FlyPT Mover 3.7.0.14
  1. pmvcda
    15,422Coins
    Are you using 19 bits?
    Edit: Are you using WYBOsimu as a controller?
  2. dzq_stone
    dzq_stone New Member
    3Coins
    In fact i only want to move longer, due to the resolution of AMT102 is 8192 pulses per revolution, so if the output range is 19 bits the pulse will be 524,288, it will twist the ball screw 64 times, but current situation is still move tiny. so i think maybe the other parameter i didn't set correct.
  3. Deleted member 38270
    Dear colleagues, I've been using FlyPt for years. I'm very happy with it. I have a question: is it possible to use the platform from photos?
    If so, could you tell me where I can find such a tool?
    Best regards, Tadek
  4. PavelF
    PavelF New Member
    64Coins
    Version 3.7.0.14. I created a settings file and saved it. It gives an error when loading. The settings file is in the application.
    It was also saved as default settings. When I tried to launch the program, it froze, preventing me from doing anything. Manually deleting references to FlyPT in the registry helped.
  5. PavelF
    PavelF New Member
    64Coins
    Another error. When disconnecting from MSFS2024, an error message appears.
      113.8 KB
      17
  6. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    Same here.
  7. Erik Green
    Erik Green Member
    341Coins
    Is there a solution for Motion Compensation using triple screens and Movers compensation output?
  8. PavelF
    PavelF New Member
    64Coins
    What are these filters for? I assumed that the pose data would be filtered before being sent to the actuators. This doesn't work in version 3.7.0.14.
    I'm setting up a logistics filter, but the platform's movements are outside the set limits.
    Am I missing something, or is this a bug?
  9. PavelF
    PavelF New Member
    64Coins
    Selected the item.
    Received an error.
  10. J-1775
    J-1775 Aviator
    1,582Coins
    Hi Pedro. I noticed that from 3.7.0.10 on I can't load profiles saved with earlier versions anymore. That is, the modules are loaded, but with default values. That isn't a tragedy, as I can load a second (older) instance of Mover and copy'n'paste values or whole filters ─ I've done this before.
    However I wonder whether there is some caveat when doing this? There must be some reason why a simple migration is not possible anymore...
  11. PavelF
    PavelF New Member
    64Coins
    Hi!
    The logistic function doesn't work in this formula: LOGISTIC(EMALP(EMALP(EMAHP(VALUE;2000);72);1200);160;1) . Am I doing something wrong?
  12. PavelF
    PavelF New Member
    64Coins
    I tried replacing it with LOGISTIC3. It doesn't work either.
