Driver motor
Discussion in 'Electronic and hardware generally' started by MotoGatto, Dec 31, 2015.
  1. MotoGatto
    MotoGatto New Member
    Torino
    450Coins
    good evening..
    I read in the faq's suggestion of using cards JRK ..
    being again I ask you, for a project with 2dof 24v engines what I could use as a motor driver ..
    I think that only jrk 12v ??
    thank you
    153,950Coins
    +11,159 / 57 / -2
  3. Pit
    30,510Coins
    short reply : VNH5019 and Ard Uno if less than 100W motors are used or Sabertooth 2x32 and Ard Mega.
  4. MotoGatto
    Torino
    450Coins
    thank you so much guys !!
    fast responses and excellent!
    for now I do have an idea about everything! Tomorrow I post measures and the project so as to have more help!
  5. MotoGatto
    Torino
    450Coins
    VNH It means it is a card that is already assembled?
    I looked at the link, but I have to ask a question perhaps stupid ..
    I 24v motors, motor driver must be 24v, one for motor ..ok ..
    but I do not understand Arduino ..
    because cards are always 12v .. Arduino does not need 24v, too?
    excuse my ignorance but I can not understand this thing
  6. Pit
    30,510Coins
    The Arduino is the controller and the VNH5019 the driver, you need both of them. The Arduino is powered by the USB cable (5V) and not by the psu.
  7. Pit
    30,510Coins
    for example
  8. MotoGatto
    Torino
    450Coins
    Thank you very much @Pit
    then..for my 2 motor 24v
    - n° 1 Arduino uno (now Arduino uno R3?)
    - n° 2 VNH5019 (each card one feeder?)
    ability to find connection scheme of Arduino and VNH5019?
    thanks again and big greetings
  9. Pit
    30,510Coins
    please can you post any specs of the 24V motor?
  10. MotoGatto
    Torino
    450Coins
    12/24v
    30/50w
    64 giri al minuto (24v)
    coppia 15 Nm
    I hope it's enough
    this is the information that I have given
  11. Pit
    30,510Coins
    IMO you should be fine with only one VNH5019 h-bridge for both motors. https://www.pololu.com/product/2507. You need (as already mentioned) an Ard like the Arduino Uno R3, either original or a Chinese clone which works in most cases without any issues. All Ard related information like codes and wiring you will find in the FAQ section. If you will struggle with the details we can help, but we do not help if users do not read and learn from what we tried to collect in the FAQ section ;) Good luck with your project.
  12. Pit
    30,510Coins
    BTW these not really strong motors are only suggested for a seat mover or shaker but not for a motion platform.
  13. MotoGatto
    Torino
    450Coins
    Thanks again
    Your help was crucial for me..In fact I was following faq to best achieve my project
    I did not get it well ..
    I can not create a platform with these engines?
  14. Pit
    30,510Coins
    I wouldn't, nevertheless you can try it, even if you build a very well balanced motion platform do not expect a big "impact" while driving over curbs. The motors are simply too weak. You can implement additional springs or gas springs but IMO stronger motors are cheaper at least than all the tinkering.
  15. MotoGatto
    Torino
    450Coins
    I thought you were better than classic wiper motors ..
    I'm disappointed for these engines!
    IMO engines what they are?
  16. Pit
    30,510Coins
    why do you want to build a motion platform? What do you prefer, racing or flying?
  17. MotoGatto
    Torino
    450Coins
    I wanted to build a platform MDF 19MM 120x90
    where I can then install a structure previously purchased (commercial)
    built for racing
  18. Pit
    30,510Coins
    racing = seat mover = best relationship of immersion and cost.
  19. Pit
    30,510Coins
    Can you upload a picture of your "commercial structure"? :)
  20. MotoGatto
    Torino
    450Coins
    perfect..comprehensive answer;)
    We hope it works ..:(
    I already have "unfortunately" the commercial structure for 3 years:mad:, now that I know you wanted to do this project ..
