Starting out on my project
Discussion in 'DIY Motion Simulator Projects' started by Dicky, Apr 11, 2026 at 18:34.
  1. Dicky
    Dicky New Member
    Saturday
    18Coins
    Hi everyone, I'm new here and I'm just starting to build a 2DOF simulator with Arduino. Could someone please tell me where I should start? Thanks in advance for any advice.
  2. Dicky
    Dicky New Member
    Saturday
    18Coins
    Hi everyone, I've started this project. I'm about to test it with the SMC3, but nothing moves when I set it to motion or manual. Can anyone help me? Thanks to anyone who can give me some advice.
    154,648Coins
    +11,190 / 57 / -2
    Can you please post pictures of all your SMC3 settings and detail the control hardware being used.
  4. Garrett
    Garrett Member
    189Coins
    I know you cant post photo's initially, but please do once the forum rules allow you to do so.
  5. Dicky
    Dicky New Member
    Saturday
    18Coins
    I'm building 2dof taking inspiration from scruck's tutorial, using arduino uno r3, two ibt7960 and angle sensors.
    I followed the SMC3 setup from the tutorial for motors 1 and 2:
    step 1;
    fpid/1;
    kp=300;
    Ki=0;
    Kd/Ks=1;
    Fpwm=20kHz;
    PWMmin=0;
    PWMmax/PWMrev=130;
    Max Limits=10;
    Clip input=200;
    Deadzone=0.
    154,648Coins
    +11,190 / 57 / -2
    Is the code set to Mode 2: https://www.xsimulator.net/community/threads/problems-with-my-simulator.15382/#post-207320
    If so, at what point in the setup steps did it fail to respond as expected, using the suggested settings?
    8. Set Kp to about 400
