25 % motion limiter
Discussion in 'DIY Motion Simulator Projects' started by abs, Jul 11, 2011.
  1. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    I want to enable and making sure to have the 25 percent limitation in game mode (not in test mode) but I am a bit confused on how. Is it in the math setup section? do we have to enter 25 0r 75 in percent limiter plugin iin the loaded profile ? iit seem 75 is more indicated , 25 wont give motion enough. The 75 value wont be OK if the percent scale is activated . Is this possible?
    thanks for the help
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    You can find this in the SCN5 interface settings dialog. Odds are if you don't know where it is, it's enabled because it's enabled by default. I would definitely suggest keeping it on.
  3. Muzza
    Muzza New Member
    Sunshine Coast Australia
    Hi there,
    To enable the 25% limiter you need click on the 'Interface Settings' tab, then on the right hand side double click and/or open your actuators tab. Up the top of the window you will see the limiter box, simply tick it to enable the 25% Limiter.
    hope this helps.
    Murray
  4. Muzza
    Muzza New Member
    Berney, you beat me by 5 minutes :)
  5. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    Thanks for the info but i thought that was only for test mode . I mean when you test the actuators. I was under the impression that the 25 % limit has to be enabled in the profile of the game we load?
    thanks for info so far
  6. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Once the limiter is enabled in the SCN5 plugin, It applies to all profiles being used. You can also use the Percent limiter within the profile but it is not necessary of the limiter is already enabled in the plugin.
  7. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    thanks a lot everyone, it is clear now
    that has to be done in interface setting/snc5serial
