SONXUN SX8847
Discussion in 'Motor actuators and drivers' started by Ceresoli, May 21, 2014.
  1. Ceresoli
    Ceresoli ceretz
    Cinema Projectionist and car mechanic
    Piemont, Italy
    419Coins
    Hi all, I have two 240w dc motor driver for my flight simulator. Does anyone know them?
    They are produced by SONXUN, SX8847 models.
    I'm trying to connect to my Arduino Mega 2560 with two optical encoders, two limit switches and a proxy for the central location of the engines.
    All for a cab game TAITO TOP LANDING converted to FSX!
    An old 2DOF.
    I will post pictures soon
    Regards
    ceretz
  2. eaorobbie
    20,481Coins
    @Ceresoli is there a data sheet available , a link with more information then we can inform you on how to use them.
    http://forum.arduino.cc/index.php?PHPSESSID=me43bkmpcav26repgknmej1ch4&topic=134411.15
    Looking here I found a code to drive them so to wire are run them he has :
    //Functions used on h bridge pcbs.
    int oneen = 8; // enable
    int onedir = 9; // direction
    int onepwm = 10; // pulse width modulation
    int onedi = 2; // disable
    //also connect GND and VCC obviously
    Looks like we need to drive the enable pin high in order to enable the driver and then set a direction high will go one way and low will turn it the other way, then we drive the pwm pin inorder to set a speed to travel in the direction we want, lastly you can then disable the driver via another pin ( like if a safety switch).
    Looks feasible and I believe @RufusDufus code could run these drivers.
    Hope that gets you started
  3. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    Thank you for reply!
    I had already looked at the link you have posted.
    I also found this, which also explains how to use the SPI register http://forum.arduino.cc/index.php/topic,171010.0.html
    I can not find the code @RufusDufus . Could you give me the link? So I can compare with other material at my disposal and can then share my experiences. I would be really grateful!
    Sorry for my english :p
  4. eaorobbie
    20,481Coins
  5. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    This in my Arduino's code for test only two SX8847 Without other I/O
    I use it witw an Arduino Mega 2560 R3.
    Two SONXUN SX8847 Test with Arduino Mega 2560 R3
    int oneen = 12; // enable MOTOR 1
    int onedir = 11; // direction MOTOR 1
    int onepwm = 10; // pulse width MOTOR modulation 1
    int onedi = 9; // disable MOTOR 1
    int twoen = 8; // enable MOTOR 2
    int twodir = 7; // direction MOTOR 2
    int twopwm = 6; // pulse width modulation MOTOR 2
    int twodi = 5; // disable MOTOR 2
    // the setup routine runs once when you press reset:
    void setup()
    // initialize the digital pins.
    pinMode(onedir, OUTPUT);
    pinMode(onepwm, OUTPUT);
    pinMode(oneen, OUTPUT);
    pinMode(onedi, OUTPUT);
    pinMode(twodir, OUTPUT);
    pinMode(twopwm, OUTPUT);
    pinMode(twoen, OUTPUT);
    pinMode(twodi, OUTPUT);
    // the loop routine runs over and over again forever:
    void loop() {
    //turn all low
    digitalWrite(oneen, LOW); // part 1, h bridge activation 1
    digitalWrite(onedi, LOW); // part no disable 1
    digitalWrite(onedir, LOW); // high turns forwards, low is reverse 1
    digitalWrite(onepwm, LOW); // high runs motor (if h bridge is on) 1
    digitalWrite(twoen, LOW); // part 1, h bridge activation 2
    digitalWrite(twodi, LOW); // part no disable 2
    digitalWrite(twodir, LOW); // high turns forwards, low is reverse 2
    digitalWrite(twopwm, LOW); // high runs motor (if h bridge is on) 2
    delay(1000);
    // onedir high, onepwm low, works clockwise
    digitalWrite(oneen, HIGH); // part 1, h bridge enable 1
    digitalWrite(onedi, LOW); // part 2, h bridge no disable 1
    digitalWrite(onedir, LOW); // high turns anticlockwise, low is clockwise 1
    digitalWrite(onepwm, HIGH); // high runs motor (if h bridge is activen) 1
    digitalWrite(twoen, HIGH); // part 1, h bridge enable 2
    digitalWrite(twodi, LOW); // part 2, h bridge no disable 2
    digitalWrite(twodir, LOW); // high turns anticlockwise, low is clockwise 2
    digitalWrite(twopwm, HIGH); // high runs motor (if h bridge is activen) 2
    delay(4000);
    //turn all low (motor off)
    delay(1000);
    //onedir high, onepwm high, works anticlockwise
    digitalWrite(oneen, HIGH); // part 1, h bridge activation 1
    digitalWrite(onedir, HIGH); // high turns anticlockwise, low is clockwise 1
    digitalWrite(onepwm, HIGH); // high runs motor (if h bridge is on) 1
    digitalWrite(twoen, HIGH); // part 1, h bridge activation 2
    digitalWrite(twodir, HIGH); // high turns anticlockwise, low is clockwise 2
    digitalWrite(twopwm, HIGH); // high runs motor (if h bridge is on) 2
    delay(4000); // wait for 1 second
    delay(1000);
    Motors waits for one second, goes clockwise for 4 seconds, waits for one second,
    anticlockwise for 4 seconds, waits for 1 second, repeats.
    The setup routine runs once when you press reset
  6. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    This is the first test of two sx8847 with Arduino Mega and one LCD.
  7. eaorobbie
    20,481Coins
  8. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    linked, sorry! i have edited the message :D:popcorn
  9. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    I have update arduino with an LCD. This is the first test.
    I'm work to study the SPI register of SX8847, becouse there are some helpful function and communication sended to arduino from this driver!
    The information are very helpful if the are some problem during motor control.
    My idea is to have an LCD monitor 20x4 for parameter visualization like motor position, sx8847 problem (temp. warning, no load, undervoltage, ecc.) and state of various switch for security.
    Very long work......:mad::mad:
  10. eaorobbie
    20,481Coins
    All coming along nicely, Well done keep us informed or any questions ask away.
  11. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    Hello, sorry for my absence, but I became a father of the little Carol
    :grin
    I attach the datasheet of the integrated heart of sx8847 and the arduino's library found around the internet.
    I hope can be useful, while I continue studying and compiling the sketch for the motor management:rolleyes:
    152,021Coins
    +11,061 / 56 / -2
    Congratulations @Ceresoli :cheers
    Thanks for this update of your developing project.
  13. Ceresoli
    Ceresoli ceretz
    Piemont, Italy
    419Coins
    With a little help of arduino's community i have compiled this.
    Example with explication for SX8847 SPI Access, program and serial monitoring
    The second step is adding a LCD for diagnostic (visualize SX8847 Poblem and motor position) and complete the sketch with some security switch, 2pot and the infrared photocells that block the simulator in case of unauthorized acces in mition simulator area .
