  1. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    it's a long time ago I build my simulator with this Interface.
    Its now time to give him a second life, as for me it is collecting dust. I will gift this to a friend.
    In the past I build a controller Box with 2 Monster Moto shields, one per motor. As i had little knowledge, and acces to tools, my controller box is quite ugly. I know managed to short one Monster moto while trying to remember which cable goes where ^^
    I was lucky and found a spare Moto Monster shield which i had ordered years ago. I am using the popular 90 ZYT Motors with MCP4 gearbox.
    Before it was a platform Simulator, which is now converted to a seatmover. Did any of you have any experience if one Monster Motoshield will be enough for both motors, or should I stick with one shield per Motor.
    If I understand it correctly, each channel of the Shield can supply 30A to the Motor peak. The motor is ratet at 23 Amps per label, so in theory one shield should be enough.
    I also have the pololu equivalent laying around, which maybe a better option than the cloned aliexpress monster moto.
    153,788Coins
    +11,150 / 57 / -2
    Clone MMs have long fallen out of favor with members.
    Member experience has led to the advice that even brand new clone MMs requires testing: https://xsimulator.net/community/faq/monster-moto-testing-before-use.158/
    I would suggest 1 MM per motor if they pass testing. The JRKs may be a better option. There are also other possibilities, for example: https://xsimulator.net/community/faq/reasonably-priced-100a-motor-controllers.412/
  3. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    I am aware of the issues with faulty clones, and tested this one years ago so it should be fine. Since the actual failure occured because of my wireing fail, I will replace the one defectrive driver. They worked flawless in the past when the sim was in use.
    If they will fail I will upgrade to another driver. Thanks for pointing me to the 100A driver. This should be a proper replacement for the future.
  4. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    While searching a little bit, i found this drivers: [​IMG]
    From the specs it looks got for me to drive both of my motors. Has anyone any experience with these drivers? They are a little bit easyer to source than the 100 A ones. It says 60A per channel.
  5. Mirko
    Mirko New Member
    29Coins
    2DOF, DC motor
    This is an amazing idea for a father and son project. I wonder, if there is a chance to get the source code of SMC3 and SMC3Utils. Does anybody know, where to get it from?
  6. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    you can get it on the first post of this thread :) at least the smc3 source code for the arduino. The Utils is only avalible as an executable as far as i know
    153,788Coins
    +11,150 / 57 / -2
    If I recollect correctly @RufusDufus confirmed the loss of the SMC3 utility source code many many years ago, as the result of a corrupted drive.
    Only the Arduino SMC3 Ino files remain, but those are the important bit and have been modified by many others over the years for different hardware.
  8. Mirko
    Mirko New Member
    29Coins
    2DOF, DC motor
    That is really a pity
    Ad we haven’t checked the Arduino code yet, we will dig into it.
    I am just wondering, if all the information provided by SimTools will arrive at the Arduino as well - like shown in the attached image.
    153,788Coins
    +11,150 / 57 / -2
    SMC3 is for configuring and tuning the hardware range/response, a SimTools plugin is totally separate from that, in that it allows available game telemetry and tuning of that within the hardware parameters/capabilities, be those set by SMC3 or others.
    Spend some time perusing the FAQs to get a bit of an overview: https://www.xsimulator.net/community/faq/
  10. Nailson Roveta
    Nailson Roveta Nailson
    Retiree
    Serra, Espírito Santo, Brazil
    57Coins
    Hello. Taking advantage of the subject, I'm trying to modify the SMC3 to be able to read my AS5600s via I2C and I've come across the following situation. It seems to me that the SMC3 is not prepared for the IBT_2 drivers. I always thought that the IBT_2 drivers needed two PWM signals. One for RPWM (pin 1) and another for LPWM (pin 2). It turns out that in the SMC3 layout, RPWM is connected to pin 9 of the Arduino, which is PWM - perfect, but LPWM is connected to D2 of the Arduino Uno and this pin is not PWM. Had anyone noticed this before? Would this improve the quality of the movement in our simulators?
    I apologize if my perception is wrong. Best regards
  11. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    Hello, interesting.
    May I ask why you want to include the reading over I2c? I just installed some AS5600 today as a replacement for halleffect pots in the normal Analoge mode and they working fine. You need some thinking for mounting to set the zero position, but this was easy done with a rotatable 3d printed holder.
  12. Nailson Roveta
    Retiree
    57Coins
    Hey, thanks for replying. My simulator already uses the AS5600 in analog mode (I also used a rotating support made in 3D). The intention of using I2C is to eliminate noise from interference, since analog signals are more susceptible to this problem. Besides, it provides greater accuracy in the information. Actually, I wanted to validate this theory. My question is more about how the SMC3 manages to do PWM on pin 2? My impression is that PWM only exists in one direction of motor rotation; in the other, it's either 0 or 1.
  13. Nailson Roveta
    Retiree
    57Coins
    This is the proposal:
    Using the AS5600 via the I2C interface offers significant advantages compared to analog output, mainly in terms of accuracy, resolution, and ease of integration into digital projects. While analog output converts position into a voltage (0 to 3.3V/5V), I2C provides direct 12-bit digital data.
    Here are the main advantages of using I2C over analog on the AS5600:
    Higher Resolution and Accuracy:
    I2C: Offers 12-bit resolution (4,096 distinct positions per rotation), resulting in 0.087° steps.
    Analog: Although the chip has 12 bits internally, the analog output depends on the accuracy of the Analog-to-Digital Converter (ADC) of your microcontroller (e.g., Arduino Uno only has 10 bits), which generates losses.
    Noise and Distance Immunity: Analog output is susceptible to electromagnetic interference and noise, especially over long cables.
    I2C is a digital protocol, which makes angle readings much more consistent and immune to noise, allowing for more robust communication.
    More Information Available (Diagnostics): I2C allows reading internal registers that indicate the magnet's intensity (magnet status), which helps to verify if the magnet is too close, too far, or correctly positioned (0.5 to 3 mm). The analog output does not offer this diagnostic facility.
    Programmability and Configuration: Through I2C, it is possible to configure non-volatile sensor parameters, such as setting the zero angle, the direction of rotation (clockwise/counterclockwise), and the maximum/minimum output range, without needing a dedicated programmer.
    Ease of Use on the Bus (Multiple Sensors): You can connect multiple AS5600 sensors on the same I2C bus, using few microcontroller pins (only SDA and SCL), while the analog output requires a dedicated ADC pin for each sensor.
    Summary: I2C is ideal for applications requiring high precision and monitoring, while analog mode is limited by signal conversion and sometimes by a "dead band" at the output.
  14. Joe Cortexian
    1,537Coins
    The timing of the I2C is going to compromise your cycle time. You have 250us to read three values. Do a simple test (not SMC3) and look at the timing. Does the update rate really need to be 4k? Perhaps not but after harboring similar plans for the A5600 I gave up after doing that test.
  15. Nailson Roveta
    Retiree
    57Coins
    Hi, thanks for the interaction. I did many tests and also gave up. I couldn't get SMC3Utils to connect at all. Exactly for the reason you mentioned. They'll remain analog. I took the opportunity to make a nice improvement to my cockpit. I separated all the power cables from the data cables. Impressively better. Now there are two cable glands, data on the right side and power on the left.
