Frex SimWheel
Discussion in 'Off Topic - All other stuff here' started by matt_tighe, Aug 9, 2008.
  1. tronicgr
    tronicgr
    I found what is the part with the orange gear ring, that is connected right after the motor shaft...
    http://www.nbk1560.com/couplicon/produc ... ex_en.html
    Its a Zero Backlash, Soft Flexible Coupling !!!!!! :lol:
    The question that remains is how it connects to the main screw...
    Thanos
  2. matt_tighe
    matt_tighe New Member
    1Coins
    Great find Tronic! How did you work that one out.
    So the reduction in backlash is just caused by having a flexible coupling?
    We can't see where it's transmitting the drive to yet until someone gives a clearer pic.
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I think I've figured it out.
    The tiny motor on the back is imho just for cooling purposes! :D
    They seem to use a linear motor system like those from SEW Eurodrives! These are motors with massive torque, are fast as hell, are silent and have no rotational parts (they call it motor, but it is more a magnetic rail, than a conventional motor).
    Such motors are used for example in the carmikaze simulator!
    playtime 2:48
    http://www.youtube.com/watch?v=r97E_QvCoQs
    It's likely that such a linear motor powers the slide on the rail, I think.
    Otherwise I couldnt explain how they could be able to achieve that much torque.
    Regards
    Christian
    http://en.wikipedia.org/wiki/Linear_motor
  4. tronicgr
    tronicgr
    It could be a linear motor system on the bottom, but it would have to be very compact and its another thing... I don't see any cables coming out of the bottom, where it should be this motor!
    (another enhanced photo of the motor...)
    Thanos
  5. egoexpress
    421Coins
    good point :D
    Regards
    Christian
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hi
    they are not the only one.
  7. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    If you think about it every thing speaks to my version with two screws :D Soft Flexible Coupling is connect to smaller screw. If you look at picture there is another bearing. Gearing is do by difference in pitches and diameters of screws. We cant just see (i hope)
    EDIT: Linear motor wuld be faar more expensive, better way is BLDC motor.
    EDIT2: I want this baby http://www.mmspektrum.com/multimedia/im ... 25_big.jpg :D that would be FF :DD (most powerful has around 20 000 Nm from 0 rpm )
  8. egoexpress
    421Coins
    That system is, from what I see, more a rumbling system, than Force Feedback device.
    Do you have a link to the manufacturer?
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
  10. egoexpress
    421Coins
    Well, cyberspace, the company who invented/sold the RnR promoted it as Force-Feedback device as well, though it was joystick controlled in the end.
    But the wheel you linked has Force-Feedback obviously. It can be seen in this video.
    Regards
    Christian
  11. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hy.
    Ye you are a head of me with the video.
    They made it far more easy than Frex.
    Regards Ad
  12. egoexpress
    421Coins
    But their system does not support more than ~280° whell rotation, while the Frex one is multiturn.
    Not really comparable.
    But for those who are satisfied with restricted wheel rotation, like for F1 or Dragsters, it will do the job.
  13. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hi Ego
    It isn,t difficult to give it adjustable steer clearence.
    one little gearwheel on the steershaft with 10 tooth for example and a 32 tooth for the end locks
    when the big wheel have allso 32 holes you can put two pins in it for the lock
    and it,s easy to adjust the clearence by putting the pins in different holes.
    regards Ad
  14. tronicgr
    tronicgr
    Why don't we concentrate on what ShigeT told, when started designing it:
    (Edited a little the sentence in red to make it more meaningful)
    Then, what way is left yet? And small enough to be able to hide from the photos taken from clarkii2??
    Thanos
  15. egoexpress
    421Coins
    In case it isnt a linear motor, then it is made like Mambo suggested.
    A second spindle that drives the slide, which is connected to the coupling.
    Regards
    Christian
  16. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hi
    When i look at the picters i still don,t get it ,with the second shaft
    I see a coupler and bearing, but a smaller shaft is useless ore it must be for avoiding tilting the slider.
    But the roller shaft is so big the zero backlash nut will avoid that
    I see no function for a second shaft and makes it complecated for nothing.
    regards Ad
  17. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Small shaft dont avoid slider, in slider there is another nut witch is connect to big nut when motor spin, small nut slide (for example) right and big nut also move right. Movment of big nut makes big screw rotates. Bigscrew has high pitch (a gess about 80 mm per one rotation -it looks like multi screw-thread ) so thats mean if you turn whelle one turn nut make 80 mm travel and smaller screw must rotate more (if it has pitch 5 mm then must rotate 16x more) thats make the transmission.
  18. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,798Coins
    Hi Mambo.
    I know what you mean, but you can do this all without the second shaft ,only with the big shaft.
    why put a second shaft in it.
    regards Ad
  19. tronicgr
    tronicgr
    Just to mention that if second shaft/screw is used, it has to have the same pitch, otherwise one nut (high pitch) will try to move faster than the other nut (small pitch)!!!!
    It must be another way of coupling the motor to the big screw!
    Thanos
    Btw, I noticed that while the is a bearing on the left (below the big screw shaft), there in no bearing on the right side end!! This eliminates I suppose the possibility for second small screw shaft!
  20. matt_tighe
    1Coins
    the idea of a second shaft is cool but.
    There's no space for it in the pictures, it would have to be inside the shuttle at the bottom which it isn't cox the motor isn't aligned there.
    As tronicgr said you would not be able to turn the wheel as the small screw couldn't be back driven. This would mean you'd need a torque sensor so you could control ALL movement from the motor in response to torque on the wheel.
    (I love that idea but doubt it's being used here?)
    Whatever the answer is, it's only about the size of a large matchbox and is hidden from view due to the angle of those pictures... Connected to the right side of the flexi coupling and going into some sort of bearing in the ali block.
    Shige you evil genius... What have you done?!?!?
