Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. roli
    roli New Member
    53Coins
    I finally had some more time to work on this. Today I finally had a bit of a test with an actual game (using Forza Horizon 4 and black box motion for cars). This seems to work-ish, but during some more violent moves I noticed that sometimes some of the actuators actually hit the end (at the bottom). Which means that it went beyond the endstops - by more than the length of the slider piece in fact. If I am moving the rig manually (as shown in the above video) the thing always stays in the normal range - far beyond even hitting the endstops. Any ideas on why this would be happening?
  2. John Doe 77
    John Doe 77 New Member
    Hanau / Germany
    34Coins
    Hello everyone,
    I would like to start the project and I am very impressed by what you have already achieved!
    Does anyone happen to have the design as a STEP file?
    That would help me a lot with the mechanical production...
    Many thanks and best regards from Hanau, Jörn.
  3. Tarak Makwana
    Tarak Makwana aimbug
    3Coins
    Instead of BLDC8015A i am using BLD300 driver Please guide me what changes need to be made in the code ?
  4. MartiniNYC
    MartiniNYC New Member
    14Coins
    Last year I have build my first 2dof platform with brushed motors, wormgear using mega2560 with smc3. I was amazed, it worked and experience flying dcs in vr is just insane.
    Now I would like to build 3dof. I have bought 57BLF03 24v with BLDC-8015A driver and smc3 board. Before I build rig I want to test motor but I came to a small issue when I was trying to upload your code from page 1 to smc3. There is a problem with lines 185 and 186 compiling it. I goggled it and found that with new upgrade some APIs were removed and replaced with others.
    Removed APIs
    • ledcSetup
    • ledcAttachPin
    • I don’t know what to do and can’t proceed. Can you please help me with this. Thank you.
  5. pmvcda
    15,702Coins
    Smc3? This project uses a diy board with esp32
  6. MartiniNYC
    14Coins
    Oh I sorry for my mistake. Smc3 with mega2560 I used last year for my 2dof.
    Now I would like to build my new rig based on ESP32 board with your code. I Can’t upload your code because some APIs were removed/replaced with others. 2 lines having issue. Line 185 and 186.
    Please help.
    Thank you
  7. MartiniNYC
    14Coins
    i ordered another board and I tried couple more times to compile your esp32 code but i had no luck. Its still the same problem, line 185 and 186. Like i said before i google it and found in Arduino forum that some APIs were removed or changed. UGHH.
    So after failure with above i bought Arduino UNO (came today) and for last couple hours Im trying to figure it out.
    Code compiled/uploaded with no issues, Great. I wired 57BLF03 motor to BLDC-8015A driver as per your diagram from page 1. Got 2 microswitches, 10 turn potentiometer.
    This is my driver connection:
    Blue - W, Green - V, Yellow - U
    Red - Ref+, Yellow - HU, Green - HV, Blue - HW, Black - Ref-
    F/R to ard to 2, AVI to ard 3, Grd to ard grd which is also connected to power supply ground.
    2 microswitches and pot also wired and checked.
    When i turn on power, motor spins all the time without uno connected and even with uno connected it only spins. I tried to move potentiometer and press limit switches and nothing, just keeps spinning. BTW both small switches on the driver are in position ON. When i push switch nr 2 to off motor stops but still pot and switches not doing anything.
    I already started building 3dof platform and i was so excited about it.
    Please, any i will appreciate any help.
    153,830Coins
    +11,151 / 57 / -2
    As @pmvcda ha alredy pointed out:
    If you post specific information regarding the esp32 difficulties then perhaps those following this thread may be able to offer some insight and ideas.
    But with respect to an Arduino, and some seemingly random related external forum information which may or may not be relevant to motion simulation, you need to start an independent thread specifically about that approach, linking in all relevant information.
  9. MartiniNYC
    14Coins
    I wanted to give update on the issue I had trying to upload esp32 code. I read that in latest update to esp32 library by espressif (3.0.4) some API were removed or changed and that probably created issue with uploading this years old code.
    So I completely uninstalled Arduino and deleted all the files. Then I installed arduino again but I chose to install previous version of esp32 by espressif library and WOW it worked. Compile and upload was successful.
    Now I’m into wiring and testing 1 motor first. Will keep you posted.
  10. WiZard
    WiZard New Member
    South Africa
    265Coins
  11. Qui
    Qui New Member
    - 154Coins
    can you share the code running on mega2560
  12. Krotoffv
    Krotoffv New Member
    49Coins
    DC motor
    Hello, friends. Will I be able to use 80ST engines to work with this ESP 32 firmware?
  13. mohmine
    mohmine New Member
    16Coins
    hello guys. my project is making a small 6 dof prototype with flypt and linear actuators with bts7960 motor driver , and infortunatly i can't get the actuators to move properly using arduino mega, i suspect it's a problem with the code reading data from flypt the actuators react weardly, can i get any help here? upload_2025-5-15_22-40-16.jpeg
  14. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    Question , show where you got the code for Arduino Mega with BTS7969 support ?
  15. SimbaFlyer
    SimbaFlyer New Member
    11Coins
    Hi Paulo, I used your Gerber files and ordered the PCB boards from JCLPCB. I want to use it for 2 DOF FlightSim. I tried to do a Continuity Test on the board using the Schematic on the first page, and noticed that eg.
    - Pin 8 for Actuator#1 continues to HV side, bottom right of Level Shifter #2
    - Pin 8 for Actuator#2 continues to HV side, bottom right of Level Shifter #3
    - Pin 8 for Actuator#3 continues to HV side, bottom right of Level Shifter #1
    Can I use only 2 motor/controllers on this board and which actuator connectors should I connect them to? Thanks!
    EDIT1:
    Upon further continuity test with the multimeter, I see that Actuator #1 to #2 match, #2 to #3 match, but not #1 to #3, some pins were missing. So Maybe I should put my 2 motor/controllers on #2 and #3?
    EDIT2:
    To answer my own question, I connected Motor 1 to connector 1 and motor 2 to connector 2 and it does work, no issues.
  16. Mech1
    Mech1 Member
    178Coins
    Hello gentlemen,
    I was really glad to find this website recently. I currently own an H2 platform, but these DOF 6 platforms of this design simply blow my mind. I got very excited about the idea of building one myself. However, all my experience so far has been with H2 platforms, which have a completely different design and working principle.
    I would really appreciate some advice regarding weight limits.
    I’m planning to buy the actuators from this for-sale post, but I’m very worried about one thing. I weigh about 90–95 kg, plus my cockpit. Altogether that puts me at around 140–150 kg. In the sale post it says everything is built exactly like in the original author’s project.
    My concern is this: do you think this construction can safely handle 150 kg? The author of the original project mentioned it was designed for around 100 kg. :( I’m worried that with my 90–95 kg there won’t be much margin left for the cockpit at all, if the platform really can only safely support 100 kg.
    I’ve done a rough calculation of motor power, and it seems there should be some headroom. But I don’t know how the load is distributed across the actuators, and I’m especially worried about extreme positions — could one or more actuators be overloaded in certain simulator situations due to uneven weight distribution?
    Any advice or clarification would be greatly appreciated.
  17. Mech1
    Mech1 Member
    178Coins
    P.S. Marketplace: 6DOF FlyPT project for sale
    This i am planing to buy. I am asking about this :) i try to put link on it in my post, but it is not possible to do. Sorry, can do only this way.
  18. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    Excellent work!
    This represents a top-level level of engineering.
