2DOF compact race / flight with Oculus Rift
Discussion in 'DIY Motion Simulator Projects' started by reko19, Jan 9, 2015.
  1. noorbeast
    152,603Coins
    +11,087 / 56 / -2
  2. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    thank you or the references @noorbeast
    so if my lever is 4", motor is 75RPM, linear speed is 2.8 feet per second which seems to be more than enough?
    152,603Coins
    +11,087 / 56 / -2
    It is actually more a question of what it takes to move something at what speed, and design affects the outcome. The general community rule of thumb approach is to run 40-60mm CTC on reasonably powerful DC motors and you will be in the ball park. But you did ask so here goes!
    I will use these motors as the basis for the example: https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    The linear velocity is how fast the arm moves for a given CTC. You can divide the torque by the CTC to calculate Newtons. Note the outcome is a trade off between speed and force.
    So a 40mm CTC at 180 rpm the linear velocity is 0.753984 m/s with 500 Newtons. A 50mm CTC at 180 rpm the linear velocity is 0.94248 m/s with 400 Newtons. A 80mm CTC at 180 rpm the linear velocity is 1.507968 m/s with 250 Newtons.
    You can then take the known Newton for a given CTC, the distance from the motor to the pivot point and the angle used. Run that through the calculator gives you the magnitude of the torque that is possible. Again the angle affects the outcome.
    If 250 Newtons is applied 600mm from the pivot at a 90 degree angle then the magnitude of the torque is 150
    If 250 Newtons is applied 600mm from the pivot at a 30 degree angle then the magnitude of the torque is 74.99999999999998
    • Useful Useful x 2
  4. reko19
    electrical engineer
    usa
    38Coins
    @noorbeast thank you for the very detailed explanation. i will stick with 60 mm CTC with some additional pre-drilled holes to give me some range to play with since it is hard to tell what is the best torque and speed for the application
  5. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    i wish there were more ratings to give ,
    thanks for taking the time to provide the info.
  6. reko19
    electrical engineer
    usa
    38Coins
    You guys are juts a bunch of troublemakers :) I was happy with my 2DOF+drift until I saw a thread from Boomslangnz 2 Dof Motion Sim Retrofit. Of course now I am thinking that adding a surge might not be a bad idea. It is a lot easier to incorporate it into the design now instead of trying to retrofit later. The problem is I am over my budget and this will easily add $300. So a couple of questions. I am planning to get 25:1 motor for this instead of 50:1 used for my other three DOF. I don't think I need as much force for surge and the eBay seller I bought them from no longer available. ANd would this be OK for the linear bearings, they are quite pricey.
    http://www.ebay.com/itm/141626670720?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    thanks guys
    152,603Coins
    +11,087 / 56 / -2
  8. reko19
    electrical engineer
    usa
    38Coins
    i know, this is how i got the idea. what is the general consensus, is surge worth the trouble or am i overcomplicating things?
    152,603Coins
    +11,087 / 56 / -2
    I don't know about consensus but I am guessing it is a bit like those who implement drift, once they have done it there is noting but positive reports. Still, surge is implemented far less often. Does it complicate things, yep, without a doubt.
  10. Boomslangnz
    4,172Coins
    sorry! haha
    Not too many seem to add surge to be honest but I thought it looked cool and would definitely add to the sim. The linear rails aren't really cheap but they seem to work really well, I actually am using the SBR30UU ones myself however the SBR16's may be more then enough I just didn't know what they could handle and it wasn't too much more expensive for the bigger. Depending on your design you may not need that long rails either, my rails are 880mm long in total but I am only using 320mm movement in total of that which I feel confident will be plenty so depending on your design you could drop the length which saves in cost! Yes im using 25:1 motors and considering I can move it back and forth with a single finger with ease then im sure it will work fine. As for if its worth it? Ill let you know once its running soon but I asked the question in the previous few weeks and everyone who had it said yes...its worth it. Apart from noorbeast and his linear rail design of moving pedals etc I think im the only one to try a linear rail for surge in this way but you could also try a similar way using castor wheels or even roller blade wheels or anything of the such which could be a cheaper design for a similar result. Its never too late to look at it later if needed anyway
  11. reko19
    electrical engineer
    usa
    38Coins
    Yes, you are the troublemaker who planted this idea in my head :). I already welded together a separate subframe for the surge. I think I will move on to the seat frame at this point to see how you like yours and if it is worth it to incorporate this into the sim. Most likely will use SBR16th as they should mount nicely to my 1.5"x1.5" square tubing I used for the frame.
  12. reko19
    electrical engineer
    usa
    38Coins
    Could someone tell be the difference between V1, V1.5, and upcoming V2 of Fanatec Clubsport Wheelbase? V2 is not even available yet, but by the time I am done I am certain it'll be out. I am considering buying a used one to save a few hundred dollars, not sure if this is a good idea or not. Thanks.
  13. noorbeast
    152,603Coins
    +11,087 / 56 / -2
    The V2 has a better motor and cooling, so is a bit tougher.
    I am not sure what is classified as V1.5, I know Fanatec made V1.5 shifters but am not sure there is an official CSW.
    In Australia at least you can actually buy a CSW V2 if your pockets are deep enough, as you also have to buy a wheel seperately: http://www.pagnianimports.com.au/fanatec-clubsport-wheel-australia.html
    I have the CSW V1 and BMW and F1 wheels and are happy with them, they are good quality and feel solid in use, but I am not a hard core sim racer.
  14. reko19
    electrical engineer
    usa
    38Coins
    i could get used V1 for half of that, that is a lot of dough
    152,603Coins
    +11,087 / 56 / -2
    Top end wheels are very expensive. If you really want to give yourself a fright have a look at the price tag for the Accuforce, which some members here do run: http://simxperience.com/products/accessories/accuforcesteering/accuforcepro.aspx
    You will need to determine what price point suits you and what options you have for that. A downside for second hand things like wheels is that you never know how hard a life they have had. That said one of your options could be a second hand CSW v1 and a future engine upgrade kit for it at some point. I can't remember who but one community member was going down the CSW V1 mod path.
  16. reko19
    electrical engineer
    usa
    38Coins
    Some progress to report. Lower frame is completed. Provisions for surge and traction loss.
    IMG_4525.JPG IMG_4519.JPG IMG_4523.JPG IMG_4524.JPG IMG_4522.JPG IMG_4515.JPG IMG_4514.JPG IMG_4506.JPG IMG_4508.JPG IMG_4511.JPG IMG_4512.JPG IMG_4513.JPG IMG_4517.JPG IMG_4520.JPG IMG_4521.JPG
    • Like Like x 5
    152,603Coins
    +11,087 / 56 / -2
    Thanks for the build update, you have been busy.
    How do the ball rollers for drift hold up under load, they look pretty smooth unloaded?
  18. reko19
    electrical engineer
    usa
    38Coins
    each is rated for 110lbs, very smooth. if anything they are more quiet under load.
  19. Sebj
    Sebj Active Member
    Canada
    492Coins
    V1 - 5.2 NM
    V1.5 - 5.2NM, improved motors to prevent fade, updated encoder (original was prone to centering issues), updated internal ribbon cable (V1 tended to rip)
    V2 - 7 NM, updated internals and look
  20. reko19
    electrical engineer
    usa
    38Coins
    thank you
