DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. mxignas154
    mxignas154 New Member
    94Coins
    DC motor
    Hello, part by part got odesc 56v and magnetic encoder, just need to wait for hoverboard. But the most important queation is, what power supply should i use? Now i have 12v 21a, but i think thats too weak
  2. Radje748
    Radje748 Member
    263Coins
    Question... everything seems to work(Odesc 4.2 and FF beast). But....
    One problem I have, is that when with no game, just on power...when I turn the wheel from left to right and let it loose it moves very aggressive to 1 side.and keeps spinning...what to do about this? Also when I keep turning it..suddenly it speeds up to that direction
    thanx!! :)
  3. Radje748
    Radje748 Member
    263Coins
    And the wheel is 100%... very impressed by the force and speed.
    Only thing is that I cannot get Rfactor 2 working.... steering and pedals are working, force is not working.
    I tried all things (remove Json files, set FFB positive and negative)...
    So anyone the golden tip...or can share their 2 .Json files?
  4. norfgs
    norfgs New Member
    16Coins
    what settings did you make on odrive?
  5. Arta Yasa
    Arta Yasa Member
    824Coins
    Hi sir i see this only used pwm, how abour dir pin sir?? So how the controler can recive the direction of ffb sir??
  6. Chris_Beeves
    2,064Coins
    It uses 0-50-100 type.
    0 is full left 100 is full right
  7. Arta Yasa
    Arta Yasa Member
    824Coins
    How to set up like that sir???
  8. Chris_Beeves
    2,064Coins
    Set what up, the mmos unit? You do it in the setup menu.
  9. Arta Yasa
    Arta Yasa Member
    824Coins
    Not all software are suport?? Like openffb or emc??
  10. Chris_Beeves
    2,064Coins
    One question mark per question is enough!
    Pretty sure EMC supports it, openffb I have not worked with at all but that is a motor driver too right? I don’t see the issue. Do you need something that works with absolutely everything or something that works?
    Do you have the hardware already?
  11. Arta Yasa
    Arta Yasa Member
    824Coins
    Oke sir, iam not have yet the hardware, but already have dd wheel diy with vesc, but i want cheaper more than vesc sir
  12. Chris_Beeves
    2,064Coins
    I’d use the odrive since you don’t have to get any extra mcu like with EMC, mmos or other solutions. The driver board is expensive, but in the end it’s cheaper.
  13. mxignas154
    94Coins
    DC motor
    Hello, came back to my project, have hoverboard motor and odesc v4.2, but do not know what software and firmware to use. If someone would help my with that question it will be awesome, THANKS!
    (Also do i need an ST-Link for an things to do??)
  14. Chris_Beeves
    2,064Coins
    Try the https://ffbeast.github.io/
    Compact solution. You shouldn’t need an stlink to flash the board, usb and dfu mode should do it
  15. mxignas154
    94Coins
    DC motor
    Do i should connect odesc to arduino leonardo? Or what, trying to flash firmware to odesc, but that gives me nothing when opening ffbeast hardware setting ui, it doesnt recognize as device or any controller
  16. Chris_Beeves
    2,064Coins
    Everything runs on the odesc, but you have to flash it with a custom firmware and get a licence key from the author.
  17. Chris_Beeves
    2,064Coins
  18. mxignas154
    94Coins
    DC motor
    license key? for stm32cubeprogrammer?
    where should i use it?
    Also do anyone have wiring diagram,because iam now with that type of motor controller (odesc) and 3 phase motor
  19. Chris_Beeves
    2,064Coins
    For activating the FFBeast unit after you flashed it. It's not necessary though if you don't need to add buttons and stuff.
    The motor wires can be connected in any way you want.
    The encoder is connected to 5V, gnd, A & B (leave Z free)
    The resistor to the AUX port
    That's pretty much it.
  20. mxignas154
    94Coins
    DC motor
    So connecting arduino is not needed? i only need to flash firmware to odesc v4.2 with stm32cubeprogrammer and it should work after wiring done?
