value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    No problem, it happened to someone before and to me too, so I've thought it could be your problem.
    Maybe @value1 can edit default Min/Max values and include it next plugin updates. Surge and Sway are set with 20, it's pretty big number so people don't feel that motion. Maybe set it to 7 or 10, just for that initial motion feel and people would not think that there is no motion at all or that something is wrong.
    Although, the first thing to do is capturing Min/Max, seems that people sometimes forget that..
  2. PatrickPro
    PatrickPro New Member
    294Coins
    2DOF, SCN5, SCN6, 6DOF
    Yes you're right. I capture the min and max and found +- 3.8 for surge and sway (build 930) , when motion is too quick i reduce the main level to 80-90% and it's pretty good. I rediscover my simulators with Simtools!!! Easy to use and doing tuning for the games is very simple. Numbers of games plugins are incredible! Thanks for all of the developpers!!!
  3. Nick Moxley
    Cant seem to figure out what install Directory will work, Any tips ?
  4. Nick Moxley
    Still no go, what am i doing wrong guys ? I did notice the original install path it choose was under Users/MyUsername/Documents which i felt was strange so i changed it to a standard C drive folder i created. That couldn't possibly be the cause i don think,
    When trying to patch it, iF i choose the "what i would think to be the install dir" it accepts the path at first but doesn't actually patch it.
  5. value1
    14,240Coins
    Should be like c:\games\rfactor2
  6. Nick Moxley
    thats exactly where i put it, but the first install like is said it wanted to put it in under my username, then documents....Installing again and it wants the Normal C:\ folder
  7. Nick Moxley
    It asks me "would you like to patch game for motion" i select yes and it says "game did not patch?"
  8. Nick Moxley
    Neither Install Dir will work, under X86 program files or the folder under username/documents. What the F is going on here.
  9. value1
    14,240Coins
    Did you try to run GameManager in Admin mode?
  10. Nick Moxley
    U are the MAN with the MASTER plan Value1. THANK You that worked. Tip officially stored in the memory vault for next time, THANK YOU THANK YOU THANK YOU buddy.
  11. Nick Moxley
    maybe you can help me again Value1, IN the video option's under resolution its listed it in .32 bit Not 64.......any tips....I dont understand how to FORCE the game to run in .64 i see the blip you have about refering to the forum for details but they dont give much, just says "Experimental 64 Bit builds added. Manual rename of 64 bit executables to 32 bit names required so the launcher can successfully start 64 bit "
  12. value1
    14,240Coins
    rFactor (since build 798) runs automatically x64 mode if possible unless you force it in the Launcher (Launch rFactor.exe)
  13. Nick Moxley
    thats kinda what i figured when i seen that option in the launcher, but why does it say 32 bit in the Video options. ? thats what got me curious.
    PS your expired. :p
  14. value1
    14,240Coins
    Fixed :D
    Isn't that the colour depth? So there is nothing more than 32 bit?
  15. Nick Moxley
    Nope Only show's 32 bit, YES im on a 64 machine. ;)
  16. value1
    14,240Coins
    Fine, but even on a 64 bit machine your colour depth is 32 bit max.
  17. Nick Moxley
    well you learn something new every day, Lol well multiple thing's today thanks to you Value1. :thumbs
    The other main thing i learned today is that I really Do NOT like rF2, had a couple 2-3 hour session's so far and for the life of me cant get ANYTHING close to what i have in AC for profiles, Tried Multiple cars/tracks, Modded or ISI content and honestly, it just Didn't do it for me. the Heave/Sway/Surge spikes off road are rather annoying and overall i think I have been Tainted by AC's laser scans, the detail in the surface alone is 100X what ive felt from any other game. Sorry ISI :(
  18. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Hello guys. I use last one plugin, but I have issues as someone in the beginning of this thread. At the start is great, but leater after some time (aprox 30 min) my rig moves in random directions. Even if I go to the pit by pressinh Esc strange moves appear for few seconds more. After I quit RF2 Windows gives me Microsoft . NET error - system.outofmemory exeption
    Code:
    System.OutOfMemoryException: Zgłoszono wyjątek typu 'System.OutOfMemoryException'.
