Showroom CXC inspired design!
  1. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks!
  2. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Help!, i am almost ready to test my sim and i encounter an issue trying to "Patch" iRacing, anyone knows how to fix this! Or i do not need to Patch a game?
    See picture:
    153,890Coins
    +11,154 / 57 / -2
  4. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    153,890Coins
    +11,154 / 57 / -2
    SimTools runs fine with Win 10.
    Can you confirm that you completely closed down SimTools, right clicked on the launch icons and chose to run as Administrator.
    I can't see the full folder you are trying to patch to in the image. Is that the actual game install folder for iRacing that contains the iRacing executable?
  6. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    You need to pick your game folder not the one under "My Documents"
    So for me I use "C:\Program Files (x86)\iRacing"
    If you have installed it in a different folder then you want to pick the folder that has the iRacing EXE files in it, not the settings folder under my docs.
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    You are correct! That worked thanks!
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Everyone, the motors are Awesome! I Started with 20% and they were so shaky that i had to drop then to 7% this is more manageable also the 5k potentiometer work great! i will take pictures soon.
    Thank you all for all your help!
    Best wishes.
  9. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I am just wondering about few observations on the Software, for same reason when I start the game the seat shakes! a few times and then stops with out me moving the car.
    is this normal?
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Also is there a manual for the software? I am trying to learn what each Axis do? Surge, Sway, Roll, Yaw, Pitch, Heavy.
    The reason I am asking is because I notice I do not feel the gravity change on turns, also the grass or gravel.
    let me know?
    153,890Coins
    +11,154 / 57 / -2
    It could be depending on the game and interface settings.
  12. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    it does it when I go to the Pit after a crash or just simply when I start the race again.
    so the Game send the signal to the Axis to shake? or maybe that is how it calibrates?
  13. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    you are correct! I just absorb the car, when I start the game or I get a new car I notice in the screen the car does shake also so it is doing what the game is doing.
    Thanks.
    153,890Coins
    +11,154 / 57 / -2
    The Startup-Output in the SimTools game engine defines the initial sim position when started, but if the game has the car anywhere else and sends data accordingly then the sim will move.
  15. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Do you know what Surge, Sway, Roll, Yaw, Pitch and Heavy do?
  16. noorbeast
    153,890Coins
    +11,154 / 57 / -2
  17. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
  18. noorbeast
    153,890Coins
    +11,154 / 57 / -2
    Sway will make you feel like you are going around a corner, it actually moves the seat away from the direction of the corner.
    Surge feels like acceleration and braking.
    Heave is for bumps.
    Pitch is up and down hills.
    Roll is for things like curbs and embankments and is opposite of sway.
    When creating a motion profile you set them up one by one and then mix them together and tweak the results: http://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks! I will do that, Question how i can tell witch Axi is left or right? Simtools called it axi and ComPort but in motion i can not tell left or right?
    153,890Coins
    +11,154 / 57 / -2
    Checking or un-checking the "Dir" box determines which way an axis goes.
    Normally surge would either have both the "Dir" boxes checked or unchecked, depending on your motor settings, and the sway "Dir" settings are normally the opposite of roll, one checked and one unchecked. You can just take a guess and test in game, which is easy to do, or check out the official description here: http://www.xsimulator.net/co-ordinate-system/
    To get a better idea of all aspects of SimTools take a look through the official documentation: http://www.xsimulator.net/simtools-complete-documentation/
