Playseat 2 dof 24V Arduino pololu + oculus rift dk2
Discussion in 'DIY Motion Simulator Projects' started by michto35, Dec 29, 2014.
  1. michto35
    michto35 Member
    france
    102Coins
    Hello all,
    This is my simulator 2 dof.
    It is made of wood and aluminum and steering wheel holder is made of pvc.
    The electronics are made of an Arduino and a 24V pololu card.
    The motors are 24V smolka
    Thank Racing Mat because it is thanks to its tutorial.
    currently running with the simulator software XSIM but I show you mine this forum in order to earn Coins.
    That after the brief space for photos:
    Some video of the simulator in action:
    If you have any questions do not hesitate.
    • Like Like x 9
  2. eaorobbie
    20,488Coins
    Welcome wont be long and you can swap over to SimTools and you will never look back.
    Plus we have some better Ard code here too you can try aswell, not that Mats is no good.
    Again Welcome and please try SimTools and enjoy !!!
  3. michto35
    michto35 Member
    france
    102Coins
    Thank you for your message.
    Sorry for my English I use google translator.
    to showcase my simulator on the forum is to switch to simtools.
    I did not know existed other than code for the Arduino I intend to look at that.
    Later I would like to add two other engine for the heave effect.
  4. eaorobbie
    20,488Coins
    Cool.
    Yes I use Google translator too if someone needs an answer in another language.
    Yes there is 3 different codes here all are different.
  5. michto35
    michto35 Member
    france
    102Coins
    different arduino code is on the firmware and interface page?
    the current code with which I turn is the Racing Mat, what is the difference with the other codes?
  6. bsft
    Nice job on the PVC frame there. Good to see another PVC sim going to motion. I like the work you have done with the shifter box and dash, very neat.
    As for ard codes, I will let @eaorobbie cover that.
  7. michto35
    michto35 Member
    france
    102Coins
    thanks
    The shifter has been done with a selector bmw buy on ebay.
    I show you some pictures of the assembly.
    • Like Like x 5
  8. michto35
    michto35 Member
    france
    102Coins
    I just parameterize the simtools on my computer. it took me a mere 10 minutes. really easy to use, I can not wait to test it in games
  9. michto35
    michto35 Member
    france
    102Coins
    pvc structures is good but the friction of pvc against wood makes a lot of noise.
    So as a solution I have half a carpet between wood and pvc, now I no longer any friction noise.
    I also rivet any junction structure.
    I add a joystick to play Elite dangerous.
    I also change my pedal that's much better than my old one.
    Here are some photos.
  10. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Hi you have done some great work there well done :thumbs:thumbs
  11. michto35
    michto35 Member
    france
    102Coins
    I take this opportunity to show you an overview of my installation.
    the small cabinet to rate simulator is homemade.
    it allows me to put my keyboard, the rift, my headset and mouse.
    Below I have half my pc.
    then the electronic box that allows you to run the simulator.
    It is a junction box electrician, 2 ventillateur 12 cm to cool.
    was found inside the 24V supply and the card arduino and pololu.
  12. michto35
    michto35 Member
    france
    102Coins
    Hi everybody :cheers
    This week I changed my simulator because it was made of wood and began to grow old and make noise.
    A force to tighten the screws wood crashed.
    So I retrieve an old bed base and I are cut into pieces and weld.
    I am satisfied, no welds because they are not beautiful o_O but it's solid.
    The rigidity of the structure and the sensations it gives on the simulator are exellent.
    no parasite movements to the flexibility of PVC.
    none of grinding noise either.
    This morning I'll make me a hand brake to play dirt rally. :grin
  13. zigzag49
    zigzag49 Active Member
    724Coins
    nice work michto, on the wheel carrier saw diameter tube, a reinforcing bar on it would have been a plus for rigiditer?
    beau travail michto , sur le support volant vu le diametre tube , une barre de renfort sur celle ci aurait été un plus pour la rigiditer ?
  14. SilentChill
    20,596Coins
    Great upgrade steel a lot better than wood :) Looking good
  15. michto35
    michto35 Member
    france
    102Coins
    Thank you :thumbs, I am eager to go to finish.
    For the reinforcement of the steering wheel bracket I wanted to test without a bar because I wanted the lightest possible strucutre.
    For rigidity I find it sufficient but if I see that it moves I would make a reinforcement.
  16. michto35
    michto35 Member
    france
    102Coins
    Here is my handbrake DIY
    it is found that recovery equipment at work and in my garage.
    the base is a cable track support.
    diameter stainless steel tube 20
    bike handle
    push Button
    spring my old pedal FANATEC
    absorber bike
    here is the result
    152,553Coins
    +11,087 / 56 / -2
    A great bit of recycling ingenuity @michto35 :thumbs
  18. michto35
    michto35 Member
    france
    102Coins
    thank you, I like recycling is good for our planet as our cars in simulators zero C02 :thumbs
  19. michto35
    michto35 Member
    france
    102Coins
    Here's a video with my dirt rally simulation and oculus rift.
  20. michto35
    michto35 Member
    france
    102Coins
    It 's very fun :popcorn
