  1. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
  2. lcturkey
    lcturkey Member
    163Coins
    @SilentChill thanks for the code. Can you Show me your interface details ? I saved like that but when I click to NL2 the fan start to turn at full speed and it doesnt stop even I close the simulator. I can read data from Dash1
    thanks for the answer
  3. SilentChill
    20,592Coins
    All the details in the first post @Icturkey nothing changed here
  4. lcturkey
    lcturkey Member
    163Coins
    what is the settings below screenshot ? ( Below Comport )
    Do I need to write,
    Output - Bit Range
    Startup-Output
    Interface-Output
    Shutdown - Output
    and Pocket Rates ?
    Thank you
  5. SilentChill
    20,592Coins
    Seriously everything is there in the first post . Nothing else to add just copy what I have put in the screen grabs
  6. lcturkey
    lcturkey Member
    163Coins
    it doesnt save the settings without writing,
    Output - Bit Range
    Startup-Output
    Interface-Output
    Shutdown - Output
  7. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    @lcturkey you are configuring the wrong interface(game engine).you need to configure the right one inside the game dash app. dont have this so i may be wrong but i think i am not @SilentChill will tell if i am wrong
  8. SilentChill
    20,592Coins
    yeah i presumed he is using gamedash and not simtools game engine.
    You need to create a preset in the settings have you tride that @icturkey
  9. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    hello
    is it possible to use two arduinos
    one for gamedash +tm3816
    and one for gameshash and wind control
    how do you set two different ports in game dash??
    i am already using one arduino + Tm3816
    thanks
  10. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    as far as I know there is only one Arduino supported via Gamedash.
    For more outputpins you can use Port expander or an Arduino Mega. But whre is the Problem using an Arduino for Wind and Tm1638?
    It will have enough outputs for both.
  11. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    thanks Tombo,
    Frankly i did not think about that.
    i dont know much about programming arduino.
    can we upload two different codes in one single arduino. And both codes would be functional at the same time via one port?
    i am not sure
  12. tombo
    tombo Active Member
    2,443Coins
    DC motor, Arduino
    You need to combine the two seperate codes to one single code.
    Most will be copy and paste.
    If the two sketches are small enough to fit on the atmega 328 I see no problem.
    Did you have both codes you want to use avalibe? If you like, you can write me a pm and I'll help you combining the codes.
  13. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    I expect I am being a bit dense here but how do you get to the Command Editor?
  14. jangomoose
    jangomoose Member
    Hobart, Australia
    784Coins
    Cancel my last. Doh!
    • Funny Funny x 2
  15. Romain Seignour
    Romain Seignour Member
    - 115Coins
    Hello @SilentChill !!
    i'm follow your post with insistance but when i download your code arduino arduino ide say is not possible to open this !
    is possible to paste directly the code arduino in this suite
    thank's for your great work !!
  16. Romain Seignour
    - 115Coins
    i don't understand why i have just 0.33v in out pin for my fan i need help for the code and the information with this
    ROUND 0
    PAD 3 0
    thank's for your help
  17. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    I am trying to set up a wind simulator like in your post but I am having a little bit of trouble getting it working.
    I have everything hooked up and @SilentChill code loaded on to the Arduino and the GameDash settings as posted on the first page but I can't get the fan to react to the speed properly.
    All I can get is the fan spinning slowly.
    I hooked my multimeter up to the second motor port so I could see what was going on.
    Before I start the game I am getting 1.84v constant.
    Then as soon as the game launches it goes up to 3.79v and it will stay at that voltage until I re-upload the code to the Arduino
    If you have any ideas they would be greatly appreciated.
  18. SilentChill
    20,592Coins
  19. Avenga76
    Network Engineer
    3,261Coins
    I have tried it with iRacing and rFactor 2
  20. SilentChill
    20,592Coins
    Have you tried to change the math value as the dash data for speed is setup for nolimits2 .
