Showroom Blame73's 2DOF Seat Mover
Discussion in 'DIY Motion Simulator Projects' started by Blame73, Nov 20, 2014.
  1. Nick Moxley
    Your "Zero" is determined by the Min/Max setting's in the JRK utility.
    Wait, Nevermind. Ard, Not Jrk. carry on. :p
    • Funny Funny x 2
  2. Pit
    30,510Coins
    ?? By turning the pot?
  3. Pit
    30,510Coins
    lol
  4. SilentChill
    20,601Coins
    Yeah turn the pot surely
  5. Blame73
    Blame73 Well-Known Member
    8,314Coins
    Due to my stupidity I'm a new adept to the 'MotoMonster Explosion Party' :(
  6. SilentChill
    20,601Coins
    Oh dear looks like you reversed the polarity ?
    153,950Coins
    +11,160 / 57 / -2
    Commiserations ... RIP MotoMonster [​IMG]
  8. Blame73
    8,314Coins
    I forgot to hook up ground from MM to Ard :cheers
  9. SilentChill
    20,601Coins
    That wouldn't blow it up tho. You have the 12v input wires wrong way round on your pic if your colours are red for positive and black for negative
    Right input = Negative
    Left input = Positive
  10. SilentChill
    20,601Coins
    If you just replace the capacitors it may still work you would have to try and see.
    I did the same with one of mine and it still working now.
  11. Blame73
    8,314Coins
    thanks for the info @SilentChill , I'm going to try replacing it.
    Do you remember the specs of the capacitor?
  12. SilentChill
    20,601Coins
    470uf 35v I just used a random 470uf 24v I think .
    Just make sure you check your motomonster power input polarity before you connect it. And then check it again and then connect it up ;)
  13. Pit
    30,510Coins
    Agree, 5v does never kill the MM or Arduino, and please @Blame73 NEVER use two red wires even if one is marked with a black tape. At least the lagging (or wiring isolation) is not as well it should be (friendly bashing ;) ). The damage is not so big, in your stead I would order more than only one sample.
  14. Blame73
    8,314Coins
    You're both right, I shouldn't do any works on Monday morning
    Putting the wires back I switched the two wires
    Ordered the capacitors, I'll try to fix the MotoMonster.
    Meanwhile, lucky enough, I got today the 'Chinese stuff', little money and 'just' one moth for delivery (usually it took two months).
    153,950Coins
    +11,160 / 57 / -2
  16. Nick Moxley
    For what its worth, I take Colored Sharpies and or bust out my Enamel Paint pens from my RC tires and Do what i can to prevent these little boo boo's......I also have Texture coded wires So Positive is Square and negative is round.
  17. bsft
    JRKS have reverse polarity protection as long as usb cable is NOT plugged to the computer
  18. SilentChill
    20,601Coins
    And so they should for what they cost ;)
  19. bsft
    I have still nuked quite a few in my time from operator stupidity, (points to himself). They are not completely idiot proof.
    • Funny Funny x 3
  20. Nick Moxley
    I wouldn't suggest testing that claim tho. :grin
