Bug i have an unhandled exception with simtools
Discussion in 'SimTools DIY Version' started by marlon, Feb 28, 2016.
  1. marlon
    marlon Active Member
    1,070Coins
    i dont know what to do
  2. marlon
    1,070Coins
  3. marlon
    1,070Coins
    153,890Coins
    +11,154 / 57 / -2
  5. eaorobbie
    20,503Coins
    ? How did the error happen , what were you doing ?
  6. yobuddy
    51,535Coins
    The error says you using the same network socket twice.
    Can I please see your interface setup? (pic's would be great)
    Are you using a 2 PC setup where you maybe set the IP addresses?
  7. marlon
    1,070Coins
  8. yobuddy
    51,535Coins
    follow what noorbeast posted above.
    Considering you have been able to run it before this error, something else has happened to the install.
  9. marlon
    1,070Coins
    still get the same error i tryed reinstalling
  10. yobuddy
    51,535Coins
    Run game engine as an admin.
  11. marlon
    1,070Coins
    i tryed unpatching and running as admin
  12. marlon
    1,070Coins
    live for speed game folder is not uninstalling
  13. yobuddy
    51,535Coins
    Patching is in Game Manger so I guess that is working for you?
    When you uninstalled SimTools did you answer yes to removing old files and settings?
  14. yobuddy
    51,535Coins
    The Live for Speed game itself is not part of SimTools, and therefore will not be uninstalled.
  15. marlon
    1,070Coins
    i tryed a system restore but that did not work
  16. noorbeast
    153,890Coins
    +11,154 / 57 / -2
    I think you need to start from scratch @marlon, it does sound like something is corrupted.
    Shutdown SimTools.
    Uninstall SimTools and say yes to removing old files.
    Check the SimTools folder has been deleted here, if it is still there then manually delete it: C:\Users\your_user_name\AppData\Local\
    Check the SimTools folder has been deleted here, if it is still there then manually delete it:C:\Program Files (x86)\
    Download a clean copy of SimTools from here: http://www.xsimulator.net/community/marketplace/categories/simtools.3/
    Reinstall SimTools.
    You will have to setup the Interface and Axis settings again for the SketchUp model you are using, see the pictures and instructions here: http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
  17. marlon
    1,070Coins
    i think it my frame works boken
  18. marlon
    1,070Coins
    it was my frameworks .net fixed it i used the clean up tool
  19. yobuddy
    51,535Coins
    @marlon,
    Great job buddy!
    Way to stick with it until you found your solution!
  20. yobuddy
    51,535Coins
    @marlon,
    Check out your coin count buddy!
    Have fun!
