value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. BlazinH
    16,671Coins
  2. Nick Moxley
    Thanks Blazin, now why wont simtools seems to "see the game" manager doesn't click over to pCars and cant seem to get it to come to life.....did i patch the right directory ? im using a x64 version with a shortcut on desktop
    Ok got pCars to work and pCars64 to work, but it wont work with the Gld version which supposedly allows all the Adjustments ingame with the press of F1, How can we fix that ?
  3. Nick Moxley
    Ok so got my base tuning #'s all set, and now i want to play with the "pCars64Gld" settings in game but cant due to Simtools not running off the proper .exe file How can we change that ?
  4. value1
    15,076Coins
    Hi @Nick Moxley
    Pardon my ignorance but what is the "GLD" version?
  5. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    Gold version allows to use shortcuts like "CTRL + S", "F1", "CTRL + F"... which are very useful in the development version but that no longer exist in the standard retail version.
    Gold version can be launched by addind "-gold" to the command line.
    PCARS.EXE
    PCARS64.EXE
    PCARSGLD.EXE
    PCARS64GLD.EXE
  6. value1
    15,076Coins
    Thank you, @Erwan960, for the explanation and the exe names. I will add them to the plugin and it should work afterwards again.
    And thanks @Nick Moxley for bringing the issue up.
  7. value1
    15,076Coins
  8. Nick Moxley
    Not being a Early adaptor of Pcars, I had the opportunity to try it out. As to how Old this version is that i have, I have no clue. Maybe Erwan could help me on that one. Yes it was a Torrent and For what its worth, The small intro i had last night getting a few cars setup and overall experience with the UI. This is a game i would consider having in my collection, So as to weather or not i would have chosen to buy before i tried is questionable. But the fact ive gotten a taste and now i want more.
  9. michto35
    michto35 Member
    france
    102Coins
    thanks for the plugin :thumbs , i want test the game with the rift and my simulator
  10. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Do you think there will be a new plugin for Project Cars release 1.0 ?
    ________________________________________________________
    Pensez-vous qu'il y aura un nouveau plugin pour projet cars 1.0 ?
  11. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    Hi every body, finally it comes out this game :thumbs, I took the steam limited version, but the plugin 3.0.6.2 does not work for me. Does it work for you ?
    If anyone can help me, thank you :)
  12. Pit
    30,497Coins
    @all: I could not test yet pCars because my rig is disassembled. If this plug in is not a bit working we have to wait until @value1 has the leisure to update the plug in. As far I know he is veeeery busy at the moment, btw writing or updating a plug in is very time consuming so please stay patient the next days...(or weeks - who knows, but I do not hope so :) )
  13. Trafalgar
    13Coins
    I found my problem, it is necessary to activate the option Use Shared Memory, by default he is on No.
    Everything seems to work now :grin
  14. zigzag49
    zigzag49 Active Member
    724Coins
    Bonjour
    Le plugin fonctionne , si tu as bien patché au bon chemin d'accès au jeu .
    Essai dans les options du jeu , tu vas dans :
    Options/visuals/hardware
    Et tu met oui dans use shared memory .
    Avec ça sa devrai fonctionner comme indiquer plus haut par blazinH.
    Hello The plugin works, if you did well patched the right path to the game. Test the options of the game, you go to: Options / visuals / hardware And yes you put in use shared memory.
    With that will have its function as indicating higher by blazinH.
  15. value1
    15,076Coins
    Indeed, the plugin worx:
  16. Trafalgar
    13Coins
  17. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Can anyone tell me what I missed, because Project cars just not workink with Simtools.
    I got a message after patching to do something in the game... to set some MMF or something?
    Plugin downloaded, patched as usually. What could I set in the game to work Simtools?
    Anyone can help me?
  18. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @Gelatin - MMF is the Shared memory. See @value1 post 2 above yours... (#56)
  19. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    OMG, Srry.
    I don't know why I did not see this post, perhaps my slow internetconnection...
    I have less time for my rig what I wish to. I need to read posts more patiently...
    I apologize for that blind question
    Thank You!
  20. Archie
    Wollongong, NSW, AU
    3,797Coins
    No worries :) Hope you got it going!
