Question Dirt Rally 2.0 weird min and max values
Discussion in 'SimTools DIY Version' started by Nicki9knuckles, Jan 12, 2023.
  1. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    818Coins
    Hi there, I am getting some really weird values when I try and run Dirt Rally 2.0. I tried in both Simtools versions and both show different values. Fyi this is after me carfully driving without hitting anything and going around a few turns and hills. When I run this profile at full intensity level, my motors just jump around. I tried lowering it to 80 and nothing is moving in a logical way, like the axis3 is shifted to one side, and my axis 1 and 2 are not really moving. Not sure if anyone ran into this before. And the roll input is NAN in the new SimTools. Not sure why that would be.
    Thanks!
    dirtrall2-werid-min-max.JPG dirtrally2-axis-settings.JPG dirtrally2-ols-simtools-weird-capture.JPG
  2. yobuddy
    51,706Coins
    Looks like the same problem in wrcg, I will take a look.
    Thanks!
  3. Nicki9knuckles
    Web Developer
    818Coins
  4. Nicki9knuckles
    Web Developer
    818Coins
    @yobuddy just a heads up that this seems to only be an issue with the plugin inside of SimTools v3. I was just testing SimTools v2.5 with Dirt Rally 2.0 and it works like a charm.
  5. yobuddy
    51,706Coins
    @Nicki9knuckles,
    I pushed a new Dirt Rally 2.0 v3 plugin to the repo earlier today, maybe let it update and give it another shot.
    Thanks buddy!
  6. Nicki9knuckles
    Web Developer
    818Coins
    hey @yobuddy I just gave the update a try. I seen it was available in Simtools v3, and downloaded it. Then I booted up DR2 and got though all the menus but as soon as I get to the race, Simtools crashes. I reproduced this the 2 times I tried, booting it up a second time and relaunching DR2.
  7. Nicki9knuckles
    Web Developer
    818Coins
    @yobuddy let me know if there is any logs or anything useful I can send you to help if you want.
  8. yobuddy
    51,706Coins
    Please remove the plugin all together and restart v3.
    Then reinstall the plugin and give it another go.
    (It's using different patching now, so I think it did not patch correctly is all.)
    But we will see :D.
    Chat soon!
  9. Nicki9knuckles
    Web Developer
    818Coins
    hey @yobuddy ! You were right! Uninstalling the patch first fixed it, things are working perfectly now. Nice work!!
  10. james wheeler
    - 75Coins
    @yobuddy
    I am having a similar problem possibly. It started out of no where as far as I can tell. The values in Dirt 2.0 are acting erratic with no consistency.
    Changes I have made recently are swapping my old g25 to a PXN V10 ULTRA. Since then I have reverted back to the g25 and removed all traces (I am hoping) of the pxn.
    To try and self fix this I have;
    Uninstalled the plug in, exited simtools 3, started simtools 3 and reinstalled the plugin.
    Then Uninstalled the plugin, uninstalled dirt2.0 Reinstalled DR2, did a race and reinstalled the plug in
    Then looked into the hardware file with notepad and changed the port to 4123.
    I have uninstalled Onedrive.
    I have tried Project cars and found that it does not share the same issue.
    Before I reinstall simtools itself I would like to know it there is something else I should look at.
    The added video shows what I am talking about and also the simtools crashes once I close the game.
    The added Picture shows my hardware config file.
  11. james wheeler
    - 75Coins
    is there suppose to be a custom <<SimToolsCustomUDP.xml> file in motionplatforms folder?
  12. james wheeler
    - 75Coins
    Also If I Alt-Tab out of DR2 and minimize it then start capturing the value they still are changing. heave got up to 17771.6
