iRacing profile for 2DOF/SFGT wiper motor
Discussion in 'X-Sim² profiles' started by pointer4, Aug 7, 2010.
  1. pointer4
    pointer4 Member
    Hungary
    276Coins
    I relate it first, i am not a big setup maker, this is my first try.
    I read a lot from the settings recently, they made progress with an SCN5 very much, and the motion-physics very well.
    I believed it it would be best to use theirs, the construction like a same, but the Thanos electronics solves the distribution of the control of the two axis for us.
    This is why the mathematics fully different, we may solve this easily, i switched the third dip switch into a second position (JoyRider)
    All two axes move oppositely after importation, i reversed them. (25 and 32 ports)
    source
    Please test it, this best one which succeeded till now, to bring out my simulator.
    I try to finetune the 33 and 30 effect to produce more movements on road bumps.
  2. pointer4
    pointer4 Member
    Hungary
    276Coins
    Okay, changes..
    NIMA visited me (I owe him a big ThankYOU), and my education being through seven hours, and the result of experimentation we did, an even better setup. :thx:
    Calibrated to lotus strength, to tune slower car, play a little bit with the sliders. (start moving up with accel,brake,bumps,rpm in first time)
    The Dip switch stay into a JoyR position.
    I am sure that, this is not the last version.
    http://www.youtube.com/watch?v=KCKZxbhqUyU
  3. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    this wars a good working with you pointer.interisting to see the video from ather
    work.
    this is a profil with slider.you must load it two times and with programm settings
    the slider a save in programm settings.on first load you only becom the slider on one accuator.than you you must load the profil again.you can see it in the math setup,on first load you only have yellow lines on one side,and the profil only work
    with yellow lines on both sides.
  4. pim
    pim New Member
    system engineer
    nederland, brabant
    380Coins
    2DOF, SCN5, SimforceGT
    Hi Nima, Pointer
    I installed the profile you too made (amc jumpers set to Joyr-dip), I can load it but don't know if i can use it also for r-factor? I tried this but when i start the game the left wiper goes down and the right one goes up when i give a little bit of throttle.
    Is this because its only for Iracing?
    I tried to build my one profile and it is working in sfgt style but i want to create one in joyr style and if i due it is working for one address.
    example:
    left wiper 25 positive, right wiper 25 negative. this works correct wiper react how it is supposed to be.
    If i ad for instance left wiper 27 + and right wiper 27 - , the system gets confused with the rules of input 25.
    My wiper will go all crazy in the game r-factor but not when i move with the sliders in profiler.
    I would like to use your already made profile because it looks realistic in the video of pointer. But i don't have Iracing and like to use if for R-factor.
    Any help would be appreciated,
    thx Pim
  5. pointer4
    pointer4 Member
    Hungary
    276Coins
    I upload an rfactor setup tomorrow, different games, need different setup.
    Stand by!
  6. pim
    pim New Member
    system engineer
    nederland, brabant
    380Coins
    Ok thanks Pointer, can't wait :thbup:
  7. pointer4
    pointer4 Member
    Hungary
    276Coins
    I'm sorry, I did not have time to deal with this today.
    I would have finetune this yet, i do it on a weekend, i promise.
  8. pim
    pim New Member
    system engineer
    nederland, brabant
    380Coins
    thanks I will try this and will see the next final one somewhere after the weekend.
    Thx again,
    pim
  9. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Hi Pointer,
    Got your profile to work, calibrated, but when I hit the breaks the seat goes backwards, when i hit the gas i sink forward. Turning seems to be right but not accelearation and decelleration, do you know what setting i should adjust? I have 2 wipers, left side facing right and right side drive facing left, JRK setup.
    appreciate any help you can provide.
  10. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Check the 'Invert' checkbox in the mathlines for Effect 27 (Longitudinal Force). You will likely also need to do the same for any pitch effects.
  11. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    thanks bville, I'll check tonight!
  12. AguNicoGaby
    AguNicoGaby New Member
    68Coins
    2DOF, 3DOF, DC motor, SimAxe, SimforceGT, Motion platform, 4DOF
    Gracias! Lo voy a probar
    Thank you! I'll try it
