2dof 3dof
Discussion in 'DIY Motion Simulator Projects' started by tmp, Feb 26, 2019.
  1. tmp
    tmp Member
    295Coins
    2DOF, 3DOF, Arduino, SimforceGT
    good I am new mount my simulator with x-sim with 2dof but I could not make it move and I would like to test with simtools have if you could make a hand and also for the code for arduino one. Thanks in advance
    153,053Coins
    +11,117 / 56 / -2
  3. tmp
    tmp Member
    295Coins
    [QUOTE = "noorbeast, post: 173598, miembro: 10786"] Si está buscando el código Arduino para usar con SimTools, tiene varias opciones: https://www.xsimulator.net/community/faq/arduino- código de uso-con-varios-hardware-y-simtools.31 /
    thank you very much if I am able to make it work because it can not be done with impotence.
    I have an arduino ibt-2 I have 2 but I want to put 3 motors if I see the wiring diagram.
    Le sugiero que pruebe el código SMC3 primero, ya que tiene una aplicación visual útil para realizar la configuración: http://www.xsimulator.net/community/threads/smc3-arduino-3dof-motor-driver-and-windows- utilities.4957 / [/ QUOTE]
