Arduino uno wiring diagram
Discussion in 'SimTools compatible interfaces' started by hooshang, Nov 9, 2013.
  1. hooshang
    hooshang Active Member
    275Coins
    hello freinds
    after having some problem with setting Thanos amc 1.5 with simtools,
    and plan to upgrade staff,finally i recieved my Arduino uno
    board,as i already have pololu vnh2sp30,can anybody help
    for wiring to connect them,
    thank you & regards
    Hooshang
  2. RacingMat
    21,059Coins
    Hello!
    Can you give an URL of the Pololu you're using? It would be easier to help you!
    Yours
    Mat
  3. hooshang
    275Coins
  4. RacingMat
    21,059Coins
    Fine, it is the same pinout as Motomonster:
    1 pin for speed (PWM) and 2 pins to indicate direction of rotation (inA motor1 & inB motor2).
    Keep on going!
  5. hooshang
    275Coins
    ok Mat
    thank you and i know this for my pololu board
    but which pin in Arduino uno is for pwm1 & 2
    ,inA1.inA2,inB1,inB2...
    regards
    Hooshang
  6. RacingMat
    21,059Coins
    I have added the wiring in the resource here
  7. eaorobbie
    20,488Coins
    Could we please place a copy of the wiring diagram here please, where the question was asked, help users more than having to troll through another post,
  8. hooshang
    275Coins
    @eaorobbie
    thank you friend for backing and fully support community:thumbs
    @mat
    thank you for direction and i think need a little more efford and study
    it takes a bit time...ill be in touch later.
    regards freinds
    Hooshang
  9. RacingMat
    21,059Coins
    I understand that point. :)
    On the other hand, a single place for an information is more convenient for any further updates/correction.
  10. eaorobbie
    20,488Coins
    This is what was posted not really a diagram of such, but pin out info.
    Arduino /..Motomonster1
    ......GND <-> GND pin
    ........5V <-> 5V
    .....pin 4 <-> pin 4 inA motor1
    .....pin 5 <-> pin 5 pwm1
    .....pin 6 <-> pin 6 pwm2
    .....pin 7 <-> pin 7 inA motor2
    .....pin 8 <-> pin 8 inB motor1
    .....pin 9 <-> pin 9 inB motor2
    such as Motomonster:
    Beware error in pin out found by @hooshang refer here:
    http://www.xsimulator.net/community/threads/arduino-uno-wiring-diagram.4908/page-2#post-47579
  11. RaceRay
    Hamburg, Germany
    23,877Coins
    Imho Helpful for people who do not know which pins must be connected together.
  12. eaorobbie
    20,488Coins
    Nice picture would have helped him more and others.
  13. RaceRay
    Hamburg, Germany
    23,877Coins
  14. hooshang
    275Coins
    its not all about the sketch
    Arduino is the open source board so first should know
    about program going to be load on atmega 328 and then make related wiring diagram.now we have the file HERE (thank you Mat)
    and a good freind here(eaorobbie),so it can be done..
    regards
    Hooshang
  15. eaorobbie
    20,488Coins
  16. RaceRay
    Hamburg, Germany
    23,877Coins
    I didnt mean it serious @eaorobbie nevertheless, the sketch looks really good.
  17. hooshang
    275Coins
    and where the pots are?
  18. eaorobbie
    20,488Coins
    Not a problem thought I would add one for the driver that was actually asked for. Its there and @RacingMat can post it into his write up or even @hooshang can, there for everybody now. I actually have tested this driver to 30amp limits and it performs well, even if I had tested with the K8055 ages ago. I still have it.
    I will add the pots tonight mate then suppose its a complete schem. for the Ard Boys.
    Sorry I should have done that last night.
  19. RaceRay
    Hamburg, Germany
    23,877Coins
    Hashtag @RacingMat so he sees this post;)
  20. eaorobbie
    20,488Coins
