Tutorial 3D printed Quick-release
Discussion in 'DIY peripherals' started by RacingMat, Feb 13, 2015.
Thread Status:
Not open for further replies.
  1. RacingMat
    21,062Coins
    Once I completed my DIY Mige steering wheel, I felt like to swap easily between wheels (F1, rally, GT...)
    but quick-release are expensive
    and for each new wheel, you have to buy the 2 parts QR and use only one
    and many QR loose precision with time
    So I intended to design a low cost, no gap, very fast quick-release!
  2. RacingMat
    21,062Coins
    Here some commercial Quick-release :
    Q1R 150€ [​IMG]
    expensive but works very well (tested by podobert)
    simracing dedicated
    http://beyondmonkey.com/pub/q1r/q1r.html and the Sim racing garage review with 2 videos
    ZENKY 65€ [​IMG]
    (tested by TortueG and StefBord)
    http://www.zenky-racing.net/collections/frontpage/quick-release
    D1Spec 60€/67€ (Taïwan) [​IMG]
    new mark II
    http://stores.ebay.co.uk/nitroxukimport?_dmd=2&_nkw=d1 spec quick release
    chinese "english" QR "5 years warranty" @60€ on ebay [​IMG]
    there are not good and wear down with gap
    SNAP OFF QUICK RELEASE BOSS KIT HUB ADAPTER FIT MOMO OMP SPARCO STEERING WHEEL
    • Useful Useful x 2
  3. RacingMat
    21,062Coins
    Here a 3D printed design from DSD
    interesting but expensive, and not so quick to fix and release IMHO
    maybe more design to come?
  4. RacingMat
    21,062Coins
    Here is what I draw:
    it should go on the MIGE shaft and use the wedge to stop rotation
    It's a printed part in blue and a collar of mountain bike in red
    it's a 100gr ABS piece
    Collar is Ø34.9mm internal: it's mountain bike size
    5€95
    http://www.decathlon.fr/collier-selle-rapide-349mm-id_3640502.html
    pay attention to:
    - the material (ABS is okay, PLA has been fine for Shannonb1)
    - ask for "full infill" (100% fill without honeycombing)
    - STL file describes only the surface geometry of a three-dimensional object (hence the volume but not the inside!) so ask for 100% fill
    because the 3D printer uses a software to read the stl file and by default they do honeycomb.
    • Creative Creative x 2
  5. RacingMat
    21,062Coins
    here is a video:
    • Like Like x 10
  6. RacingMat
    21,062Coins
    Same design can be applied to aluminium machining:
    A friend Rider63, machined the piece I drew in aluminium
    • Like Like x 7
    • Winner Winner x 4
  7. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Do you mind sharing your 3d print file?
  8. RacingMat
    21,062Coins
    I have added the stl file in the message ;-)
  9. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Just for insight....I checked with shapeways and they wanted 65$ to print this.....I have a buddy I work with that has a makerbot2 and is gonna hook me up instead but I figured I would look. I need to get into the 3d printing business!
  10. RacingMat
    21,062Coins
    you can have some quotation on 3DHubs.com
    it's expensive but less than what you got
    it's around 30€
    it's a good solution if you got a printer, yes !
  11. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    a 7 hours job!!
    I thought about starting with this....
  12. RacingMat
    21,062Coins
    It could be...
    • Like Like x 5
  13. Daguru
    Kitchen installer
    Wales uk
    469Coins
    Motion platform
    Thank you for sharing this idea @RacingMat
    I don't have a 3D printer so I thought why not run with a mild steel one so
    got a free bike frame off a friend and cut a section of the seat pole off the frame and the seat
    I used a bimetal hole cutter to make a 80 mm disc and then cut rough to size both seat pole and frame pole
    then drill G27 wheel PCD test fit and cut to size and paint
    works great and very fast to swap wheels total cost £5 for seat quick release
    thanks again ;)
    :cheers
    • Creative Creative x 3
    • Useful Useful x 2
  14. RacingMat
    21,062Coins
    @Daguru you're welcome! I'm glad it was useful for you and cheap!
    very nicely done!
  15. RacingMat
    21,062Coins
    This is the turn to Vicpopo to follow the aluminium Quick-Release model :)
    • Like Like x 7
  16. Pedro Melim
    Pedro Melim Smoother Racer
    Programmer
    Funchal
    710Coins
    I wish i found this sooner hehe.
    Bought from ebay 2 quick releases and still not sure if 2nd wheel can be fitted as im using the G27 default buttons and need some connections to the wheel itself.
    I think with this solution would be able to make a cheap and nice alternative to the quick release i have atm.
    Even tough, if my 2nd doesnt work will look into this, probably i an fit both wheels with this and make it work ;)
  17. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    thanks making the effort showing all your diy Quick releases. Very interesting :thumbs
    I'm thinking of converting my Fanatec Gt2 for other wheels, therefore I want to use one too.
    @RacingMat thanks for sharing your 3d printfile. May I ask what software you used to create it and would it be hard to change the diameter of the shaft?
  18. RacingMat
    21,062Coins
    I'm using Solidworks :thumbs
    write on the picture the new dimension you like: so i can produce a 3D file for you ;)
    • Friendly Friendly x 3
  19. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    thanks for making this offer this would be very nice.:thumbs I give the messurements when I have dissasembled my wheel and can messure the diameter.
  20. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    about to go with this design but will be mounting my quick release to this hub. Anyone used this? any failures with the print?
Thread Status:
