Ultraforce GS-4 DIY - Software
Discussion in 'DIY Motion Simulator Projects' started by Schluzu, Mar 7, 2014.
  1. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    Hi guys
    today i drive my first rounds on the seat with all Plates together, what should i say
    "i love it", sure there can be some modifys in simtools but it works great 4 me.
    by the way here are 2 test-videos from today
    the Surface Plates make only 40% of the possible Way, thats far enough for me, i like it so.
    and the Backrest aprox. 70%
    Cuted foam rubber will follow.
    @eaorobbie thx 4 the code
    Your Code v1 works great on arduino nano at the backrest
    and in the moment at the seating surface works the Teensy 3.1 >>>>> wont work with any of your new codes ????????<<<< with the old modified from the board here
    i hope i get the Arduino Nanos as soon as possible........
    @Roadster2
    i hope you mean a schematic like this:
  2. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    @Roadster2
    please note:
    if you want to install the servos paired like the original (face to face), you must open 1 servo and change the direction of rotation.
    if you make it like me, you dont have to change anything in/on the servos.
  3. Roadster2
    Roadster2 Member
    1,197Coins
    Hi Martin. Thanks. With two Arduino's you would run the base plates from one card and the rear plates from the second ?
  4. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
  5. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Very good @Schluzu ... I'm very impressed ... that idea never came across my mind before ... nice job ... keep the inventing machine ON .:thumbs
    I guess you're the first how makes a chair like this here ... as far as I saw .
  6. Roadster2
    Roadster2 Member
    1,197Coins
    From the photo's on the ultraforcesim web site, see link above, it appears that they use two servos on each plate but then you notice the CentredPushrod photo that shows two servos driving one actuator arm. Is this on the base plates or both the base plates and the rear plates ? (anyone with a GS-4 answer this). Photo "2012-09-24 14.21.19.jpg" (http://www.ultraforcesim.com/pub/2012-09-24 14.21.19.jpg.jpg) is one of the base plates and shows, I think, the cable to the third servo right at the back.
    I have also picked up info on Turnigy TGY-1270HV Metal gear Digital Servos. These are rated at 40kg, have heatsinks and are not that much more expensive.
  7. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
  8. RacingMat
    21,050Coins
    @abdo_tahan : you can find information about DIY Gseat in this resource
    there is a link to a 2011 topic with detailed pictures and explanation.
    I just added the link to @Schluzu's Gseat ;-)
    Congrats for your functional Gseat simulator!
  9. RacingMat
    21,050Coins
    @Schluzu : can you tell us where is your pivot point?
    Due to the shape of official gSeat plates and patent principles, I suppose that it should be B rather than A: but I'm wondering what you did and how this feels... ;-)
    thanks
  10. speedy
    Alexandria , Egypt
    7,943Coins
    Thanks buddy this site here is huge and can't cover it all ... nice concept description ... But they using balloons I guess ?
  11. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    @RacingMat
    if you make the Pivotpoint like A you have much more load on the Servos.
    and on the Baseplate i have the Pivotpoint under the Seatbone (Ischium)to get the maximum load to there.
  12. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    I think one of these
    sitz.JPG Sketches feels even better.
  13. RacingMat
    21,050Coins
    Yes, I agree with you: load is reduced.
    Plus it pushes in the middle of your back: while braking, you're pushed forward.
    If pivot is like A, this effect is lacking.
    For bottom plate, it pushes you upward: it simulates heave effect.
  14. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    My bottom plates only working from 127 to 255 (<< assigned -90° to +90° / Servo Starting Point is -90°) theres no negativ way. (1-126 is ignored)
    The backplates works from 0-255 also (<< assigned-90° to +90° / start at 0°) and when you watch
    the video, even stepp on the brakes the backplates go nearly to -127 at the same time the bottomplates
    come up. I also have tested, that the backplate only work in one Direktion but the feeling was not so
    good like now. Acceleration, Braking and Sway works much better with both directions.
    on the backplate i have mixed: small Roll / full Sway / small Pich / full Surge
    and Bottom: mid Roll / mid Sway / smal Pich / mid Heave / mid only negative Surge (working upwards like all other dof`s)
    The % and Filters of each DOF i haven´t in mind here in the office
  15. Roadster2
    Roadster2 Member
    1,197Coins
    Hi Martin. So what exactly is needed for control of the servos - 2 x Arduino Nano boards and 2 x expansion boards for ease of connections. Is anything required for programming the boards or is this done simply via the onboard USB connection. From your schematic the servos are driven directly from the Arduino boards i.e. no additional driver boards or circuits required. If I have this right it sounds relatively straight forward.
  16. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
  17. Roadster2
    Roadster2 Member
    1,197Coins
    Hi Martin. What have you used for actuator levers - metal ones, standard commercial product ? For the Push Rods I was thinking of using M5 or M6 Rod Ends with pieces of threaded bar - but these may not be too easy to adjust.
  18. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    i used 10x rear upper suspension arms from a modster beetle V2.
    why?
    the right length for me, and in sufficient amounts at my dealer available.
  19. Roadster2
    Roadster2 Member
    1,197Coins
    Have you now got the two Arduino boards setup. How are things now ?
  20. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    not really time currently and i am still waiting for the arduino board(s) :-(
    i´ll wait for the arduino and use the code from earobbie(THX) ;-) which works fine at the backplates.
