but plan to build a 3 or 4DOF using DIY linear actuators. Which I'm hoping could be later expanded to use in a 6DOF if I ever take it that far.
    There is a really good 6DOF using worm gear motors on the forum here somewhere, I forget who built it but will have a search and post below if I find it. It is more compact than most Stewart platforms and I guess cheaper than building custom actuators.
    Good luck on your quest!
  5. RandomCoder
    Control Engineer
    1,674Coins
  6. Zed
    USA
    5,842Coins
  7. insomagent
    124Coins
    150,542Coins
    +11,017 / 55 / -2
    You need very powerful DC or AC wormdrive motors for a 6DOF if not using actuators, have a look here as a start, though there are more 6DOF builds in the member project section as well: https://www.xsimulator.net/community/faq/list-of-6dof-projects.179/
  9. RandomCoder
    Control Engineer
    1,674Coins
    This forum is always unveiling new surprises. I didn't know this list existed, it's a great resource and far easier than using the search.
    But why is it that when searching for "6DOF" this FAQ is not top of the list of results? :mad:
  10. RandomCoder
    Control Engineer
    1,674Coins
