2DOF Simulator by a Newbie
Discussion in 'DIY Motion Simulator Projects' started by mugge66, Jun 17, 2014.
  1. bsft
    yes thats right , that will provide best leverage
  2. mugge66
    mugge66 Member
    Denmark near Copenhagen
    167Coins
    2DOF, JRK
    I have read and also my first choice to mount the motors at the back of my cabinet. But if i want to save and spare the motors would you the recommend option A B C. And also i little stupid question if you wish in the future to upgrade to 3dof du i still need my shaft or is it carried by the motors.
  3. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Still trying to figure out this puzle. Ideas are welcome, how do you guys mount the lever to Wipermotor are welding the solution or can loctite do it.
  4. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Just 4 pcs of these today. From lever to seat.
    • Optimistic Optimistic x 1
  5. Scratch
    Scratch Active Member
    281Coins
    Hi! Looks good, I'm also building my first rig ATM. I had similar idea at one point about motorized pedal and steeringwheel movement, but then decided to leave it for now. Would be very cool feature though, wish to see your implementation!
  6. bsft
    @Scratch , I've built many full frames. They are fine to build. A little more to set up than a seat mover.
  7. bsft
    Motors work best at "c" , then next best place is "a". If you look at 3dof full lift later you would use a spring at the pivot placing to assist the weight of the frame instead of the pivot. But as you may be looking at full lift , I suggest 4 x Big worm gear motors with 50:1 boxes on them and levers about 45mm ctc. Going from balanced to full lift increases cost quite a bit.
  8. Scratch
    281Coins
    Yes, I've read about your awesome setups here in xsimulator bsft and your posts have helped me tremendously. And it surely must be a whole new level with fully moving frame!
    But what I ment here and was referring was mugge66's idea to adjust pedal and wheel distance with motors instead of manual adjusting.
  9. bsft
    Done that as well. Had a height adjustable wheel mount that would move up and down and back and forth towards driver , that and the pedal base was long enough to move the pedals back to the seat for shorter driver. Pivot doesn't move , but adjustability of driver size does.
  10. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Think i will go for the C option :) then.
  11. RacingMat
    21,068Coins
    You can also :
    - do a conical hole in the lever
    - use a nylstop nut to press the lever against the teeth
    it works fine for my 2DOF.
    Or you can weld a nut on your lever + add a second nut to lock it
  12. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Thank you racingmat. I just wasnt sure it could hold. but will run with that solution ;)
  13. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Does anyone know a quickguide to understand the learn function and motor direction. Im little lost.
    I tested yesterday the learn function, but what i dont get is. The first thing i need to do is move the lever to max"forward position. does this also means accelerate direction or brake direction. or have it nothing to do with that.
  14. bsft
    Sounds like you are setting the feedback.
    I take it the pots are connected to the motors are they?
  15. bsft
    @eaorobbie , you might be able to answer this sooner than me
  16. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
  17. RacingMat
    21,068Coins
  18. eaorobbie
    20,491Coins
    http://www.xsimulator.net/community/threads/playseat-to-2-dofseat.5401/page-2#post-56352
  19. Pit
    30,502Coins
  20. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    You can get those on eBay for about 8.00 US - Great product.
