First Build, Wood 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Bandersnatch79, Jan 9, 2025.
  1. Bandersnatch79
    Bandersnatch79 New Member
    85Coins
    Evening Kings,
    I'm ready to get started, full of loosely thought out plans. The idea is a simple seat mover, a la DOF Reality H2. I'm going with the amazon motors, 24v / 50:1 / 35nm, run off a battery, IBT2, not sure if i'm going to do potentiometers or hall effect sensors, not 100% on how to execute the CTC levers but I have Ideas. More to follow on all that, first I want to finalize the design and fabricate most everything then do all the motors and electronics. Attached are my first rough drafts and SimCalc results. Excuse my Blender skills, just learning. I guess my first question is do you see any glaring errors? I think I'm getting the most I can out of the design. Screenshot 2025-01-09 170751.png Screenshot 2025-01-09 170946.png Screenshot 2025-01-09 164614.png
    Not certain about the pitch and roll degrees, while I've read Norbeast say less is more in VR as long as it is quick, is 9-10 degrees enough? I am limited by my U-joint to about 15-17 degrees so I was hoping for 14-15, I believe the H2 is 20. But if more experience says 10 is enough, I'm good with that.
    I am also wondering if the seat should be flipped around so the motors are in the back and not in the way. Thoughts please, especially on the SimCalc numbers. I'm not married to anything in the design except simplicity. Thanks in advance
    PS Inspired by RomanDesign and Joe Cortexion(I don't now how you @ people on here)
    151,668Coins
    +11,045 / 56 / -2
    I am looking forward to following your project :thumbs
    Tagging a member is as easy as adding @ to their user name: https://www.xsimulator.net/community/faq/tag-a-member.73/
    People choose various designs for a range of different reasons and simplicity is a good criteria. A knee mount design gives away a little with respect to inherent design leverage.
    The motors mounted vertically may create some interference issues with the top frame.
    Personally I do consider 180 degree Hall sensors the better option, even though there are a little more expensive, as they can be easily direct mounted, have great resolution, won't break if over rotated and have a lifespan.
    With a base mount design the movement experienced is multiplied by the height of the the seat back.
  3. Bandersnatch79
    85Coins
    @noorbeast Thanks for the tip. Tracking on the possible motor interference, they can/should lay down.
    In regards to the knee mount, my first instinct had been to tuck them back in a true compact design like your(really nice looking rig BTW)It would definitely be easier to get in and out. But I didn't like the numbers I saw in Simcalc, more likely I didn't understand them. I just took another crack at it and...it seems better. Screenshot 2025-01-09 234201.png
    Picture the motors laid down.
    Moving the mounts to the 12 and 12 position still maintain near max efficiency, seemingly good force? and more pitch and roll than the knee mount. I like this. Are the lower torque values good or bad?
    151,668Coins
    +11,045 / 56 / -2
    A compact rig has even less inherent design leverage, so requires motors with lots of torque for larger users.
  5. Bandersnatch79
    85Coins
    In reference to Simcalc numbers, how do the pitch torque and roll torque values effect the rig? Is higher or lower better?
  6. Joe Cortexian
    1,087Coins
    The leverage is based on the length of the lever arm and the distance of the attachment to the center of rotation. So the attachment under the seat (your second post) has less leverage than at the wheel. I found that 70mm was fine but at 80mm I started to have problems.
    My rig is very stiff at the front. The back with the seat not so much. So front is a better solution for me. You do have to be careful about interference with the motors. You should maybe add the pedals into your rendering.
    My first prototype had a single 4x6 as the backbone. My early videos showed me how much that support beam was flexing. It worked I just hated the flex. Hence the two 4x6. Of source I am moving the wheel and pedals which is a quite a bit of weight,
    Encoder: I use “multi-turn” Hall effect devices. There is no coupling. They are hard to center but I made a simple mod to add in an offset in SMC3. I would be happy to post a STL file for the mount. Very important to precisely center the magnet behind the sensor.
    Attachment of levers: When what I have fails and I have to redo it I will get them welded. I don’t own a welder but it’s pretty easy to take the shafts and your lever arm to a friend to have them welded. My welder friends seemed to think it would not be an issue. I use 1/8 steel for lever arms.
  7. Bandersnatch79
    85Coins
    Thanks @Joe Cortexian Please do post your STLs when you get a chance. I would also be curious to see your SimCalc numbers if you had them handy. When you say 70 and 80mm, do you mean CTC length?
    151,668Coins
    +11,045 / 56 / -2
    The higher the value the less strain on the motors.
  9. Joe Cortexian
    1,087Coins
    I didn’t use SimCalc. I mean the distance from the center of the motor shaft to the center of the Heim joint (the swirly thing at the end of the rod for future google searchs).
    I don’t have the STL handy at the moment but one other note is that you need to scrape a resister off the sensor module so that it outputs analog. You can’t use the digital outputs because it’s too slow like 10 times slower than analog.
