100 Amp Motor Driver Wiring Help 3DOF
Discussion in 'DIY Motion Simulator Projects' started by Jon Amico, Jan 17, 2026.
  1. Jon Amico
    Jon Amico Member Gold Contributor
    416Coins
    Hello! I appreciate any and all help in advance..
    I Read somewhere that the IBT2 motor controllers can burn out / or cause issues so went ahead and ordered the 100 Amp dual Motor controllers for my 3 DOF Build.. So 2 should work for the 3 motors..
    Im now not finding that thread or can I find and an updated wiring diagram..
    Can anyone help me match the colors Im missing?! Pic attached
    https://www.dropbox.com/scl/fi/ufk9...ey=eoyznl6c9ipmpb47qq2al3w9y&st=1wwvvhdv&dl=0
    I need to run 2 motors on one of the controllers..
  2. Jon Amico
    416Coins
    If I had to guess I go Yellow (LBW) goes to PA on the 100Amp, then the R_EW and L_EW go to A1 and A2?
    154,508Coins
    +11,184 / 57 / -2
  4. Jon Amico
    416Coins
  5. Joe Cortexian
    1,616Coins
  6. Jon Amico
    416Coins
    Yeah.. Trying to make the wheelchair motors work as they are what I'm have at my disposal.. Already spent too much money..
    I should have been more patient and tried saving up money… But I can’t seem to do that… Lol. "Cheapest and fastest… I’m sure I will upgrade it at some point… lol
    And Way Past that… Pic Attached..
  7. Jon Amico
    416Coins
    Downloading SMC3 today… I’m thinking the attached Wiring should work..m
  8. Jon Amico
    416Coins
    Well Almost got it... I had to go back to Mode 1 with the 100 Amp Controllers.. at first, they didn't work.And just shook vigorously and cut off.. i've been went back to the IBT2 and got one of the motors working properly..
    I then tried to go back to the hundred amp controllers, but nothing would work.And I would only get spinning on one motor..
    I found to try Mode1 and that works four, the controller that only has one motor on it.. but the other controller one motor spins and the other doesn't work..
    I i found to try the opposite positive negative on the spinning motor.. so I will try that when I get home.. but if anyone else has any advice on getting the controller with two motors wired correctly?! I did a continuity test for all the wires, and they should be hooked up correctly with continuity...
  9. Jon Amico
    416Coins
    Update.. I Finally got a chance to mess around And changing the positive negative on the moving motor worked! With some tweeking....
    After switching the wires, it did the vibrating thing that I had already seen.. So I then l messed around with the settings in the 3MC Sofware and got all 3 motors to seemingly work correctly... Lots of jitter to remove but think I found setting that work pretty Smoothy on all 3 motors..
    I did have two motors that were from a different source, so maybe the one motor was wired different?! But either way, switching it to mode one and changing the wires on the motor that was spinning after doing that worked with some code tweaking..
    Work has got a hold of me. So I haven't been able to do any videos or posts, but still plan on doing a full build thread Soon..
  10. vistol5100
    vistol5100 New Member
    151Coins
    I've been following your posts! I'm planning to upgrade my 3DOF setup to a 4DOF by adding traction loss, and I really love the design you've come up with
