Help choosing the right kind of 2dof for me.
Discussion in 'DIY Motion Simulator Projects' started by mariano68, Apr 26, 2015.
  1. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Thanks very much guys!
    @mazak515, it takes time to understand you but once I get the idea, you are a great help! Thank you!:)
    Done, and thanks to this test I found the problem, it was the protoboard :mad::mad::mad:
    Once I'd disconnected all, and connected only the POT to the arduino, the POT tracked fine!
    Sure I still have a lot to do, but man! It works!!!
    Edit: Forgot to say that also uploaded the 0.63 version, so maybe that helped too.
    Thanks again @Pit !!! You kept helping me and we prevailed! :cheers
    Just a short video of the motor working!
    Cheers!
  2. Pit
    30,510Coins
    I am glad you sorted it out, perhaps the order of the jrks was jumping the gun...?
  3. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Well...to be more precise, a local shop has one JRK in stock and they were getting some more and asked me if I will want some, I said that possibly yes, but not paid upfront for them ;)
    Looks like I wont need them, I can get a really nice seat instead, thanks!
    Now back to the mechanical design. :cheers
  4. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Electrical part and electronics done:
    A Cablemodem box recicled :) for the Arduino+motomonster
    Also made a new shielded cable for the POTs out of an old VGA cable.
    Trying to make the sim as compact and light as possible, got the idea:
    I bought longer screws so I can fit the ball-joints, as I will start with 25mm levers, I think torque will be fine, the COG is about 200mm lower than the ball-joint, we will see...
    153,980Coins
    +11,160 / 57 / -2
    What are the torque/speed specs of the truck wiper motors you plan on using?
    You can get a bit of an idea of how design may effect available torque: http://www.xsimulator.net/community/faq/calculating-basic-linear-speed-and-forces.89/
  6. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Based on what I searched, this wipers are in the 20NM range, and tuned to about 90RPM no load.
    Thanks for the link! It is on my favorites already but as the specs of this wipers aren't sure, I will start with a short lever (25mm ctc) and then tune it to my pleasure:)
    153,980Coins
    +11,160 / 57 / -2
    For practical purposes 25mm CTC is about the shortest you can go and I think you may need it.
    I use 40mm CTC with 36nm torque and 54 rpm at the gearbox but I am guessing I have a longer and definitely higher connecting point, so also use much more leverage than you plan on using. In fact I have moved my connection point 30mm further forward during my current round of upgrades, to increase the leverage even further.
  8. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Yes, I know it is the shortest, and coincidentally it is the size of the lever that came with the motor pantograph :grin, but as you said, my connection points are really narrow (I think I saw some narrower).
    Anyway, I think this initial setup will be just that, "initial". I want to feel and play with a moving sim, once tried I'm sure I will know a lot better what I really want and expect from it.
    What I think it will help it's that the center of gravity is about 15-20cm lower than the upper ball-joint.
    BTW, I'm using a server psu, 12v 32amp. that has a really noisy fan, when I tried to change that fan for another quieter/slower, the PSU didn't turn on, so it looks like it has a current sensor as the original fan is 12v 0.65amp and the replacement is 12v 0.15amp. As I will use 2 fans for cooling the wipers, I connected them together with the inner fan of the PSU and Voila! PSU working fine again and I have power for my fans ;)
  9. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    There is generally a good reason for PSU fans being noisy and that is to keep the PSU cool. By downgrading the fan you are reducing the cooling efficiency of the supply.
    I would monitor the temps coming from the supply whilst in high usage to make sure the supply doesn't get too hot.
  10. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Agee with you, near the fan it is a temp sensor glued to a heatsink that shut down the PSU in case of overheat, also, I saw other people with this same PSU slowing down the fan and using it for hours at a constant 25amp load without probs, but yes, I will keep an eye on it and possibly add another fan in the vent.
    Playing with the parts...
    Fits perfectly, no need to solder anything an easy to add YAW movement in the future...:)
  11. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Sim is ready after a long day getting the U joint soldered and all mounted, but it's 1AM and I can't make noise... I'm effed up o_O
  12. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Which game send telemetry data without having to play? I mean, I want to test and tune my Sim without having to play directly.
    Thanks anyway!
  13. Pit
    30,510Coins
    try the replay of your games probably it works. Ages ago AC supported telemetry data while watching the replay but now not.
  14. bsft
    Rfactor has AI, download a cracked version of the game for free. choose track and car, go into practice, press the AI button (what ever it is) let it go for a run.
  15. Pit
    30,510Coins
    Seriously? You propose to do something illegal? o_O
  16. noorbeast
    153,980Coins
    +11,160 / 57 / -2
  17. mariano68
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    Thank you guys!
    Well, it is rough, it will be nicer...
    It's called "The Chair" :confused:
    Before I try anything, I have to install the pots better...
  18. noorbeast
    153,980Coins
    +11,160 / 57 / -2
    So I am hoping a video will soon follow? It would be great to see The Chair in action.
  19. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Love it !! you should call it THE ELECTRIC CHAIR :grin
    • Funny Funny x 2
  20. Pit
    30,510Coins
    Nice and clean design.
