Resolved iracing plugin not working?
Discussion in 'SimTools DIY Version' started by Bruceaust, Nov 2, 2013.
  1. Bruceaust
    Bruceaust Member
    CNC Routing
    Launceston, Tasmania, Australia
    63Coins
    First of all, thank you for making this software easier get going. The interface is much easier to use.
    Great work thanks
    My Question: I have downloaded the" iracing plug in" and patch it into the game manager.
    However when I run iracing, the Game Engine says "iRacing_Plugin.dll is Not a valid game plugin!"
    Are there a problem with this plugin? Has anyone had the same issue?
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,451Coins
    Hi Bruceaust, I haven't had the same problem as you but I have reported an issue with iracing plugin having intermittent motion output - it's being investigated at the moment. Couldn't say if they are somehow related, hopefully a new version will be available soon that solves known problems.
    Have you had success with other plugins?
    Have you been playing iracing long? I have only just started recently, still waiting to get a license. :grin
  3. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    Thanks RD,
    I have been iracing a few years now. At this stage its the only racing sim I use. I would describe myself as an "average middle of the road" racer. But I really enjoy it (iracing) and the hobby of Motion Sim building.
  4. yobuddy
    51,551Coins
    maybe a corrupt download?
    try it again please... :thumbs
    did you install it as a zip?
    thanks buddy
  5. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    Yes, I installed as stated in the guide.
    I have since re installed the patch successfully - same problem occurs when I try to run iracing. I am using a second PC to run the motors. Connection via LAN works fine.
    I tried everything again using 'Live for Speed ' - same errors occurred.
    Incidentally, when I installed LFS , it corrupted my Logitech wheel configs and my graphics configs in iracing. I had to do a system reinstall to fix these issues! Do I really need to run LFS initially to get sim tools to work?(Iwould rather not, as I don't wish to repeat the corruption issues I experienced here.)
    If you need any more info on my settings to help isolate where the problem might be coming from, I am happy to oblige. Has anyone else experienced similar problems that may be related?
    Cheers
  6. value1
    14,244Coins
    Hi Bruceaust
    Do you get motion out of Live for Speed?
    (Or any other simulation other than iRacing?)
  7. yobuddy
    51,551Coins
    Hi Bruceaust
    What OS are you running and are you an administrator on this PC?
  8. eaorobbie
    20,503Coins
    I haven't had this issue except iracing plugin need work as in data doesnt seem to flow smoothly,
    On the other question, LFS was one of the first that was done, doesnt mean you have to install it to test SimTools, feel free to install any of the other games, I have tested most in Windows 8 - 8.1.
    Mmmm is the other software plugin still in use on the machine, could be causing a conflict. We never know but I know of a couple of members who still have it installed and they haven't reported any issues, I have tested Dirt3 and Grid2 with 2 pcs, no issues to report on them.
  9. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    I only use iracing, but tried LFS just to get sim tools going. My game PCM runs w7, my motion PC runs Xp.
  10. yobuddy
    51,551Coins
    well it's not a plugin problem if it happens with both plugins.
    LFS Plugin came with the main software so it should have no problems with Not Valid DLL?? hmm..
    Did you install the plugin for IRacing on both the Game Manger PC and the Game Engine PC?
  11. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    aaaaaAAAAAHHHH! lol.
    I need a rap over the knuckles - no I have not installed the iracing plugin on the motion PC.
    Thanks I will give it a go.
    Bruce
  12. eaorobbie
    20,503Coins
    We are only human mate, mistakes can happen, hope its all go for you, btw SimTools is not resource hungry like the other software, runs fine on one pc, but the option for 2 pc's is very handy indeed.
  13. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    I now have got the "Game Engine" talking to the "Game Manager" . But I still have a problem.
    The output from the Game Engine is very small. I have searched the forum for a similar problem and have tried to do what was recommended to fix the issue. - ie: "use the Tuning Centre". I tried to use the tuning centre to set new Max/Min values. However the tuning centre did not capture any max min values. As soon as i started iracing, the capture button blanked out, the reset button would not work and the save button also did nothing. The data was changing in the top windows, but nothing changed in the capture windows.
    I must be doing something wrong?? (or there is a bug?) I see from others that they have used the tuning centre successfully.
    I try to resolve my problems as best i can, but this one has me baffled.
    Any suggestions please - (anyone else having the same issue)
  14. Bruceaust
    Bruceaust Member
    CNC Routing
    63Coins
    I done more testing , and found that the buttons in the Tuning centre do work, but you need to click and hold for a second. However the text on the capture and reset buttons disappear when iracing starts.
  15. yobuddy
    51,551Coins
    First start IRacing and then click "Capture Max Min" and then click reset and you should be good to go.
    But please check your Axis Settings for IRacing first, maybe they are to low.
    And will you clear the BUG status from the thread as you now have it working, thanks!
  16. eaorobbie
    20,503Coins
    This is clearly explained in the manual , please check there before searching the forum, has a lot of information in it that hasn't even been discussed among the users. Plus written for people to understand as in not big confusing words, if you follow it from start to finish its basically a how to.
