2DOF Wiper Sim from Interview 2010
Discussion in 'DIY Motion Simulator Projects' started by Deleted member 4120, Oct 1, 2010.
  1. Deleted member 4120
    Deleted member 4120
    hello people,
    i'am Alex and i would like my Wiper Motion project protocol.
    because I'm pretty new to this scene I need your help. :yes:
    As far as I am now!
    - Boards Appointed http://www.platinenbelichter.de
    - Electronic Appointed http://www.reichelt.de
    - Item-frame Appointed http://www.item24.com
    - Transformator (POWER SUPPLY) http://www.smd-light.de or http://www.ledhome24.de/ better at ebay search: LED Transformator
    What else I need!
    - Wiper Motors http://shop.ebay.com/?_from=R40&_trksid ... Categories
    My order list:
    Boards: http://www.platinenbelichter.de
    Electronic:http://www.Reichelt.de
    Here is my shopping cart:
    - Tronic's AVR MotionController v1.5 Parts: http://www.reichelt.de/?ACTION=20;AWKID ... ROVID=2084
    - Simple dual H-bridge PCB 1.2b parts: http://www.reichelt.de/?ACTION=20;AWKID ... ROVID=2084
    - NOT FORGOTTEN!!! (missing in the shopping cart please do not forget to order with) 20x http://www.reichelt.de/?;ACTION=3;LA=50 ... SORT=artnr
    NOT FORGOTTEN:
    - Potis 10k ohm Multiturn: http://www.reichelt.de/?ACTION=3;GROUP= ... 98df65d6a1
    - LCD 162: http://www.reichelt.de/?ACTION=3;ARTICL ... 5fd6a4887b
    - USB Adanpter: http://www.reichelt.de/?;ACTION=3;LA=50 ... SORT=artnr
    - Transformator (POWER SUPPLY): http://www.smd-light.de or http://www.ledhome24.de/ better at ebay search: LED Transformator
    !!!!IMPORTANT!!!!! *edit
    (IRFZ 44N Pleace to update IRLZ44N or IRL540N)
    (when you use 22,18,14 Mhz you need 2 KERKO 18P!!!) in the shopping cart are the parts for 24, 22, 18, 14MHZ!!!!
    Instructions, Pictures, Layouts and Gerber Exellion download here: http://www.megaupload.com/?d=N0WZ1GAZ
    When my Parts arive i write more. :thbup:
    thanks
  2. Frakk
    Frakk Active Member
    328Coins
    Re: Wiper Motin Projekt Protocol by Interview 2010
    I have posted this about 15 times already, and people still get it wrong...
    You need IRL 44N, a LOGIC LEVEL MOSFET, and NOT IRFZ 44N, NOT IRF 3205.
  3. Deleted member 4120
    Deleted member 4120
    Hmm sorry :blush: ( NO TUTORIALS!!)
    and where can i read that??
    is in my part list something wrong??
    thx frakk
  4. Deleted member 4120
    Deleted member 4120
    There is a small error in the part list! The IRFZ44 part is actually the IRL44N model
    (There is difference between IRFZ44 and IRLZ44N !!!! You need the IRLZ44N ones!!!!!!
    The ones without N are not able to fully turn on by the 5v logical system of the h-bridge! )
  5. Frakk
    Frakk Active Member
    328Coins
    The N doesn't matter in the end. It is the L you need, meaning LOGIC LEVEL -> turns on with 5V.
    The H-Bridge only has 5V to turn on the low side MOSFETs, regular ones turn on with 10-12V. If you don't use LOGIC LEVEL, they will heat up very fast and won't give you full power.
  6. Deleted member 4120
    Deleted member 4120
  7. Frakk
    Frakk Active Member
    328Coins
    Instead of PM's, please post your questions here. Maybe others can benefit from it.
    Yes you need the IRL 44(N). You can also use any other LOGIC LEVEL mosfet that has the same Gate-Drain-Source pin order and handles the current you need.
    http://www.reichelt.de/?;ACTION=3;LA=44 ... d448dc7b0b
  8. Deleted member 4120
    Deleted member 4120
  9. Frakk
    Frakk Active Member
    328Coins
    Yes that is right too, but why would you pay more, for less?
    Use crystals 14.7456MHz or 18.432MHz.
    I hope you know what you are doing when it comes to putting it together!
    In my opinion you should try the Pololu jrk 12v12...
  10. Deleted member 4120
    Deleted member 4120
    i use crystals 24Mhz..
    In this pololu controller:
    Peak output current: 30 A
    ...well, i don't no.... maybe it's to small.
  11. Frakk
    Frakk Active Member
    328Coins
    Why would you use 24MHz? The At8535 is rated for 16MHz maximum...
    If you don't know if 30A is too small, maybe you should listen to those who know.
    Most wiper motors draw less than 20A peak...
    Unless you get a truck or bus wiper motor with long arms and heavy load, 30A will be enough and you will save a lot of headache.
  12. egoexpress
    422Coins
    :thbup:
    Afais, your Reichelt partlist contains parts for both the AMC and the h-bridge in a mixed up order. The effort to check it isnt in relation to your effort to reorder something missing.
    Simply order what's on your list so far, and start soldering. You'll notice what's missing along the way ;D
    Thanos has been able to successfully run the 8535 with 24khz. However, mine didnt, and I had to step back to 22khz. Its possible to run it with 24khz though. Depends on the batch qualitiy I guess.
    regards
  13. Deleted member 4120
    Deleted member 4120
    That why i use 24MHz ;)
    Tronic's AVR motion controller v1.5 Parts:
    IC chips:
    1- ATmega8535 16PI (rated on 16Mhz) (I overclocked it using a 24Mhz crystal)
    An ATMega644 is also shown here as future replacement (different firmware required)
    you must read :p
  14. Frakk
    Frakk Active Member
    328Coins
    :rofl: :rofl: :rofl:
    Are you telling me that I must read about overclocking a microcontroller to 150% of it's maximum clock?
    You go ahead and do what you want. But please don't come back crying if it doesn't work... :D
    @ego: You are right, it depends on the batch. Either way, you are not really gaining anything by overclocking, only increasing the chance of failure and errors.
    Oh.. and not to mention the error rate of the UART clock. Frequencies other than multiples of 1.8432MHz will have a % error in the BAUD rate generator...
  15. egoexpress
    422Coins
    Well, you gain cycle speed.
    However, I'd recommend a safer overclocking speed like 18-22khz.
  16. Frakk
    Frakk Active Member
    328Coins
    In the case of the AMC, cycle speed won't affect the performance what so ever. The only thing you might notice is the PWM frequency if it is in the audible range below ~18kHz.
    The USO is limited to 1kHz output rate (1ms delay) and I see no reason to have a faster PMW duty% refresh rate. If the firmware cannot calculate the P term that fast, there are serious issues with it.
  17. egoexpress
    422Coins
    If I rememeber right, this was the reason for overclocking that much :blush:
  18. Deleted member 4120
    Deleted member 4120
  19. Deleted member 4120
    Deleted member 4120
    Re: Wiper Motion Projekt Protocol by Interview 2010
    in two days coming my boards :)
    and then i need your help.. :sos:
    thanks all
  20. Deleted member 4120
    Deleted member 4120
    :yippiee:
    my electronic and my race seat is coming..
    tomorrow coming my ITEM for FRAME :brows:
    and then built
    (tomorrow pictures)
    thx
