SIMULATOR 2DOF PROJECT WITCH ARDUINO UNO R3 Y MOTO MONSTER H-BRIDGE
Discussion in 'DIY Motion Simulator Projects' started by Pastrana, Jan 3, 2016.
  1. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Well first of all, sorry for the English, the translator is to use as my primary language is Spanish. I'm from Argentina, and a few months ago I decided to build my simulator 2dof movement. As we have a special economic policy, the materials are expensive for us for the conversion of the currency. 1 euro equals 15 pesos, plus the customs policy is a problem, so the sacrifice in the assembly of these projects. Materials for version 1.0 as I call it, were two potentiometers, two 12V motors dc windscreen a Toyota Hilux, "moto monster" brigde and h-R3 Arduino Uno, supply power pc 400 and the other software. Here the first tests.
    • Like Like x 5
  2. Pastrana
    Pastrana Member
    Argentina
    165Coins
    reserved
  3. Pastrana
    Pastrana Member
    Argentina
    165Coins
    After testing and checking will step to the assembly of the structure, structural pipe of 30x30mm for the seat base and 35x35mm for the estructura.Los restro engines uniball rod ends are connected by 12mm threaded rod with a 12mm by 450mm long. The engine cranks with 54mm long, and the motor shaft a system to move the potentiometers which are 10kohm linear, at the end has a rubber Cañito which serves to supply the imbalance shaft and acceded fuse in case of full turn by a bug in the software.
    https://www.youtube.com/watch?v=r0HMhuup0SU
  4. Pastrana
    Pastrana Member
    Argentina
    165Coins
    The seat pivot axis became a universal joint steering of a vehicle Ford Fiesta 96. And to prevent the seat rotate on its axis stabilizer bars are placed to fix the circular structure made of kneecaps travel and 8mm threaded rod 8mm to 30mm in length.
    The source is a Dell server 57amperes source server is recommended because of its cost and the quality of its components. 57 amps for two motors work too well.
    The electronics are composed of an Arduino Uno R3 Ebay China that cost 6 euros, always ask several more, and a bridge-h "Moto Monster" Chinese for 8 euros, it is recommended to ask more than three and that is so cheap manufactures come with failures, the test image below owed to the "moto-monster" before wiring or move forward in the project. In version 1.0 the Arduino was mounted with special software motomonster but then and in version 2.0 and present, and to work with simtools is wired by the draft SCM3. All this in a cabinet source obsolete pc.
    Then and now in version 2.0 limpioparabrisas place dc motors 12v Ford Taunus to be more robust and more powers than before. These recommend that are refrigerated, in this case by two 12v pc coolers.
    Now awaiting coins to purchase simtools plugins and make further progress on the project. Then add a third engine to pass 3DOF.
    151,596Coins
    +11,043 / 56 / -2
    [QUOTE="Now awaiting coins to purchase simtools plugins and make further progress on the project. Then add a third engine to pass 3DOF.[/QUOTE]
    You have enough coins, as per my earlier PM you can buy the week access to all plugins here: http://www.xsimulator.net/community/shop/
    I look forward to seeing you simulator running with SimTools, if you have any setup questions then the community members can help you out.
  6. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Bienvenido y felicitaciones!
    Subí un video una vez que lo tengas andando con Simtools.
    También de Argentina, San Isidro aca. :)
    Welcome and congrats on your sim!
    It would be nice to see a video of your sim working with simtools soon!
    I'm from Argentina too.
  7. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Ahí esta el video funcionando con simtools
    • Like Like x 5
  8. Pit
    30,482Coins
    Every time when this happens to new users it is a big pleasure to see that it works ;)
    • Agree Agree x 4
  9. Pastrana
    Pastrana Member
    Argentina
    165Coins
  10. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Thanks Pit, whether by little we are going to bring contributions to the community .
  11. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    123Coins
    Nice sims project!
  12. Pedro Pablo
    Pedro Pablo Active Member
    Software Developer
    Valparaiso, Chile
    599Coins
    Hey, nice project. Can you tell me exactly what motor are you using????
    Grettings from the other side of Los Andes :D
  13. spiroboy1
    spiroboy1 New Member
    611Coins
    olá Pastrana! eu sou brasileiro.
    Muito interessante Seu Projeto, gostaria de saber Como configurar gamemanager pará ELE reconhecer o arduino? Que configuracao voce usou? E hexadecimal? A mesma do racemat? rápido Você UO Alguém nenhum fórum pode me Ajudar?
  14. spiroboy1
    611Coins
    Pastrana hello! I am Brazilian.
    Very interesting your project, I am building my 2dof simulator engine windshields and Arduino motomonster.
    I downloaded the software tools Yes, it seems pretty simple, but I can not change the LFS game for Race Driver Grid. Can anyone help me with the SER setting? I wonder Setting gamemanager stop IT recognize the Arduino? Configuration that you used? And hexadecimal? Same as racemat (my Arduino this with the code of Racemat? You or Someone forum can help me?
    151,596Coins
    +11,043 / 56 / -2
    Yes, see my response here: http://www.xsimulator.net/community...ember-introduce-here.1737/page-126#post-96562
  16. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Felicitaciones desde Buenos Aires!
  17. diegjn
    diegjn New Member
    Argentina , Buenos Aires
    165Coins
    Muy bueno la verdad , soy de argentina tambien y me gustaria armar algo asi pero la veo complicada jaja , abrazo!
  18. Pedro Pablo
    Software Developer
    Valparaiso, Chile
    599Coins
    @diegjn Ensayo y error estimado, yo también quiero montarme un simulador y con suerte se trabajar en arduino, así que me espera un gran desafio :sos
    Así que a preguntar, al menos aqui estan dispuestos a ayudar (pero si sabes ingles, mejor, got it???)
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    good English is not required. just use google translate. post it with your native language. you will get a better response.
    Inglés bien no es necesario. sólo tiene que utilizar el traductor de google . publicar con su lengua materna. obtendrá una mejor respuesta.
  20. spiroboy1
    611Coins
    HELLO PEOPLE!!
    I am new to the forum, I set my X Motion with Arduino UNO and a controller Motomonster, I have a problem;
    everything works fine until I connect the G27, the software stops sending data to the Arduino after a few seconds, restart the machine and the same thing happens. With another simpler wheel everything works perfectly, so I have this problem with the G27, I have reinstalled the Arduino drives and G27 and nothing. Can someone help me? following pictures of my Xmotion.
