Missing or unknown device (-24)
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jsmith2307, Jan 29, 2012.
  1. yobuddy
    51,539Coins
    Do you have all of your jumpers installed? My AMC 1.5 has one up in the right corner. See picture. And in the lower right it looks like it may need one?
    there is a jumper by the switches too that I can't see.
    Sure, if you want to send it to me and have it programmed, just IM me for my address buddy! :cheers:
  2. jsmith2307
    jsmith2307 Member
    Respiratory Therapist
    Corpus Christi, Texas
    324Coins
    2DOF, DC motor, Arduino, Joyrider, Motion platform
    Jumpers? I have only three on my board, should I have four?
  3. yobuddy
    51,539Coins
    Wire jumpers Highlighted in RED.
  4. jsmith2307
    jsmith2307 Member
    324Coins
    Thanks, maybe this will be my ticket! I checked my board there is not a place to put a jumper at that spot. My board v1.5 was updated 13-8-2008, is there another?
    jsmith2307
  5. yobuddy
    51,539Coins
    The closer I look at it; you may just be using a newer layout than mine.
    Feel free to send the chip for programming if you’re stuck buddy!
  6. jsmith2307
    jsmith2307 Member
    324Coins
    Yeah, I started freaking out, but I saw a v1.5b with a jumper, in that area. The footprint is a little different. Yes, I will send the chip tomorrow or Monday. :clap:
    jsmith2307
  7. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings,
    I am still trying to figure out this board... aside from getting a bad batch of atmegas, I think my zeners are positioned correctly (see pic). My crystal appears smaller than the ones used in your boards, could this be it? I'm getting my atmega checked out by Yobuddy, I should hear something in 3 or 4 days.:( DSC04701.JPG
  8. kbssa
    kbssa New Member
    Brazil
    0Coins
    I am having the sema problem as you, I tryed wtih 24mhz crystal but not success missing or unknown device, so I chenged to 18432mhz crystal and nothig again.
    I have tested all the board conections and it is allright, I dont know what could be.
    I will try to with another chip, i am using a usb converter, if anyone know how to make a serial cable let me know so I will make one to see if the problem is the cable.
  9. tronicgr
    tronicgr
    Well... seeing this thread confirm's my thoughts for kits with pre-programmed microcontroller.
    Actually yesterday I finalized my bootloader code that allows simple users to upgrade the firmware without the hassle of using any programmer circuit or ponyprog anymore. It works great over USB-serial and has a simple GUI on the pc side!!
    Thanos
    PS. (lol... posted in wrong thread before... too early in the morning)
  10. jsmith2307
    jsmith2307 Member
    324Coins
    Greetings,
    Another quick question. I have a combination of metal film type and carbon resistors, on the AVR could that be the problem? It is reaching, a little, I know. Yobuddy, the crystal thing did not work, Thanks for trying, back to the drawing board. :?
    jsmith2307
  11. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    This is the error-free cable style :D
    There are two important things to notice:
    1 - Make this cable long enough. I made mine too short and regret about it.
    2 - Make a solder job better than mine lol
    regards,
    rafael.
  12. yobuddy
    51,539Coins
    Resistors are so cheep, why not try it?
    Or the chip will be there soon man!
  13. jsmith2307
    jsmith2307 Member
    324Coins
    Man, I think you are right! I'll have the whole thing rebuilt. But it bugs me I can't chase this thing down. The chip should be here by Friday. :)
    jsmith2307
  14. kbssa
    kbssa New Member
    Brazil
    0Coins
  15. jsmith2307
    jsmith2307 Member
    324Coins
    Hi There,
    Check your zener orientation one looks off! :yippiee:
    jsmith2307
  16. kbssa
    kbssa New Member
    Brazil
    0Coins
    jsmith2307 found an error on my board !
    The orientation of zener is wrong
    Thanks man for help !
  17. jsmith2307
    jsmith2307 Member
    324Coins
    Anything I can do. Good Luck!! :cheers:
    jsmith2307
  18. kbssa
    kbssa New Member
    Brazil
    0Coins
    I don't believe that !!!
    tI was only the zener man, now it is working !!
    I hope you can solve your problem too
    Thanks a lot jsmith2307
  19. jsmith2307
    jsmith2307 Member
    324Coins
    Ongoing delemma, yesterday, I tried replacing all of the carbon resistors to metal film resistors, 13 in all.
    Nothing changed.... Today I plan on replacing the capacitors...., somethings got to give. :?
    jsmith2307
  20. kbssa
    kbssa New Member
    Brazil
    0Coins
    Nothing yet ??
