power supply
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jarena, Mar 25, 2024.
  1. jarena
    jarena Member Gold Contributor
    126Coins
    hi guys ,
    On the diagram using 2 ITB-2 and Adruino, it shows one power supply to run 2 motors. my question is .. one power supply enough to run 2 24v motors that pull about 4amps each?
    Also if I understand correctly , to position the pot i have to remove them from the motors , center the chair and the motor links , then open simtools to make sure my pots are also centered and then attach them to the motor correct?
  2. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    360Coins
  3. jarena
    126Coins
    thanks for the reply will try this over the weekend .
  4. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    99Coins
    I am running 2 24v 250 watt motors off a single 600 watt 30 amp power supply . Using 24 volt motors means you only draw half the amperage of 12 volt motors. Watts divided by voltage = amps
