FlyPT Mover 3.7.0.15
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    Can’t properly lift my rig with following settings. @pmvcda Any Ideas?
  2. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Tried to change to the old string order (341256) but it gives me same results as in gif image I posted above.
    Edit:
    I edited manually the config with 250000 with even worse results
  3. pmvcda
    15,478Coins
    You are with motion4sim right?
    Right now i have my bldc rig and a odrive one to test.
    I have the motors to test the boards (Thanos and Motion4Sim) and it looked ok some time ago. Seems i have to check again...
    Edit: the output values are strange... But you have the output disconnected
  4. pmvcda
    15,478Coins
    Wait!
    I looked again at the string.
    Because of vars, it's no more axis1a format
    In list at the right, go to the rig, actuators and drag the value with B (bit value)
  5. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I am on the old Thanos AMC1280 board
  6. pmvcda
    15,478Coins
    @PeterW , you now have the T variable for turns in the actuators
  7. GTakacs
    GTakacs Member
    430Coins
    Any idea when a new release is coming with iRacing and MSFS sources working?
  8. pmvcda
    15,478Coins
    In 1 or 2 hours
  9. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Indeed, it’s more coherent now
  10. dureiken
    dureiken Active Member
    1,248Coins
    Thanks a lot for all your work, didn't yet look into that but I will soon :)
  11. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Pedro!
    Yes, of course I saw that straight away! A thousand thanks for that!
    Your personal tireless commitment here in the forum and for our entire community is overwhelming and unique! Thank you so much!
    Of course, I installed the new version as soon as it was released and hope to have time to familiarize myself with it over the next few days.
    When I have the new mover 3.7 running well, I will also share my knowledge in the forum on how to use the official Odrive firmware.
  12. pmvcda
    15,478Coins
    hmmm a bit more, still problems with simconnect :think
  13. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I have trouble to connect to DCS. No pb with 3.6Beta
  14. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
    at System.Linq.Enumerable.OfTypeIterator[TResult](IEnumerable source)+MoveNext()
    at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext()
    at Mover.Devices.Utils.UpdateDevicesListsInUI()
    at Mover.Devices.Joysticks.Update()
    at Mover.Devices.Joysticks.UpdateTimerElapsed(Object sender, EventArgs e)
    at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
    System.Private.CoreLib
    Assembly Version: 8.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.CoreLib.dll
    Mover
    Assembly Version: 3.7.0.0
    System.Runtime
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.dll
    System.Drawing.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Drawing.Primitives.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Windows.Forms.dll
    System.ComponentModel.EventBasedAsync
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.EventBasedAsync.dll
    System.ComponentModel.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.Primitives.dll
    System.Windows.Forms.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Windows.Forms.Primitives.dll
    System.Collections.Specialized
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Specialized.dll
    System.Diagnostics.Process
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.Process.dll
    System.Runtime.InteropServices
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.InteropServices.dll
    System.Threading
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.dll
    System.Diagnostics.TraceSource
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.TraceSource.dll
    System.Collections
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.dll
    System.Drawing.Common
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Drawing.Common.dll
    System.Xml.XDocument
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Xml.XDocument.dll
    System.Private.Xml.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Xml.Linq.dll
    System.Private.Xml
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Xml.dll
    System.Linq
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Linq.dll
    System.ComponentModel.TypeConverter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.TypeConverter.dll
    Microsoft.Win32.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\Microsoft.Win32.Primitives.dll
    System.Threading.Thread
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.Thread.dll
    Accessibility
    Assembly Version: 4.0.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\Accessibility.dll
    System.Resources.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Resources.Extensions.dll
    System.Memory
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Memory.dll
    System.Drawing
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Drawing.dll
    Microsoft.Win32.SystemEvents
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\Microsoft.Win32.SystemEvents.dll
    System.Numerics.Vectors
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Numerics.Vectors.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ComponentModel.dll
    System.Collections.Concurrent
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Concurrent.dll
    System.Runtime.Loader
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Loader.dll
    Microsoft.Win32.Registry
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\Microsoft.Win32.Registry.dll
    System.ObjectModel
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.ObjectModel.dll
    System.Collections.NonGeneric
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.NonGeneric.dll
    Microsoft.Windows.SDK.NET
    Assembly Version: 10.0.17763.24
    WinRT.Runtime
    Assembly Version: 2.0.0.0
    System.Runtime.CompilerServices.Unsafe
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.CompilerServices.Unsafe.dll
    System.Security.Cryptography.Algorithms
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Cryptography.Algorithms.dll
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Cryptography.dll
    System.Private.Uri
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Private.Uri.dll
    System.Linq.Expressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Linq.Expressions.dll
    System.Reflection.Emit
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Emit.dll
    Snippets
    Assembly Version: 0.0.0.0
    System.DoubleNumerics
    Assembly Version: 1.0.0.0
    System.Configuration.ConfigurationManager
    Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\8.0.8\System.Configuration.ConfigurationManager.dll
    System.Net.HttpListener
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Net.HttpListener.dll
    System.Net.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Net.Primitives.dll
    System.Net.Http
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Net.Http.dll
    System.Text.RegularExpressions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Text.RegularExpressions.dll
    System.Resources.Writer
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Resources.Writer.dll
    System.Runtime.Serialization.Formatters
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Serialization.Formatters.dll
    System.Reflection.Emit.ILGeneration
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Emit.ILGeneration.dll
    System.Diagnostics.Tracing
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.Tracing.dll
    System.Security.AccessControl
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.AccessControl.dll
    System.Security.Principal.Windows
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Principal.Windows.dll
    System.Runtime.Numerics
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Numerics.dll
    System.Formats.Asn1
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Formats.Asn1.dll
    System.Reflection.Primitives
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Primitives.dll
    System.Reflection.Metadata
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Reflection.Metadata.dll
    System.Xml.ReaderWriter
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Xml.ReaderWriter.dll
    System.Security.Claims
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Security.Claims.dll
    System.Net.WebSockets
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Net.WebSockets.dll
    System.Collections.Immutable
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Collections.Immutable.dll
    System.IO.Ports
    System.Text.Encoding.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Text.Encoding.Extensions.dll
    mscorlib
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\mscorlib.dll
    System.Runtime.Extensions
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Runtime.Extensions.dll
    NWaves
    Assembly Version: 0.9.6.0
    Mythosia.Integrity
    Assembly Version: 1.2.0.0
    netstandard
    Assembly Version: 2.1.0.0
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\netstandard.dll
    Mythosia
    System.Threading.ThreadPool
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Threading.ThreadPool.dll
    System.Diagnostics.StackTrace
    Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\System.Diagnostics.StackTrace.dll
  15. pmvcda
    15,478Coins
    Did you add or removed a joystick?
  16. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Some glitch in audio devices (Realtek blabla) for some unknown reasons. I clicked “update devices” and it seems fine now.
  17. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Could we have back the singularity limiters especially the leg angle with the platform position?
    It was a very useful security feature I think.
    Also could you briefly explain please the new “pre-follow” feature?
    Thank you so much for your efforts!
  18. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Before clicking update”:
    after clicking update”:
    Sound device no detected ??
  19. Marco Annunziata
    895Coins
    The pre follow is the width of the actuator's slowdown curve as it approaches the limit.
  20. pmvcda
    15,478Coins
    Guys, I'm sorry, we have to wait for tomorrow.
    Still having problems with Simconnect incorporation in .net8 single file...
    Debug/Release works, but not publish... :confused: Give me some more hours... sorry
    EDIT:
    It will come with iRacing, FS2020 and KayakVR
