Display config. options
Discussion in 'DIY peripherals' started by julian.bernard, Feb 23, 2011.
  1. julian.bernard
    julian.bernard New Member
    22Coins
    Hi all,
    I'm in the final stages of wrapping up my sim design before I embark in the purchasing process, and have got one last dilemma! I've decided I definately want a 180 degree wrap around screen, but am unsure whether to go for a curved screen or a three panel screen with substantial radii joining them together. I intend on using 3 HD projectors (Mitsu HC4000 seems to be my best bet at present) and possibly some warping and edge blending software, namely Warpalizar which appears to be very well priced! My only fear in running a curved screen config as opposed to a 3 panel screen is the focal depth issues brought about by projecting an image onto a curved surface.
    According to my calculations, each projector will be projecting an image of 2.21m (Wdith) and 1.25m (high) with a maximum screen depth of around 25-30cm (throw distance between3.1-4.6m). I've asked around on the projector forums but nobody really has any idea on extreme curved surfaces as most focus on home theatre configs.
    On the other hand I could play it safe and go for the three panel arrangement, but I wonder how good the immersion sensation would be...
    Any opinions would be much appreciated!
    Regards,
    Julian
  2. ozywan
    ozywan New Member
    0Coins
  3. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Hi Julian,
    nice project going on :thbup:
    If I ever start a project like this I would go for the curved screen without hesitation simply because I personnaly hate the angles between the screens on a 3x flat panels setup... It kills the immersion even without bezels...
    Videos of sims on curved screens using Warpalizer looks amazing! No more screen angles causing image distortion :clap:
    Thx for sharing! Now I want my own curved screen!
    This one is very similar to your drawing and the FOV looks fantastic!
    http://www.youtube.com/watch?v=MayDauX_l2o&NR=1
    http://www.youtube.com/watch?v=q4Yq_6NoNZQ
    http://www.youtube.com/watch?v=zaYTGmL3L3U
    Looking good even on smaller screen!
    http://www.youtube.com/watch?v=0ugtkl8SP5w&feature=related
    And for inspiration...
    http://www.youtube.com/watch?v=-3CDndo6lQw&feature=player_profilepage
    Here is a DIY project of a 130 degrees curved screen. It's more for home theater but contains a lot of usefull infos that might help you in your project. You must be logged on to view the pictures ...
    http://www.avsforum.com/avs-vb/showthre ... st15186244
    Please post your work progression :)
    Regards,
    Bleco
  4. julian.bernard
    22Coins
    Thanks for the input Bleco. Yeah I have stumbled accross those videos, very nicely sims! The first rig is base performance sims, that one is 42 (GBP) thousand if I m not mistaken!!!
    My only worry is that the projector won't be able to produce a relatively uniform focus picture...what do you think?
  5. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi julian
    the focus is with 3 projectors not a big problem and a curved screen.the spot height
    is not very high.the rest make the software.i use nthusim.but i have find a other soft http://www.vioso.com/de/profi-tools/vio ... enter-pro/ hi make the correctur with camera.
  6. bleco
    Montréal, Canada
    258Coins
    I don't think this will be a problem especially with Mitsubishi projectors! :thbup:
    Bleco
  7. julian.bernard
    22Coins
    Thanks Nima, What is spot height?
  8. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi
  9. julian.bernard
    22Coins
    So in my case teh spot height is around 25-30cm (i.e. maximum depth?) Now I'm just deciding on graphics cards to power the 5769 x 1080 resolution! I'll either be going for 1 or two Radeon HD 6970's :)
  10. bleco
    Montréal, Canada
    258Coins
    The res will be 5760x1080 and using one single 6970 will be more then sufficiant ...
    Bleco
  11. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    I currently have 3x 28 @ 5760x1200 on a HD6970 and it is holding up pretty good!
    However, you need a nice CPU to keep up with that.
    Anyone up for testing 2x 1920x1080?
    Any focus limitations?
    Bleco, maybe after you get your FullHD projector, we should get together for some testing on a home made card board curved screen or something like that! :)
    Cheers,
    Erick
  12. bleco
    Montréal, Canada
    258Coins
    Hi Erick,
    It could be cool, I'm up for it if you have a DIY screen to test ... I am not near starting this kind of project on my side...
    But I think it would look way better with 3 PJ's ... Check on youtube for curved screens using 2 PJ's, it doesn't look good ... but maybe it's just a config issue ...
    Bleco
  13. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    I was talking about making a simple cardboard curved screen just for fun.
    Watch this video, seamless edge blending with warpalizer!
    http://www.youtube.com/watch?v=HWm9PtzWvko
    More info here:
    http://simhq.com/forum/ubbthreads.php/t ... x12_C.html
    That looks great, much better than 3x720p IMHO!!! What do you think?
    Cheers,
    Erick
  14. Deaks
    Deaks New Member
    Freelance Editor
    Bristol UK
    388Coins
    Hi Nima
    I have a single projector setup, currently projecting onto a flat 2.4 x 1.45 metre screen. I want to try a curved screen for better immersion. I have some sheets of white painted metal sheet 3 x 1.5 metre to do some tests with.
    I have downloaded NTHUSIM standard to test, but the cost is quite high. I notice you have been testing the VISOSO presenter pro software. How do you get rfactor to display onto the visoso panel?
    I can see that the warping controls work very well, but I can see no way to get rfactor to display. Can you help me?
    Thanks in advance
    Deaks
  15. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    i have test with the vioso multi software.but only with the demo and the demotime
    is beend bei me.with the multi all have work and its work with the destop the nthusim not.but i drive with nthusim again i have pay nthusim.
  16. Ashraf
    Ashraf Member
    1,034Coins
    3DOF, Arduino, Motion platform, 6DOF
  17. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    until people use a screen like that they dont understand how much that helps improve your driving.
  18. gigi
    gigi Active Member
    916Coins
    2DOF, JRK, 4DOF
    Hallo,
    I've just build a curved screen and I will use it with my Vpr Optoma GT1080darbee.
    Do you know if there are any conflict or issue with simtools 2.2?
