Motion Sim w/ Surge & Traction Loss
Discussion in 'DIY Motion Simulator Projects' started by Boomslangnz, Oct 26, 2014.
  1. bsft
    the USB cables are a mini A from memory. A generic USB cable for most devices, not just JRKS.
    DO not use PS3 cables. I did once and nuked my JRKS.
  2. Boomslangnz
    4,172Coins
    Okay usb cables are mini B actually so I picked up a couple today. I've driven up to my father in laws and checked everything over and relised I've left the heatsinks at home for JRK's. Doh! Ill have to drop into jaycar and hope they have some and I also need some connectors for putting over pins on JRK's anyway
    153,920Coins
    +11,156 / 57 / -2
    Jaycar carries heat sinks and often in multiple styles/heights, so you should not have any problems there.
  4. Boomslangnz
    4,172Coins
    Added my surge today and working on traction loss, still 3 more days up here to get plenty more done
    153,920Coins
    +11,156 / 57 / -2
    Don't forget to pause for a moment and take some happy snaps to post for your next update, I am looking forward to seeing them as I suspect you will be getting close to initial testing ;)
  6. Boomslangnz
    4,172Coins
    sorry I didn't take too many photos but a few I did take so here they go.
    10355803_10152890661363335_5590145357077848672_n.jpg 10983380_10152890661468335_3994129360127253809_n.jpg 11088402_10152890661208335_717068792952857974_n.jpg 11099989_10152890661313335_9208686782488420177_n.jpg 11133723_10152890661403335_3638266183232875026_n.jpg
    153,920Coins
    +11,156 / 57 / -2
    Thanks for the pictures...I figured you would be making the most of the Easter weekend.
  8. Boomslangnz
    4,172Coins
    as you can see from pics im using the linear bearings same as yours but mine will be doing the surge itself. I got a 880mm long one but im only gonna have 340mm total travel max (may not even go that far) so a big thanks to you dude for showing me the way! I was a little worried how they would go to be honest but they are awesome, moved the rig with ease although I haven't tried it with myself on it plus the very top frame yet. Hopefully we can finish the frame building tomorrow as traction loss frame is mostly made so far but haven't shown pics of it yet, just got to get it all sitting level with my 99mm high rubber castor wheels at back and the lazy susan bearing up front which is maybe 10mm high max but we are hopefully onto that.
  9. Boomslangnz
    4,172Coins
    another day done, traction loss frame basically done except for motor mounting positions etc and hall sensors need to still be added. Put it all together at the end of what we have made so far and seems really good. Both surge and traction loss can be moved around with a single finger. Bottom and final frame still to make which should be the most simple really but lets see how it all plays out, dropped into jaycar and grabbed the bits I needed
    153,920Coins
    +11,156 / 57 / -2
    It is really coming along now @Boomslangnz, thanks for taking the time to take and post the photos when you are so busy making the most of your free time for building this weekend :thumbs
  11. Boomslangnz
    4,172Coins
    any tips on how best to mount the hall effect sensors? at the moment we just had a threaded bolt basically going right through to other side of motor and im not sure how best to mount the sensors onto it
  12. bsft
    If they are like a pot, just do it the same way
  13. Boomslangnz
    4,172Coins
    same way as what tho? just drill a hole into the bolt?
  14. bsft
    @noorbeast , I recall you have photos handy to show how to mount the pot in motor shaft
    153,920Coins
    +11,156 / 57 / -2
  16. Boomslangnz
    4,172Coins
    Awesome thanks. Couple more questions while I remember. How far should traction loss swing around at rear and how much movement should I setup for my top layer? well your recommendations more then anything
    Thanks guys appreciate the help
    153,920Coins
    +11,156 / 57 / -2
  18. Pit
    30,510Coins
    • Useful Useful x 2
  19. Boomslangnz
    4,172Coins
    So relised I was an idiot and had my motors around the wrong way today eg 25:1 and 50:1 ratio motors so that was cool........
  20. bsft
    whoops
