X-Sim support for SCN5 actuators
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by yobuddy, Jul 18, 2008.
Thread Status:
Not open for further replies.
  1. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    The mechanical actuators-setup is the issue today. The DIY stepper controller lies ready in the drawer...
  2. egoexpress
    422Coins
    To me it seems pretty much like a ballscrew drive with AC motors. Where have you seen the belt transmission in a FD301?
  3. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    I mean more type of simulator (3 acutators). It would'n usable for Frex type (it would be long)
  4. egoexpress
    422Coins
    Hey Sirnoname, amazing result! :yippiee:
    The video is great!
    :cheerleader:
    Thank you!
    Christian
  5. yobuddy
    51,545Coins
    Great video Sirnoname!
    Thanks for the update, getting pretty excited :yippiee:
  6. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    :cheers: :cheers: :cheers:
    Let's celebrate...
    I want to start my tests next month... Migrate to X-Sim soon! 8)
    That is freedom... :mug1:
  7. egoexpress
    422Coins
    You've got it! :cheers:
    But let me say that we have to go on very slow and careful to a default setup, cause I dont want any actuator death due to wrong or too progressive settings.
    Regards
    Christian
  8. tronicgr
    tronicgr
    This is awesome news!!!! The video is great too! Congrats! :cheers: :dance1: :dance2: :yourock:
    About the RS485 converter... I used all of its features of the converter you mention on my USB_to_RS485 converter:
    post9152.html#p9152
    So I guess it will work too. I'll prepare a prototype of this USB converter and send it over to you to test it! :thbup:
    Best Regards, Thanos
  9. nordisch
    nordisch Member
    Germany, Hamburg/Lübeck
    61Coins
    A little step for an SCN ... But a big step for the community :hi:
    my gratulations
  10. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi Christian
    @ AD
    Well,if you are willing to share some ideas with us,go on i,ll appreciate that.
    Well i,am willing,have more ideas.
    When some one makes a new topic fore it , i will reply
    it,s better to keep this tread on topic i think.
    regards AD :thbup:
  11. RaceRay
    Hamburg, Germany
    23,884Coins
    Hi Martin,
    wirklich fantastische Resultate, die Du erzielt hast. Ist ein tolles Gefühl jeden Tag im Forum vorbeizuschauen, die kleinen Steps mitzuverfolgen und auf einmal wieder eine audiovisuelle Tech-presentation geliefert zu bekommen. Starke Leistung.
    Danke, Thanks, Merci Beaucoup, Grazie, Salut :cheers:
    Selbst die 80mm/sek sehen schon gewaltig aus. Ich glaub Chris hatte garnicht so unrecht damit wenn er meint, das die SCN einem bei Full-Speed das Rückgrat aus dem Kreuz rütteln :rofl:
    Also bei einer zukünftigen Sammelbestellung und weiteren Fortschritten bin ich schonmal dabei.
    Viele Grüße
    René
  12. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Don't worry...
    That is why I will wait 1 more month, for sw maturity.
    As I told you before... I already use only 5cm (from 10cm) of range to avoid damage to the actuator.
    I am planning to use 10cm only with FSX, which I believe has a much slower motion anyways... ;-)
    BTW, I need some help to understand which USB-485 interface to use, I want a shelf solution...
    Let me ask again, after all you learned so far, will this converter work with x-Sim?
    http://ekmmetering.com/EKM_Metering/Con ... pters.html
    Do you believe I will not have the 80mm/s speed limitation you had?
    I will be more than glad to write down a how to/DIY conversion of the SCM to a X-SCM (X-Sim Controlled Motion)... How you like that name? :lol:
    BUT, I need your guys support to make this right since the beginning.
    Cheers,
    Me
  13. tronicgr
    tronicgr
    I'm not sure if their circuits include auto RS485 switching, like Sinoname said: These converter are half duplex and can send OR receive, this is the SCN5 Termibus RS485.
    But I guess for 10 bucks for the simple serial port version its worth to try. In worst case you will have no communication between the SCN5 and the computer, no other harm can be happen... :headfullofmath:
    Thanos
  14. egoexpress
    422Coins
    I'm not sure what you're meaning.
    Its planned to make a SCN5 plugin, where you can adjust the speed, accelleration and more via sliders. Sure, you will be able to set them faster than 80mm/s.
    I am just saying that we have to be carfull, to prevent overdriving them to the limits with high speed.
    Regards
    Christian
  15. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I understood Noname had a speed limitation imposed by the RS485 interface, which didn't allow him to go faster... Or, did I read it wrong? :-(
    Thanks.
    Me
  16. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I was planning to use the USB solution.
    I believe that considering the shipping costs, it would be worth to buy two of them, instead of one than other one...
  17. egoexpress
    422Coins
    Yes, you did. The limitation is the max SCN5 update rate of 5-10ms. That means that the acutator is able to change direction just in a 5-10ms loop (rumble).
    The speed and accelleration will be adjustable the same way, as you are used from your current setup.
    Dont worry, it will be as fast as your SCM :D
    Regards
    Christian
  18. egoexpress
    422Coins
    I've ordered some of Thanos DIY usb>RS485 converter layouts from Heinz. I will assemble some for you guys, as soon as Thanos gives green light.
    Regards
    Christian
  19. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Thanks Ego... When I read it for the second time I got the impression to have wrongly understood it...
  20. tronicgr
    tronicgr
    Yes, I will give the green light as soon Sirnoname test it with SCN5 motor, and assure us that it works like the simple serial_to_RS485 converter he uses right now.
    Just to mention, that apart from the DIY_USB_to_RS485 PCB you will need to purchase a small FT232R breakout board from Sparkfun.
    I ordered two such FT232R breakout boards, and paid 22euro (including shipping expenses from USA). :thbup:
    Regards, Thanos
Thread Status:
