SMC6 - 6DOF Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by Gadget999, Jul 8, 2022.
  1. Gadget999
    12,007Coins
    Hi guys,
    just want to confirm that everything is working
    all the computer needed was a reboot after installing simtools !
    the correct syntax as @yobuddy mentioned is TGT<Axis1a>,<Axis2a>,<Axis3a>,<Axis4a>,<Axis5a>,<Axis6a>
    thanks for the help :)
  2. Gadget999
    12,007Coins
    Here is a video with the F3 tub fitted
    It looks like it has the power to lift the whole car not just the tub !
  3. Gadget999
    12,007Coins
    heave step test - the sim is moving in small steps
    the tub is carbon fibre approx 35kg, the base is many times heaver
    the base is lifting off the ground
    need to find someone brave enough to get in it LOL
  4. Jeroen
    Jeroen DoctorXeno
    Holland
    - 61Coins
    This is a very nice project Gadget999. The cheapest way to build a 6dof in my opinion.
    Looks quite accurate if you ask me. I like your approach with the controller/software
    and h-bridges.
  5. Gadget999
    12,007Coins
    The project is on hold for a short period whilst I order a new motor driver
    I tried a new power supply and it gave off a lot of noise - the circuit board interpreted the noisy signal as movement on the encoders - it tried to move the motors to many different random positions very quickly and it looks like a motor was driven in both directions at the same time - the motor driver did not like it !
    I will code a filter so that the encoders can only count so far in one control cycle - if its above a certain threshold the motor will stop with an error code
    next job is to fit a OSW mige ffb steering wheel and hydraulic pedals
  6. Arta Yasa
    Arta Yasa Member
    824Coins
    Did u will sell the board or hex code and firmware?? I have wormgear 1:60 6pcs. Yes its before for motion also. But the motor is ac servo drive, i cant find the driver. Thank u, very interest. Good luck mate. Ur smc3 verry great also
  7. Gadget999
    12,007Coins
    The code is designed to work with a Dc motor not a servo drive
  8. Arta Yasa
    Arta Yasa Member
    824Coins
    O
    Whh, need to change the motor, how about if encoder 1024ppr??
    Is your code free like SMC3 before??
  9. Gadget999
    12,007Coins
    it will work with any encoder - but needs a DC motor
    PWM and direction
    the code is not open source
  10. Arta Yasa
    Arta Yasa Member
    824Coins
    How much for the board mate?
  11. Gadget999
    12,007Coins
    Its not currently for sale till the project is completed - its been on hold for various reasons, however we are looking to restart the project very soon
    everything is working well with sim tools
    I am going to program a start up routine to get the encoders to do a homeing procedure for safety and then the main loop will start
    The next step is to build another DD drive and get it fitted so the tub can be used by a driver
    I will tackle that soon enough
  12. Arta Yasa
    Arta Yasa Member
    824Coins
    Nice mate, for me just need for the motion, for now still using ur smc3. Its realy amazing, but i plan to build 6dof and see ur smc6. But my motor was pmsm with gearbox, so just need change the motor or make driver for pmsm suport pwm dir right??.
    Also for DD wheel i used AC servo 10Nm peak 30NM. With combine vesc and EMC tools mate. So far its good,
  13. Gadget999
    12,007Coins
    last wheel i built was a mige with aasd driver and VNM simultion board
    the board is pretty good and will work with other servo drivers
    next wheel will be a mige driver / mige motor and VNM board
    pedals will be thrustmaster with a hydraulic brake conversion
  14. Gadget999
    12,007Coins
  15. Arta Yasa
    Arta Yasa Member
    824Coins
    Nice man, have u try the mige with vesc?? Its more cheaper. But i dont know vnm suport vesc or no. But EMC are suport .
    Hope u give the info later when ready about smc6 sir
  16. Arta Yasa
    Arta Yasa Member
    824Coins
    Damn good man, i was have 4 actuactor only but without driver servo, that way still loking for the other servo, i have panasonic minas A5 its suport step dir also but dont have torque reach ( vnm need it for limit stop) also the encoder resolution is 20bit ABZ its mean 1milion++ ppr, they say over kill for motion
