News 3dof linear acurator with steper motor 12Nm
Discussion in 'DIY Motion Simulator Projects' started by misoswan, Apr 8, 2015.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hi am start build 3 dof . need help I need arduino code for stepper motor.
    how To connect arduino + stepper motor with simtools.thanks
    am used nema 34(steper motor) 12Nm+cnc driver+arduino uno. thanks
  2. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  3. bsft
    3 dof drift or 3 dof lift?
    do you have an example photo of what you would like to build
  4. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    sorry it is fast drawing
  5. bsft
    3 dof lift, ok
    I will let someone else advise
  6. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    ok thanks
    153,914Coins
    +11,156 / 57 / -2
  8. RacingMat
    21,082Coins
    @misoswan : you will need to add some anti-rotation system on this 3DOF lift design. Do you have already an idea about this?
  9. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    anti-rotation system?I do not know what you mean. am used linear acurator and change engine ,Timing Pulley Belt Set Kit Reducer Ratio 6:1
  10. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    i have conection arduino on simtool.need to test a motor (stepper motor).HOW? need arduino code ?where and how.thanks
  11. RacingMat
    21,082Coins
    yes, your design is not stable: 3 articulated rods... and the plateform will fall instantaneously
    For a similar design but stable, it is 6DOF!
    For 3 DOF only, you need to add a guide to allow heave without sway!
    Look at the central part of this 3 DOF
    3_DOF_Motion_Base_-_2000_Lbs.jpg ;)
  12. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    i like
  13. SeatTime
    Or maybe like this below, if your motors are big enough - were the actuators are mounted to a hinged joint at the bottom. As for stepper motors - Ard just driving a stepper motor - easy, but for a sim - high speed + high torque stepper + feedback (rotary encoder etc) and running the required code at the required speed on a Ard - not so easy.
  14. bsft
    @riton was developing his own version of this
  15. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    I am a beginner so therefore where do I start?
  16. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    i have 3x steper motor 12nm.
    1x CNC Power Supply 350W 60V 6A For CNC Stepper Motor Driver MA860H M542H NEMA34
    3x steper driver DQ860ma
    1x arduino mega
    later i buy linear acurator .
    how can i connect an test the stepper motor, can anyone help please, an do i need to nut anymore bits for it to work
    153,914Coins
    +11,156 / 57 / -2
  18. SeatTime
    @misoswan said - I am a beginner so therefore where do I start? (Just my 2cent:)) - Really depends on your background/workshop etc and how much money you are prepared to throw away on development, but for a beginner 'where do I start' - My only recommendation is to keep it simple for your first sim using one of the well proven designs on this site. Likely a 2Dof seatmover. Once you have built and debugged one of these (no small challenge for a beginner in itself) you will understand more of what is required and can move onto more complex designs (if you feel you even need to). Seen so many people jump into something that is just too complicated/expensive, basically setting themselves up for failure from the beginning. In the end it is of course your choice.
    • Agree Agree x 4
  19. bsft
  20. misoswan
    1,032Coins
    3DOF, Arduino, JRK
