Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. Pit
    30,510Coins
    the second layer is finished. Better photos will be taken later.
    • Like Like x 9
    153,956Coins
    +11,160 / 57 / -2
    It is going to be a massive beast once it is all back together, can't wait to see it in action!
  3. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Me 3 ...
  4. Pit
    30,510Coins
    There must be order...
    BTW surge and sway has been already tested, the concept of using rails and gear racks was a success. Now I will assemble all the parts and - the trickiest part - to fix the projectors on the tables. Meanwhile I am optimizing the moves and when all is finished and assembled (and not until then) I will upload a video. But I do not make empty promises if I say the effort was worth the trouble.
    20150901_230152.jpg 20150901_230233.jpg 20150901_230249.jpg 20150901_230259.jpg
    • Like Like x 7
  5. Pit
    30,510Coins
    piggyback...
    • Like Like x 15
    • Winner Winner x 3
  6. RacingMat
    21,082Coins
    OMG! A godzillamulator!
    • Funny Funny x 8
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    too cool gj
  8. WowaDriver
    WowaDriver Waldemar Jost
    Bachelor of Science and Engineering
    Hannover
    1,127Coins
    looks amazing! Its a really individual monster!
  9. hooshang
    hooshang Active Member
    275Coins
    Hi @Pit
    this is the "Pit made" machine:thumbs
  10. Pit
    30,510Coins
    I am struggling with the projector stand, I have to save weight but at the same time I have to avoid any "mini vibrations", I did already a projector stand which failed due to too much vibrations. The model taken in the picture shows you a test unit (build 2.1 ;) ) The final is expected somewhere around build 18 or so...*sigh*
    153,956Coins
    +11,160 / 57 / -2
    It may be easier to build a moving motion system for the cameras and mount it seperate on the roof than it would be to try and eliminate vibration with the sort of motion you run @Pit.
  12. Mmcool
    Mmcool Member
    USA
    1,174Coins
  13. Pit
    30,510Coins
    Thank you both for the suggestions. Unfortunately the projectors have to be placed over the seat and between the seat and the ceiling I have only a few centimeter left. I am experimenting and already build 2 is promising a good result. Today the stand will be reinforced, the evening I will report how it works (or not).
  14. Pit
    30,510Coins
    Build 4 - and it works. I have only very small interferences, and only if I push hard against the rig. I am using rubber buffer.
  15. SilentChill
    20,601Coins
    Wow what a beast !!!
  16. speedy
    Alexandria , Egypt
    7,948Coins
    Hi @Pit ...
    Regarding this video how you used the projector before ...
    So, you may use a slightly over head shelf " crew nest" that hosts the projector ...
    Then mount it to a main mast long enough above your head like the pirate ships :) that use log robes for support ...
    Lightweight firmly stand still and easy to achieve concept ...
    Or ... use the high tension transmission lines tower triangles design to achieve such concept ... plus maybe using some PVC pipes .
  17. Pit
    30,510Coins
    @speedy thanks so much for your thoughts. It sounds crazy but I have (had) to find a mix between stability and flexing - meaning an "antiflex" stand. The layers are build by using wood - a material which likes to flex. While the big forces are no problem, when I was releasing the clutch pedal in a very fast and aggressive way or shifting very hard the small vibrations (jitter) which have occurred have been very annoying. I think I tinkered a reasonable solution now, probably could be better but my hands are demolished by bashing the rig all the time doing the vibration check ;)
  18. Blame73
    Blame73 Well-Known Member
    8,314Coins
    Waiting for videos here :popcorn:cheers
  19. SilentChill
    20,601Coins
    :popcorn:popcorn:popcorn:popcorn
  20. Pit
    30,510Coins
    Everyone has his cross to bear so the mine is I am a lousy and incompetent guy when I have to meter. After some really catastrophic actions while measuring (often I did it twice because it was too short or shorter than too short) today I added the left screen to the rig and noticed when I roll the rig to the left and back side, the screen touches the wall... :( I have to turn the rig and to push it a little forward but this monster weights 200KG or more so how to move it will be my big next question for the next days...Anyway I am very happy that I have no carpet ;)
