24v 1000w 44A Switching Power Supply !!!!BARGAIN !!!!
Discussion in 'Marketspace - Marktplatz' started by SilentChill, Feb 6, 2019.
  1. SilentChill
    20,594Coins
  2. Gadget999
    12,035Coins
    are these a server power supply ? what are the large brackets on the front for ?
  3. SilentChill
    20,594Coins
    No they are high quality medical grade power supplies. Serious bit of kit I think
  4. BlazinH
    16,671Coins
    Not quite the deal it sounds like though when they what 50% more to ship them.
  5. SilentChill
    20,594Coins
    Free shipping to the UK though lol :grin:thumbs
  6. BlazinH
    16,671Coins
    Hmm, this is what their description states.
    Anyway glad your shipping was free :cool:.
  7. benkay
    benkay New Member
    6Coins
    Bargain...very nice.just ordered one!
  8. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Hi SilentChill,
    I have n.4 motors TRANSTECNO ECM240.240 24V 350W (please see file pdf with spec.) I use with sabertooth 2x32, 2 motors for each card.
    Actually I'm try to use SIMUKIT Power Supply 24V 1000W 40A output. 1 power supply for eache card and 2 motors.
    It seems that the power supplies do not supply enough current. I don't understand if because the motors require more than 40A that the power supply can supply or if the problem is the power supplies that supply less current than is declared. I have to try to measure the output current with the amperometric clamp.
    In your opinion, for my engines one power supply that you suggest in this thread is enough for each card and for two motors or it is better to use two power supplies in parallel (24V 88A total) for each card. Do I have to buy 2 or 4 so to not have problems with my engines? Furthermore, if I were to connect 2 of them in parallel I will have to adjust the output voltage to be exactly the same. Do the power supplies have a trim for voltage regulation?
    I thank you for your support
    gigi
  9. dddman
    dddman New Member Gold Contributor
    193Coins
    They are the output posts, pretty huge for "only" 44A
  10. wannabeaflyer2
    london uk
    8,345Coins
    Nice Find @SilentChill Fleabay truly can be your friend LOL
  11. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    @SilentChill are you happy with the power supplies? Would you still recommend them after having them?;)
  12. SilentChill
    20,594Coins
    I've still not upgraded my, its slow going at the moment :D
    I don't even know if they work I have not even powered the up yet
  13. My.stAr
    Engineer
    1,064Coins
    DC motor
    LOL, ok;)
    There is also one guy who said that his supply does only work up to 200 W :eek:
    No risk, no fun. I'll also order one:D
    Thank you for the link:thumbs
  14. SilentChill
    20,594Coins
    Hi dude, did you get this sorted I've only just seen it.
  15. gigi
    gigi Active Member
    917Coins
    2DOF, JRK, 4DOF
    Hallo Silentchill! I get n4 new (not used) of the psu you suggest in this thread but I have not yet mounted them because I believe I have solved my problems. for my project I initially planned 80mm levers ... too many and useless. Obviously a lever so long forced the engines to intense efforts that it was certainly able to withstand but that required many amps. It was enough to reduce the levers from 80 to 60 and subsequently to 45mm. the necessary torque has drastically lowered and consequently the amps thirst of my engines have also been lowered. so i am currently using simukit power supplies without problems. I was stupid, there was no reason to expect such long levers. My project does not need it. With 45mm levers it does everything it has to do, it is very very fast and also detailed. I'll post the link to the first video
    .... it is still everything to set but it is already fantastic. I have four new feeders boxed and I keep them in stock. I also had to face another problem, fortunately solved well. With its sabertooth 2x32 engines. The engine as images is very powerful and I immediately realized that the cards warmed up a lot ..... I measured 65 °. So I bought two heat sinks with 92mm fans that fit perfectly. Mounted the heat sink behind each board using the thermal paste .... result .... now the sched never go beyond the 32/35 ° even after hours of intense use. fantastic! .
  16. SilentChill
    20,594Coins
    Ahhh very good .
    Has anyone tried the PSU's yet lol
  17. gingercat
    gingercat New Member
    Software Engineer
    Nr Lancaster, UK
    131Coins
    DC motor, SimAxe, Arduino
    I grabbed one in case I ever get round to upgrading my wiper motors to 24v equivalents. All I can confirm is they do indeed output 24v, but haven't actually used them to power anything yet. Fans aren't all that quiet, but they're not much louder than the 12v HP server PSUs I've got (and aren't quite as whiny).
  18. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    I really like the simulator station
  19. My.stAr
    Engineer
    1,064Coins
    DC motor
    I finally tested the PSU.
    Aaaand... I don't have any voltage:mad: (measured with a multimeter and also connected the sabertooth to DEScribe)
    It is a new unit (I just messed around for some minutes).
    Can it be, that the the connectors are the cause?
    Interestingly, when I turn on the PSU, I can see a voltage increase in DEScribe, but it quickly decreases to 0 V
    :sos
  20. Anthony Morris
    Anthony Morris Member Gold Contributor
    Multi trade
    Essex UK
    38Coins
    Just so we know its not amps its volt amp ie you will not get 44amps if your voltage is 210v if you look at the label it will say 44amps at 240volts no clamp meter needed just calculate with your nominal voltage
