Horse Riding Simulator
Discussion in 'DIY Motion Simulator Projects' started by apple, Oct 16, 2025.
  1. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    Overall Project Goal: Create a Horse Riding Simulator
    Detailed Project goal: I want to try to create a Horse Riding Simulator (incl. VR Environment) which simulates the basic movements of the horse (three gaits) and can be controlled by the rider itself but also by the instructor. It contains therefore sensors for leg and rein pressure and a control interface for the instructor.
    My personal goal regarding this challenging project: Just start the learning journey, learn new things, do something useful. As of now I don't expect that I reach the project goal.
  2. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    Currently I am investigating if the stewart platform concept is the right approach to simulate the horseback movement. I am trying to understand the mechanism of the platform and therefore looking for a virtual simulation as it is shown in this video 'Stewart platform design and prototype' on YT (can't post the link). Excel based simulation.
    Does anyone know where I can get such file or (free) access to a ready simulation software?
    153,914Coins
    +11,156 / 57 / -2
  4. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    Thanks, I will have a look into it!
  5. long16652
    long16652 New Member
    - 220Coins
    I don't think the dynamics of a horse are complicated, and two axes should be able to simulate them well.
    • Optimistic Optimistic x 1
  6. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    Are you a rider?;) Actually the part where the saddles lies on (thorax vertrebrae) is not that flexible. it does rotation, bend, heave, forward, backward, shift. but the tricky part is the impulsion which comes from the four legs when touching/leaving ground. in every gait it is different. trot is the easiest one because it is a symmetrical two-beat rhythm. walk is four beat and therefore rather complex.
    153,914Coins
    +11,156 / 57 / -2
    Have you considered options like pneumatic motion options: https://www.xsimulator.net/community/faq/gseat.20/category
  8. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    No, not yet. The only thing I know about pneumatic that it is more expensive than linear actuator (when I am right or do i mix it up with hydraulic?). But I will investigate on that. Thanks for the input.
    153,914Coins
    +11,156 / 57 / -2
    Pneumatics with bladders and RC servos is very cheap. An upside is that they can simulate a sustained force that may suit some of what you described, but likely augmenting an actuator driven rig.
    While I am not a rider I have been on a horse and the motion is part in how a saddle moves, plus the physical contact through the legs against the horse, which is where bladders may be of use.
    The other part that may also be worth considering is wind simulation: https://www.xsimulator.net/community/faq/fans-wind-simulation.67/
  10. Doon1
    Doon1 Member
    391Coins
  11. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    Thank you. I investigated on that solution and it seems to be a suitable approach: softness, power to keep something in position, cheap, not very precise
    I definitely will keep this in mind.
  12. apple
    apple New Member
    58Coins
    Arduino, 6DOF
    No barrel racing, no jumping ;)
    It looks so good! Getting something like this would make it a lot easier. I am currently trying to visualize the type of movements (degree, distance, speed) which i need to simulate. I hope this will help to figure out if such a system would be suitable.
    do you know how the general steering concepts works? i don't think i will connect to a driving simulator software.
    in my prototype i use arduino ide. i am planning to do the vr environment with unity.
  13. Chris_Beeves
    2,165Coins
    Awesome project!
    You mean to make the software and physics yourself?
    Considering the different gaits, the different rhythms aren’t related to degrees of freedom in the motion. I’m sure riding could be reasonably simulated with a pitch/roll platform. However, heave and surge are involved in trotting or canter.
    Honestly, the hardware will most likely be the easy part once you start modeling something as unreliable as horse physics.. Vehicle dynamics modeling is hard enough when the vehicles aren’t stubborn biting beasts. :grin
  14. accelero
    accelero Member
    france
    287Coins
    2DOF, AC motor, Arduino
    hi, nice project
    do you plan starting directly with VR or begin with a screen displayed 3D First person game?
    i am on such a project for years, the IMU sensors use has been of great help, not using data directly. After multiple filtering and calculations , i have been able to get a good model of different gaits, first step was to implement it on a 2 dof platform( NJMotion) , which was a nice learning journey.
    Second step is to go to 3 dof platform with linear actuators ( aluminium frame, thanos board, sfx100 like actuators)
    the hardware is indeed the easiest part. developping the usefull software that could be coupled to Unity is on air, but really tough :)
  15. accelero
    accelero Member
    france
    287Coins
    here is the NJ motion based simulator
  16. accelero
    accelero Member
    france
    287Coins
    here is the project from Rice University,
    nice try, huge work for young engeeners but you can see that lomocotion is a bit weird , the use of non filtered data from IMU is probably one of the reasons
