  1. Pit
    30,498Coins
    SMC3 drives only one motor, either motor 1 or motor 2 etc. You have to click with the mouse on the "Motor 2" upper left corner to drive Motor 2..
  2. Greg83
    Greg83 Active Member
    IT Specialist
    Budapest, Hungary
    328Coins
    Thanks! And is it normal that once it moved the right motor, then I had to re wire the left one but after finishing this none of them move. Checked my cabling and all is well.
    Or setting up the utility needs simtools and a game to be running also?:confused:
  3. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Nope, the tool doesn't need any games or simtools to run. Should simtools be running SMC3 wouldn't be able to communicate cause the port would be already used.
    Why are you rewiring the motors? have you tried just re-launching the application?
  4. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Basically this was the reason, but I only had to change the power leads on Motor 2:
    • If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning."
    My diagramm might have been bad, the two yellow bars where represented like so, I have just changed the motor 1/2 blip and hence got the same info on one screen:
  5. Pit
    30,498Coins
    As I mentioned before in other threads (and already not only one time) do not write down your issues only, please post all photos and screenshots about your hardware/software. And I mean all...The screenshot which you have posted shows motor 1 ONLY.
  6. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Sorry about this.
    So the motor1/2 picture:
    My motors are wiper motors from VW:
    My wiring is done like so:
    I run the tools from the same pc as the games.
    What else would you need?
    Thanks!!
  7. Pit
    30,498Coins
  8. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Sub thread :
    Using the SMC3 Util. as Hall effect Feedback pot adjustments tool .
    Now open the SMC3 Util. connected to Ard. board ... then select to display the feedback signal and motor limits Only ... you will see a Green and 2 Red lines ... the green one is moving up and down when you rotate the pot manually ... align the pot Real midpoint " some pots have a midpoint click " to midpoint displayed on the screen ... OR ... 0-180 degree to the upper/lower Red motor limits .
    - Repeat that for each motor ...
    - Tight every thing down ready :thumbs .
    Thanks to my friend @cthiggin who pointed me to this Idea ...
    Best regards
    Spe;)edy
    • Informative Informative x 4
    • Useful Useful x 2
  9. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
  10. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
  11. Pit
    30,498Coins
    @Greg83 the wiring seems to be fine, of course I cannot see if all is welded correctly. BTW your wiring is really messy, please beware of mixing any colours, use blue or black for GND, red or orange for + and NEVER use same colours for different outputs. The day will come and you have to solve any issues. You will be lost mate if you will use two or 4 MMs once upon a time :) (30A; 60A).
    PS: already only using one MM you will be lost.
  12. RacingMat
    21,060Coins
    HA, ha!
    • Funny Funny x 2
  13. Pit
    30,498Coins
  14. Lighthill
    Lighthill New Member
    211Coins
    Hello to all,
    i need a little bit of your help.
    Is it at all possible to run the SMC3 code with a h-bridge which is operating
    the BTS7960B max 43A chip ?
    And if yes, which mode i have to use ?
    Mode1 or Mode2 ?
    Again - thx for your help and for your
    SMC3 code.
    BRGDS
    Lighthill
  15. Pit
    30,498Coins
    Hi @Lighthill c&p from the FAQ:
    MODE1: Supports the more common H-Bridges used in the forums. This mode has a PWM output pin plus two Motor Direction output pins. Examples include the MonsterMoto shield.
    MODE2: Designed for H-Bridges that require direct drive of Highside and Lowside switch inputs. In this mode one switch is driven as a direction pin and the other with the PWM output however the PWM duty needs to be inverted whenever the motor changes direction with the direction pin. (An alternate approach would be to switch the PWM between inputs as direction changes) An example H-Bridge that uses this mode is the cheap 43A IBT-2 found on ebay.
  16. Lighthill
    211Coins
    Ok, thank you for your fast reply ...
    my bridges have a
    PWM ENB
    INA 1
    INA 2
    that means i need mode 1, Right ?
    THX Lighthill
  17. Pit
    30,498Coins
    Your BTS7960 is a IBT-2 bridge...so what is the conclusion?
  18. Lighthill
    211Coins
    thank you Pit,
    I didn't know that, of course it helps
    me a lot ...
    Brgds
    Lighthill
  19. maiso
    maiso New Member
    19Coins
    First sorry for mi english. I'm new on this forum (since 2010 on x-sim) , I will start to build a 3DOF simulator. I have a Arduino Mega R3 2560 + Monster Moto Shield, this board is compatible with the firmware of this post correctly setting the pins or have to use the UNO R3?
    Thanks and soon I'll upload a post with pictures of the process.
    Regards
  20. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Guy,
    What I'am I doing wrong?
    Motors won't even move if PWMmax setting are set to 255, but in the tutorial it says it should start to move.