       w System.Diagnostics.NtProcessInfoHelper.GetProcessInfos(IntPtr dataPtr)
       w System.Diagnostics.NtProcessInfoHelper.GetProcessInfos()
       w System.Diagnostics.ProcessManager.GetProcessInfos(String machineName)
       w System.Diagnostics.Process.GetProcesses(String machineName)
       w System.Diagnostics.Process.GetProcesses()
       w SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
       w System.Windows.Forms.Timer.OnTick(EventArgs e)
       w System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Zestawy załadowane **************
    mscorlib
        Wersja zestawu: 4.0.0.0
        Wersja Win32: 4.0.30319.18063 built by: FX45RTMGDR
        Wersja zestawu: 0.1.3.0
        Wersja Win32: 0.1.3.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    Microsoft.VisualBasic
        Wersja zestawu: 10.0.0.0
        Wersja Win32: 11.0.50709.17929 built by: FX45RTMREL
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Wersja Win32: 4.0.30319.34238 built by: FX452RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        Wersja Win32: 4.0.30319.17929 built by: FX45RTMREL
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        Wersja Win32: 4.0.30319.34251 built by: FX452RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        Wersja Win32: 4.0.30319.34270 built by: FX452RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
        Wersja Win32: 4.0.30319.34245 built by: FX452RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
        Wersja Win32: 4.0.30319.18060 built by: FX45RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        Wersja Win32: 4.0.30319.34234 built by: FX452RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PluginAPI
        Wersja zestawu: 1.0.0.0
        Wersja Win32: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    AssettoCorsaEA_Plugin
        Wersja zestawu: 3.0.6.0
        Wersja Win32: 3.0.6.0
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/AssettoCorsaEA_Plugin.dll
    DirtRally_Plugin
        Wersja zestawu: 1.0.4.0
        Wersja Win32: 1.0.4.0
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/DirtRally_Plugin.dll
    iRacing_Plugin
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/iRacing_Plugin.dll
    LiveForSpeed_Plugin
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/LiveForSpeed_Plugin.dll
    pCARS_Plugin
        Wersja zestawu: 3.0.6.2
        Wersja Win32: 3.0.6.2
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/pCARS_Plugin.dll
    RaceRoomRacingExperience_Plugin
        Wersja zestawu: 3.0.0.5
        Wersja Win32: 3.0.0.5
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/RaceRoomRacingExperience_Plugin.dll
    rFactor2_Plugin
        Wersja zestawu: 3.0.3.4
        Wersja Win32: 3.0.3.4
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/rFactor2_Plugin.dll
    RichardBurnsRally_Plugin
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/RichardBurnsRally_Plugin.dll
    WarThunder_Plugin
        Wersja zestawu: 1.49.8.22
        Wersja Win32: 1.49.8.22
        CodeBase: file:///C:/Users/Gigus/AppData/Local/SimTools/GamePlugins/WarThunder_Plugin.dll
    mscorlib.resources
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/mscorlib.resources.dll
    Microsoft.GeneratedCode
    System.Core.resources
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Core.resources.dll
    System.Windows.Forms.resources
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_pl_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** Debugowanie w trybie JIT **************
    Aby włączyć debugowanie w trybie just in time (JIT), plik .config tej
    aplikacji lub komputera (machine.config) musi mieć
    wartość jitDebugging ustawioną w sekcji system.windows.forms.
    Aplikacja musi być również skompilowana z włączonym
    debugowaniem.
    Na przykład:
    <configuration>
    </configuration>
    My other sims like AC or pcars works OK. Help please ;)
    153,908Coins
    +11,154 / 57 / -2
    @lee1970 tracked a similar problem down to out of date drivers for a USB chipset: http://www.xsimulator.net/community/threads/out-of-memory-error.5324/
  20. gorzasty
    Poland, Wrocław
    1,060Coins
    thx @noorbeast. I installed up to date usb drivers and now i don't have any NET framework errors (maybe that have happend onece) but still have problems with strange platform movement after some time of playing. At he start everything is working gr8, but after 1h my platform moves randomly ;/ I need to close GameManager and GameEngine, start it again and I have another 1h of good playing. But in the next week I have 70min race at IRG-wrold and I really like to use my platform but I'm afraid that could kill me on the road after some time ;) No problems in any other sim.