  10. Bandersnatch79
    85Coins
    Makes sense. I imagine the number will vary based on design geometry, motor strength, etc, but would you say there is a too low value?
    151,668Coins
    +11,045 / 56 / -2
    Yes the number will vary based on design geometry.
    There are minimum values, but those are dependent on motors and associated calibration of control hardware/software and very difficult to know for sure, you need to over rather than under design, with previous member builds being a useful guide.
  12. Joe Cortexian
    1,087Coins
    If they are too long the system stops working because you are asking too much of the motors and electronics. If they are too short it may not move far enough to suit you.
    Mine failed now and then at 80 mm with the failure being that the ibt-2 cut out. Now it fails rarely but is fixed by cutting power to just the ibt-2. I have a new driver on order which would likely fix this. In any case it’s good enough now.
    So 70 mm gives me a theoretical motion of 14o mm but it’s actually closer to 100 mm. That translates (for my configuration) to pitch of +-9 degrees and roll is +- 13 degrees.
    I did several experiments to determine the optimal length so you may not want to weld it to begin with or drill four holes at 50 60 70 and 80 mm to determine where it starts failing.
  13. Bandersnatch79
    85Coins
    I got the idea today from another post, for initial set up and testing, no weight, I will 3D print them, once I find the sweet spot, I will either CNC them from aluminum(not sure if that will work) or like you suggested, get someone to weld an arm on the shaft.
  14. Joe Cortexian
    1,087Coins
    I cant post STLs here. Here are a couple of design images. The open side allows me to look at the magnet. The diameter of the hole is slightly large than the shaft (18.2mm). The assumption is the end of the shaft is the same plane as the end of the mounting plate (in my case the bearing block. I use the back side to align the shaft with the center of the device. The depth of the pocket is 7mm. That;s 2mm for the device, 2mm for the magnet and 3mm for the gap (in round numbers).
  15. Bandersnatch79
    85Coins
    Hey all, long time no post, I'm getting there, but need some expertise. About two months ago I bench tested my motors and electronics, Battery, 12V 200W motors, Arduino UNO, IBT2s, and AS5600s for position. Everything worked, probably a few hiccups, I don't recall, but it all ended up working. Fast forward, I'm getting everything mounted to the rig for the next phase, and the motors/electronics will not work after reassembly. I can't even get the on/off buttons on the top left of SMC3Utilities to work. I continuity tested all the connections, everything seems to be set up exactly as before. When I manually rotate the AS5600s the green line moves, but when I up the PWMmax the motors will not kick in. I'm sure there is some knucklehead mistake on my end, but I cannot wrap my head around it. Send Help.
  16. noorbeast
    151,668Coins
    +11,045 / 56 / -2
    A few suggestions to try, first set Step in SMC3 to 1.
    Then check the Comm Port is correct in Device Manager on your PC.
    While done with another board in mind use this as a bit of a guide to check the IBT2s actually function as expected, as many have previously reported quality issues, even with brand new units: https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
  17. Bandersnatch79
    85Coins
    @noorbeast COM ports seem to match up, setting step to 1 is easy enough, but what would that effect really? I'll have to read through that post about test. I read something about setting up a test with LEDs and resistors that might be worth trying.
    What I'm stuck on, is what error/mistake/failure would prevent the on/off buttons in SMC3 Utils from working?
  18. Joe Cortexian
    1,087Coins
    My recollection is that the only thing that cause the motors to not turn on is if the read sensor value is beyond the limit. I would assume that you green line in SMC3 is where you expect it to be aka around zero. The function is like Disable1(). I am out of town so I can’t check where it’s called. There must be another condition. Both motors have the same symptom?
  19. Bandersnatch79
    85Coins
    @Joe Cortexian you're brilliant. And I'm an idiot. Part one is solved. When I re-mounted the AS5600s to the motors, i put them on 180 out from where i had initially mounted them. Flipped them around, the green lines popped to the center and i was able to work the on button for the motors. Even got a little noise and movement out of one of them. Then it all went to hell because I probably effed something up trouble shooting. So current issue is one motor indicates "on", green line in the middle, no movement. The other motor, the one that had some life, won't turn "on" and the green line has migrated off center, no movement or life any more.
    More checking. But progress.
  20. Bandersnatch79
    85Coins
    So this is turning into the problem I always knew it would. Situation was, one motor dead, one would run to the stop limit and quit. Replaced both H-bridges. That seemed to fix runaway motor. Dead motor still dead, thought I tracked that down to Pin 3 only putting out~2-3V. New Arduino. Pretty sure I fried that one because I was getting 16V out of the 5V pins when I hooked the battery up. Second new Arduino(3rd total. 3) Working motor still works. Dead motor moved! To the limit, then quit. Near as I can tell now, the Arduino(3rd) isn't putting out modulating voltage from Pin 2 and 9. Steady 5V out both. Anybody seen this before?
