simulador 2dof arduino inicio
Discussion in 'SimTools compatible interfaces' started by Claudemir, Nov 22, 2013.
  1. Claudemir
    23Coins
    how do I switch to IDE mode 2 in SMC3 setup?
    did istalaçao of fois alright! could not do more to move the engines yet! do not know if I chose the right way! Any tutorial for this, I do not know how to change the IDE!
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,313Coins
    Edit the code at the top to say MODE2 (no space) as in picture below before you upload to the arduino.
  3. Claudemir
    23Coins
    OK!
    Unable to move the cattle engines.
    And how should I proceed?
    trerei using SMC3Utils.exe along arduio as well as with SimTools_v1.0?
  4. RufusDufus
    Adelaide Australia
    16,313Coins
    Start 1 step at a time, and let me know where you get to.
    Step A: Shut down Simtools both Game Engine and Game Manager
    Step B: Program the Arduino (don't worry about wiring up H-Bridges and feedback pots yet)
    Step C: Run Windows SMC3 Utils on the same machine as you have programmed the Arduino. Check that it starts up and doesn't report any communications errors
    Step D: You should now see the chart being updated on screen, select square wave or triangle wave and the blue line should change
    Step E: Disconnect the Arduino from power/computer and connect the feedback pot if not already done
    Step F: Reconnect Arduino to computer and run Windows SMC3 Utils again - now you should be able to turn the pot and the green line will change on the chart
    Step G: Disconnect the Arduino from power/computer and connect the H-Bridge and motors and motor power (if you can find a toy motor and 9V battery that is a good safe test at this stage)
    Step H: Reconnect Arduino to computer and run Windows SMC3 Utils again.
    Step I: You now have to get some useful parameters setup, as a start try Kp=400, Ki=0, Kd=0, PWMmin=0, PWMmax=150
    Step J: Now when you turn the feedback pot from one extreme to the other the motor should slow down, stop/change direction, and speed up again.
    If you can get to this point then you are ready to put the motors and feedback pot on the sim and configure that... Follow the steps below:
    8. Set Kp to about 400
    Now you are ready to get Simtools setup. *** Make sure Windows SMC3 Utility is not running while you are trying to use Simtools ***
  5. RufusDufus
    Adelaide Australia
    16,313Coins
    Actually in Step J above if the pot (green line) moves outside the Limit Zones (Red Lines) the motors will be shut down so it will seem like nothing is working.... move the pot so it is in the center of the chart and then restart Windows SMC3 Utils which will reset the controller. Same for the numbered steps at the bottom.
  6. Claudemir
    23Coins
    Good day could make the engine move up and to Beixo now have to configure the tools pragrama yes?
    I tried to configure most do not know how to do it right!
    You could esplicar me an easier way intender sim tools?
  7. RufusDufus
    Adelaide Australia
    16,313Coins
    Hi Claudemir, That's great, sounds like you have the motors working?
    To get simtools setup with the SMC3 you need the following in the Interface Settings: (Typically the Interface 1 tab but any will do)
    The Interface output string is: [A<Axis1>][B<Axis2>]
    If you have three motors use: [A<Axis1>][B<Axis2>][C<Axis3>]
    No spaces anywhere.
  8. Claudemir
    23Coins
    Hello all right? good today did the testing of engines with pots when turning the potentiometer can manually control the direction of them and also keep them stationary, this indicates that the motors are connected correctly right? al plugged the arduino simtools installed on your computer and applied the settings that u gave me the GAME ENGINE like this here in the photo, I will do more when output test nothing happens or an engine moves! what to do you have a complete setup sim tools that I can use? I do not know anything about programming thanks!
  9. Claudemir
    23Coins
    Hello could make the motors move with the sim tools
    My mistake was deichado Egine space on the Game setting. But now it's running to see the video!
  10. Claudemir
    23Coins
    New Photos of mechanics is already ready.
  11. RufusDufus
    Adelaide Australia
    16,313Coins
    @Claudemir, great work, looks like you are moving along well. Glad you solved your problem driving the motors.
  12. Claudemir
    23Coins
    Thanks but owe it all to you!
    But now what do I do with the rest?
  13. Claudemir
    23Coins
    Adding a little Surge% to simulate the acceleration and braking or Heave to bumpiness road.?
    because the engines move with delay?
  14. eaorobbie
    20,488Coins
    Your video show the motors and not moving at the same speeds or at the same time as is needed for a true pitch or roll movement which will lead to bad motion cues, be nice to see the whole rig move with you on it.
  15. Claudemir
    23Coins
    yes but the question is, which of to realize that when I put the game to run with the controls are delayed exp: it accelerates the arms of the motors should move up and the brake should move up and down but it does not !
  16. Claudemir
    23Coins
    Because the game engine does not simulate the Heave, Yaw, Sway and Surge?
    The Roll and Pitch are working!
  17. RufusDufus
    Adelaide Australia
    16,313Coins
    Hi Claudemir, what game are you using? As far as I am aware all Simtools plugins have the 6 basic DOFs: yaw, pitch, roll, heave, surge, sway.
    As for the motors not responding too well, my guess is either the values in the Simtools tuning center are not right yet, or you haven't got the PID parameters in the Arduino motor controller right yet.
    Are you still using the Arduino SMC3 motor controller? If so use SMC3utils to setup the parameters for the motor so they run smoothly with that first - you can output test signals to try. Values of say Kp=500, Ki=0, Kd=0, PWMmin=50, PWMmax=200 are probably good starting points.
    If you post screenshots of the Simtools Interface Setup tab, Tuning Parameters, and SMC3utils parameters, etc we may be able to spot anything that doesn't look right.
  18. Claudemir
    23Coins
    I'm using the game rfactor 1.
    I'm using the motor controller to the Arduino SMC3 that you stated!
    I did not SMC3 is a change in how you sent me.
    Then you have to configure parameters outside the game engine?
    I'm using a R3, 2 arduino ponteH IBT-2, 2 engines 5v, 2 potentiometer
  19. RufusDufus
    Adelaide Australia
    16,313Coins
    Yes you need to use SMC3utils to setup the motor parameters for best performance.
    The setup steps I gave in post #46 are just cautious settings to make sure nothing gets broken while setting up. Once you are happy with the setup you then need to adjust the parameters for best operation. Looking at your video you are ready for this step.
    I would suggest stopping Simtools and running SMC3utils again and changing the controller parameters. Select the "Sine Wave" output and adjust the settings until the motors move well. Try the values in post #59.
  20. Claudemir
    23Coins
    OlaRufusDufus
    I'm posting this with the settings
    Because SMC3Utils does not respond?
    I edited the notepad but nothing happens.
    With the new 0.6-SMC3 will not communicate with the game engine!
    What did I do?
      347.3 KB
      949
      193.3 KB
      979
      140.7 KB
      995
      1 MB
      1,016
      256.5 KB
      995
      324.4 KB
      910
