value1
Need For Speed Plugin 0.0.0.0
SimTools game plugin for Need for Speed Series
  1. value1
    14,244Coins
    Need For Speed Plugin - SimTools game plugin for Need for Speed Series
    • Like Like x 7
  2. bsft
    Cool stuff man, thanks Id better go see if I can find the game disc
  3. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    I testing Need for Speed Shift 2.
    It does not work
  4. value1
    14,244Coins
    I only have 1.0.0.0 here :(
    Is there a patch somewhere?
  5. CraCk
    Made in Ukraine
    670Coins
  6. value1
    14,244Coins
  7. yobuddy
    51,549Coins
    your a superstar @value1! - great work!!!
  8. CraCk
    Made in Ukraine
    670Coins
  9. value1
    14,244Coins
    BTW: You can get some of these games with a very big discount at Origin as "Black Friday-Sale!
  10. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Another VIP goes to the list "Very Important Plugin ":grin ... perfect job @value1 & @CraCk :thumbs .
  11. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    Hi, after several attempts, I can not run this plugin for Need for Speed SHIFT. I play on Steam, I patched the installation directory of the game in steam (C:\Program Files (x86)\Steam\SteamApps\common\Need For Speed Shift). I also tried, patched to the backup directory (C:\Users\JP\Documents\NFS SHIFT). The two methods do not work in the tuning center, the Surge /Sway values do not vary. If anyone can help me, thank you :thumbs
  12. value1
    14,244Coins
  13. Trafalgar
    13Coins
    @value1
    I apologize, I had not read that only NFS Shift provides pitch, roll and yaw. But for Need for Speed Shift 2: Unleashed, I have the same problem.
  14. value1
    14,244Coins
    @Trafalgar
    I'm on vacation and will check when back next year ;)
    In the meantime, you can try if it works, when you start SimTools after the game (Unleashed) is running.
  15. Trafalgar
    13Coins
    @value1
    I tried to start SimTools after the game, it does not work. It doesn't matter, we'll see it next year. Good holiday :)
  16. value1
    14,244Coins
    @Trafalgar: Please try this version. Hopefully it solves your issue. Please let me know:
  17. Trafalgar
    13Coins
    @value1 , no, it still does not work :(
  18. value1
    14,244Coins
  19. Trafalgar
    13Coins
    @value1, I will wish not need to install this software, do not waste time for me on this game. I have other less focused on simulation games, for my friends they want to test my 2DOF. Thank you anyway ;)
  20. Raulmerlos
    Raulmerlos Member
    Mecanico maquinaria calzado
    Monóvar (Alicante) España
    138Coins
    3DOF, Arduino
    Hello friends, I get this error when I try to patch elNeed for Speed SHIFT, you can help me, thanks.
