3dof, AC motor.
Discussion in 'DIY Motion Simulator Projects' started by vulbas, Jul 17, 2010.
  1. Frakk
    Frakk Active Member
    328Coins
    Re: 3dof, AC motor. axes combined ?
    And it also saves a lot of room with very nice thumbnails that can zoom! :)
  2. pathetic
    pathetic Member
    - 38Coins
    congr. for your good work.
    I ve finally started working with AC motors.
    are not your motors slow? or do you think the feeling will be enough ?
    cause i couldnt decide the rpm of reducted side of motor.
  3. vulbas
    vulbas Active Member
    france
    1,103Coins
    AC motor, 6DOF
    Thank you.
    The motor speed is sufficient. It may slightly increase the speed with the drive ( variateur ).
  4. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    HEllo can you write to me an exactly type of moteur? it is 3phase motor or motor with changeable frequency?thanks lot ..
  5. kermit
    kermit Member
    0Coins
    Very nice build,
    Just a little remark
    It looks like the connection between rod and frame is a bit weak
    the u beam already starts to bend as the bold is pulled tight,
    I wonder if it will sheare off on the weld when real forces are applied
    What are you using as a frame (size of beams),do you know total mass?
    speed of the frame is depending on :
    speed of the motor
    Gear-ratio of the drive
    and distance between motor axle and pin of the rod.
    And distance between pivotpoint and rod connection
    example
    motor speed 1500 rpm
    gear-ratio I=40
    drivespeed will be 37,5 rpm or 0.625rp per second(this speed is free running)
    It also depends on the strengh of the motor and force/speed for needed motion.
    I`m also building a motion platform for a real cessna fuselage(2DOF), total moving mass around 350 kilo or aproxx 775lbs
    For now the upper and lower frame(1200x2200mm)
    is ready , using beams 50x50x4mm and 40x40x5mm.
    calculated for 1,500kgs weight ratio, so very strong.
    Also I have 1 one drive ready for action
    3ph 220 volts 1.1 kw motor on a I=40 ratio wormwheel drive
    I`m saving for an other one and frequentie inverters.
    regards Henk
    could you state make/rpm details of motor and gear-ratio
  6. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    Here are the specifications of the engine
    >> a) Motoréducteur coaxial
    >> Moteur CA triphasé 0,55 kw. 1500 tr/mn. 230/400 V. IP 55. Cl F.
    >> ( moteur standard sans frein )
    >> Rapport de réduction : 1/99,21
    >> Vitesse de sortie : 14 tr/mn
    >> Couple de sortie nominal : 347 Nm
    >> Arbre de sortie de diamêtre 25 mm x 50 mm
    >> Référence à rappeler : MV 173 / 71 C 4 / 14 tr/mn
  7. kermit
    kermit Member
    0Coins
    Thanks for the info,
    what are you using for pid control or positioncontrol.
    What problems did you encounter while setting up the electrics?
    So I can understand and adept to the problems
    (please write in english or german)
    I can`t read French sorry
    regards Henk
  8. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    I am on vacation and not home, my simulator is on stand-by. for the posistion I think I'll use it http://www.megatron.fr/composants/posit ... ab40_f.php the programable version but the price is heavy 135€. no problem for the connection but I was helped by Scott and riton
  9. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    thanks vulbas.. it means i need only standard 380v motor with 550w and 14tr/mn? and thanos electronic or velleman k8055? i dont know why are you using omron mini j7?this part is for what? we´ve got 380v here in czech. and can i connect thiis all with xsim profiler?what part is changing the direction of motor? my h-bridge?
    Mila Czech
  10. lotada
    lotada New Member
    coffe Roaster
    Kralupy nad Vltavou
    248Coins
    Here is a company in which i founded asynchronous motors. and some gears, frequency changers. is it able to use it for the 3DOF, 2DOF simualor platform?
    http://www.leroy-somer.com/
  11. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    I return finally,
    I'll download all the photos on the forum.
    if you want to see more photos go to imageshack in my signature
    bon aller on continue un peu la peinture
    we continue painting
    le squelette
    the skeleton
    vue de dessus du support enceinte
    top view of the speaker stand
    vue de coté
    side view
    fixation de la barre de support des enceintes
    the support bar speakers
    l'angle donné à cette barre, j'ai mis un coup de meuleuse pour faire un sillon et plié
    the corner given to this bar, I put a shot grinder to make a groove and bent
    les enceintes avant en place
    the front speakers in place
    il me reste à placer les deux ventilo de 120 ou 140mm, j'hesite un peu sur l'emplacement... des idées ?
    I still have to put both fan 120 or 140mm, I hesitate a bit on the site ... any ideas?
  12. vulbas
    france
    1,103Coins
    AC motor, 6DOF
  13. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    hello,
    my project is in standby because the baby arrived, but i received my poti of megatron.
  14. vulbas
    france
    1,103Coins
    AC motor, 6DOF
  15. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    ça avance petit à petit,
    je suis aller chercher de quoi fixer mes potar et poulies
    that advance gradually
    I'm going to find something to fix my pots and pulleys
    j'ai reperçer les poulies de 25 dents pour que l'axe central soit au bon diametre (6mm)
    j'ai acheté de bonne lame de scie à metaux pour decouper le simu :bad3:
    suite au prochain episode 8)
    I redrilling pulleys 25 teeth to the central axis is the proper diameter (6mm)
    I bought a good hacksaw blade to cut through the simulation: bad3:
    after the next episode 8)
  16. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    de mon coté je me suis motivé et j'ai attaqué ma boite à carte et variateurs.
    on my side I'm motivated and I pushed my card box and drives.
    in place
    avec la carte
    with the card
    j'ai mis des spacer pour surelever la carte
    I put the spacer to raise the card
  17. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    hello,
    I made it simple to start. same effects on all axes. it's good.
    http://www.youtube.com/watch?v=92q6wj6Ax0c
    someone he can create this for a 3DOF?
  18. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    j'ai fixé les potar et tout fonctionne de ce coté. la réduction est la bonne, 44 dents 25 dents (merci riri)
    I fixed the pot and everything works on this side. the reduction is good, 44 teeth 25 teeth (thank you riri)
    sur celle ci on vois que ça passe à 2 ou 3mm
    on this one we see that it goes to 2 or 3mm
  19. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    we appreciate your pictures.
    However, server space is limited, so please consider if it is really neccessary to post 4 highres pictures of a potentiometer, or 8 high res images of your freq.inverter mounting plate in just slightly differnent angles. Thanks
    Regards
  20. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    sorry. I do the housework ;)
