simulador 2dof arduino inicio
Discussion in 'SimTools compatible interfaces' started by Claudemir, Nov 22, 2013.
  1. Claudemir
    33Coins
    [Anexar = full] 14111 [/ attach] [attach = full] 14111 [/ attach] [attach = full] 14112 [/ attach] [attach = full] 14113 [/ attach] [attach = full] 14114 [/ attach] [attach = full] 14115 [/ attach] [attach = full] 14116 [/ attach] [attach = full] 14117 [/ attach] [attach = full] 14116 [/ attach] [attach = full] 14116 [/ attach] Mais algumas fotos do projeto, agora no tamanho total da plataforma.
  2. Claudemir
    33Coins
  3. Pit
    30,490Coins
    Hi Claudemir first I thought the final weight could be a problem, but you demonstrated already the very good balance. Good job!
  4. Claudemir
    33Coins
    Bom Manh Galera.
    Esteu simulador de para ver Como Fazer Mecanica Feito FOI Pronto. Eu Sqaq: Disse NAO, e de Todos os OS Motores superaquecido testiculos Fez. Im usando UMA bateria e Opaco 24v 50A Fonte.
    Uma nota para UMA ponte HE Tao Bem e eu Localidade: Não Fazer superaquecimento coloquei nenhum refrigerador e As Pontes H paragrafo Proteger superaquecimento Arduino.
    Paragrafo videio Como ISSO Mostrar-LHE Funcionava Eu Fiz.
    Ficar ao Lado Com Voce Vai dos par ver Como eu ter tratado Tambem Motores Comportamento pesos Sandalo.
    Pensando estava Eu, VAMOS colocar de Mais e Mais potentes CAINS evitar marchas reducoes Motores de Danos.
    Ele. É Tudo ISSO Momento Pará
    MODERATOR EDIT:
    Good Morning Guys.
    'm Simulator to see How Mechanics Ready Made WAS. I Sqaq: I said NO, and All OS Engines overheated testicles Fez. Im using a battery and 24v 50A Opaque Source.
    A note to A bridge HE Tao and I Well Location: Do not put any cooler overheating and The H Bridges paragraph Protecting Arduino overheating.
    Paragraph videio Show How YOU THAT I Made It worked.
    Staying With the side you will see the pair As I have dealt Also Motors Behavior weights Sandalwood.
    I was thinking, WE put more and more powerful gear motors CAINS avoid cuts Damage.
    Him and all this time to
  5. Claudemir
    33Coins
  6. Historiker
    9,208Coins
    Please take the time to use Google Translate so more people can follow along with your wonderful build. We ask this of all members.
  7. Claudemir
    33Coins
    perfeitamente funcionou rfactor1 com tudo, mas não com rFActor2 Funcion the plugin installed. Ele que indica esteu conectada a Plataforma, mas não se move, devo fazer o que? rfacto1 Funcion bem com!
  8. eaorobbie
    20,481Coins
    If GameManager reports that the game is running then check in the Game Engine - Tuning Centre that values are coming in this will confirm the plugin is running correctly.
    Then make sure there is an entry in the GameEngine - Axis Settings for rfactor2, if have missed the important step in setting up - Setting up the Default Axis - when you install a new plugin they will not be assigned an Axis Assignment, or will be what ever you had in the default axis.
    Last if all right it will be that the min max setting in the tuning centre are set too high.
    That should fix the issue.
  9. Claudemir
    33Coins
    Bom dia!
    Rfactor conseguiu fazer o trabalho, mas tenho uma dúvida.
    Tenho todos os eixos de trabalho, mas não estou tendo as reações de mudança de velocidades!
    Quando eu acelerar levanta empurrando-me traz, e ao puxar freio para baixo, porque os meus motores estão na frente da plataforma.
    Então o que devo fazer para obter esses saltos que sentem quando mudar de velocidade?
    Estive a ver alguns vídeos de outros membros do fórum e notei que todos eles têm esses movimentos.
    Cada mudança de marcha é notado uma sacudida, mesmo quando você tirar o pé do acelerador.
    Meus movimentos de desaceleração e aceleração dá-me a sensação de que eu estou indo para cima!
    Este sentimento que eu deveria arrancar cada troca de marcha ou redução súbita do motor do carro correto?
    Tem vídeo explicativo de como configurar?
  10. eaorobbie
    20,481Coins
    Shift change is present in the surge force , and a little can be felt in the pitch angle too.
    I setup a balanced Axis Assignment (100% in total Axis Movement) using 5 DOForces ,Roll,Pitch,Surge,Sway,Heave setting each at 20%. Ok now to test and find that nice surge movement for shift changes , modify the Axis Assigment so that only surge is working at 20% then start the game and test, if the movement is too little or too weak, open the Tuning centre and lower the values for surge. And shouldn't take long to find a nice setting for your table.
  11. Claudemir
    33Coins
    Bom dia!
    Hoje agradeço a Todos Que me ajudaram a completar o Meu Projeto.
    Aqui esta o rezultado final.
    Eu Localidade: Não Vou citar nomos parágrafo Localidade: Não esquecer ninguem, eu ESTOU Muito feliz.
    AINDA Falta alguns Ajustes FINAIS nn SimTools confuguração.
    ESTOU postando hum Vídeo parágrafo Você. ver.
  12. Claudemir
    33Coins
    Bom dia eaorobbie
    Eu tenho hum Problema com a Minha Plataforma.
    Quando eu Estou los UMA curva o Eixo gira Demais, e Acaba de Parar o Automóvel!
    A Minha pergunta e: Como Posso reduzir o grau de Rotação do Eixo ?: sos
  13. Claudemir
    33Coins
    ola @ eaorobbie RufusDufus
    Ok?
    Comprei dois motores maiores para minha plataforma.
    E eu tenho um problema!
    Motores OS funcionão por um tempo Cuto!
    Eu suspeito que é a ponte H!
    Está certo?
  14. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    To bad that this is all in Spanish. :(
  15. bsft
    is called online translator, copy, paste, read, etc
  16. Blame73
    Blame73 Well-Known Member
    8,304Coins
    I'm pretty sure it's portuguese
  17. Claudemir
    33Coins
    [QUOTE = "Blame73, post: 65408, membro: 13543"] Eu tenho certeza que é português [/ QUOTE]
    Portugues Brasil
  18. SilentChill
    20,592Coins
    Really ? im sure you have told people to use english when posting ;)
  19. bsft
    :p
  20. Claudemir
    33Coins
    Sorry my friend I use Google translator and I can not tell if they really are intendendo me!
    But I'll try to tell my difficulty.
    I'm having problems with my 250wts engine.
