Tutorial How to Modify a Server Power Supply for 12v
Discussion in 'DIY peripherals' started by Slider, Sep 7, 2014.
  1. substatica
    substatica Member
    882Coins
    It was the PWM frequency. I implemented some methods to enable Ultrasonic PWM courtesy of @RacingMat and the high pitch whine is gone. Thanks all.
  2. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Gone for Humans but you are likely sending all local Dogs mental :p
    • Funny Funny x 2
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    that to me sounds like the Hz of the motor. 5hz vs 20hz
  4. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    NM, you solved it already. Sorry didnt see that.
  5. RacingMat
    21,082Coins
    Arduino has standard 390Hz PWM and can be upgraded to silent 20kHz ;)
  6. Darkhanbaatar
    Darkhanbaatar New Member
    - 6Coins
    2DOF, DC motor, Arduino, 4DOF
    hi guys i have problem and i'm building 2dof wiper motor simulator but x-sim can sent signal to arduino, it think motomonster have problem, wiper motor don't move. What i do now
    153,914Coins
    +11,156 / 57 / -2
    We use SimTools here @Darkhanbaatar, not X-sim.
    If you are using X-sim then you need to post your question to the X-sim forum.
    If you want to try SimTools you can, but do start your own project thread and Xsimulator members can then try and assist you.
  8. Darkhanbaatar
    - 6Coins
    ok i'm sorry i tried Simtool results is same, first i build micr oservo it is working fine and i started build big one, i used arduino + motomonster code of arduino
    153,914Coins
    +11,156 / 57 / -2
    Again start a new thread @Darkhanbaatar.
    In your new thread explain what you have built and include details, like have you ground isolated the wiper motors, and include pictures so we know how it is wired.
    You also need to explain what code you are using with the Arduino. There is code available for Arduino/Moto Monster/SimTools, but are you using that or something else?
  10. substatica
    substatica Member
    882Coins
    No matter the connectivity of the pins the power supply (the same model as the tutorial) fan is always on, is this what everyone else is experiencing? Are you switching the power cable as well to turn on/off the PS fan?
    153,914Coins
    +11,156 / 57 / -2
    Yes the fan remains on, that is normal @substatica and I do turn mine off at the power switch.
  12. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    I wanted to know if anyone knew if you can connect 2 DPS-600PB's togehter with 1 switch to turn them on? Same as in this thread (4 and 8 on one side and 6 and 10 on the other side), but just [4,8,4,8] one side of switch and [6,10,6,10] on other side of switch. Would this one switch turn both supplies on? The power coming from each psu are still seperate( one psu for each motor), just wanted one switch to turn them both on. Just wanted to know if it would mess up the units somehow.
  13. Nick Moxley
    • Agree Agree x 3
  14. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    What Nick said, just add another contact to the switch and keep both power supplies separate.:thumbs
    You could also switch the supply voltage TO the power supplies via a emergency stop switch. That way you would only need one contact. But that obviously requires you to switch the mains voltage which can make things dangerous if not done right.
    So again, the best option would be to add a second contact to the switch.
    153,914Coins
    +11,156 / 57 / -2
  16. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    Thanks for all the help guys!! I really appreciate all the responses! I had one of these...
    laying around so I wanted to use the key sort of set up for both psu but I think I'll just go with 2 switches.
    I did see one of these...
    called a "Double Pole, Double Throw relay"
    "A Double Pole, Double Throw relay allows you to switch two different circuits simultaneously. The 'Double Pole' bit just means that it has two separate inputs that can be switched - and we now know what the 'double throw' stuff means. With this type of relay you can:
    - turn on two completely independent circuits
    - turn one off and one on
    - turn off two completely independent circuits"
    but I think I'll go with just 2 switches for 2 psu. Thanks again!!
  17. madgino
    madgino New Member
    1,122Coins
    There's no quicker, simpler, or more reliable means of converting a DPS-600. It takes all of a minute to accomplish.
    As stated above, simply bend the pins together and solder with a fine soldering tip. The non-used pins can be bent out of the way to create more room if desired but I have never found this to be necessary.
  18. Nick Moxley
    I would be weary suggesting newbies trying that method Madgino. My fear is Worst case scenario......A Pin breaks then the user is left with either diving in Far deeper than they had imagines into the wiring, or buying a new supply and starting again.
    Looks nice tho. :thumbs
  19. madgino
    madgino New Member
    1,122Coins
    Once you try it that way, you'll never go back ;)
  20. Shadow041
    Shadow041 New Member
    Sparkie
    Melbourne, Australia
    431Coins
    Does anyone know what the limits for these power supplies are? i seem to be having trouble with mine. I've got some hooked up to jrk controllers (1 for each controller) and the 25:1 gear motors from motion dynamics and have found that in certain circumstances (like if i drive off the track) the psu will shut its output to the jrk off.
    This doesnt seem to make sense as theyre rated for around 47A and supposedly the peak current handling of the jrks is 30A... Any ideas?
