value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. value1
    15,032Coins
    Hmmm… [​IMG]
    If you have everything ready, it'll take you ½ hour. So might be worth giving it a try.
    152,117Coins
    +11,066 / 56 / -2
    It won't be tonight @value1 but I will do the Cheat Engine steps again and post the results.
  3. jem45472
    jem45472 Active Member
    Buffalo NY
    97Coins
    @value1 I have same problem with steam version.
    Not sure if I did this right, but here it is.
    [​IMG][​IMG]
  4. jem45472
    Buffalo NY
    97Coins
    Today I started no limits twice before starting simtools and did not get the motion not supported error.
    I will continue to start game before simtools and let you know if i run into problems.
  5. value1
    15,032Coins
    I run the steam version too and got the message box. However I receive data once I click the msg box away.
    Do you get motion data as well?
  6. jem45472
    Buffalo NY
    97Coins
    I haven't tried clicking the box away.
    I'm usually using the rift and the box ends up buried behind the game.
    I will try if I have the problem again. It's been working all day today as long as I start game first.
    152,117Coins
    +11,066 / 56 / -2
    I will have to double check but I am pretty sure that on my stand alone version the message box does not go away when I try and click it, nor do I get data. Would it simplify things in the longer term if I used the Steam version instead?
  8. value1
    15,032Coins
    I'm updating Fullx86, Fullx64 and Steamx64. Currently there's no need to switch.
  9. Bodax
    Bodax Member
    Belgique
    583Coins
    Hi
    NoLimit 2 and simtools, it' s possible ?
    152,117Coins
    +11,066 / 56 / -2
  11. Bodax
    Bodax Member
    Belgique
    583Coins
    This is the same as for nolimit1?
  12. Bodax
    Bodax Member
    Belgique
    583Coins
    Good, there is there a tutorial ?
  13. noorbeast
    152,117Coins
    +11,066 / 56 / -2
  14. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Hi Bodax,
    I can help you if you need. I wrote a tutorial on a french forum, maybe it can help :sos
  15. value1
    15,032Coins
  16. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Thanks yet again Thomas.
    Mike
  17. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    Pitch isn't possible ?
    Cool plugin! love it.
  18. value1
    15,032Coins
    Currently not. We'll see with V2.2…
    Thanks ;)
  19. Mitchell
    Mitchell Member
    Netherlands
    87Coins
    I noticed sometime during a ride some turns sway to the other side haha.. just me or ??
    For example, left turn : sway to the right, another left turn : Sway to the left ... error in the game or is it just me ?
    i experienced this with Forest mountain park ride.
    i find this the best track btw, i also love the triple brake at the end hahaha gets me smiling anytime ( stupid i know )
  20. SilentChill
    20,592Coins
    @value1 I have just asked this in the nolimits forum and sounds like good things coming our way :D Can we use this for simtools ??
